PROMPTMENU system variable
Prompt menu
Specifies the command prompt menu mode.
BricsCAD only
| Type: | Short |
| Saved in: |
Registry |
| Range: |
0 to 5 |
| Default value: |
0 |
| Possible values: |
0: Don't display prompt menu 1: Display prompt menu 2: Display prompt menu at top left corner 3: Display prompt menu at top right corner 4: Display prompt menu at bottom left corner 5: Display prompt menu at bottom right corner |
