PUBLISHALLSHEETS system variable
Publish all sheets
Specifies whether to load the contents of the active document or of all open documents in the Publish dialog box.
Tipo: | Booleana |
Salvato in: |
Registro di sistema |
Valore predefinito: | On |
Valori possibili: |
Off (0): Only the contents of the current document automatically load On (1): The contents of all open documents automatically load |
