PRINTPDFPREVIEW system variable
Print As PDF Preview
Specifies whether Print As PDF preview uses a system default PDF viewer or an internal program window.
BricsCAD only
| Type: | Short |
| Saved in: | Preference |
| Range: |
0 to 1 |
| Default value: |
1 |
| Possible values: |
0: Use BricsCAD window 1: Use external viewer |
