POLARMODE system variable
Polar mode
Specifies the settings for entity snap tracking and polar snap tracking. The value is stored as a bitcode using the sum of the values of all selected options.
| Type: | Short |
| Saved in: | Registry |
| Range: | 0 to 15 |
| Default value: | 1 |
| Possible options: | 1: Relative 2: Use polar tracking settings in entity snap tracking 4: Use additional polar tracking angles 8: Press SHIFT to acquire entity snap tracking points |
