PROPUNITS system variable
Property units
Specifies whether certain types of property values are automatically formatted (e.g. mm²/cm²/m² for areas), when INSUNITS is not zero.
BricsCAD only
| Type: | Short |
| Saved in: |
Registry |
| Range: |
0 to 255 |
| Default value: |
47 |
| Possible values: |
1: Format length properties 2: Format area properties 4: Format volume properties 8: (Reserved) 16: Format dynamic dimensions 32: Format mass properties |
