PROMPTOPTIONTRANSLATEKEYWORDS system variable
Prompt option translate keywords
Specifies whether translations of command option keywords are loaded or not. If disabled, the local keyword will be a copy of the global (English) keyword. As a result global shortcuts can be used without underscore.
BricsCAD only
| Type: | Boolean |
| Saved in: | Preference |
| Default value: | On |
| Possible values: |
Off (0): Don’t load translations of keywords On (1): Load translations of keywords |
