QUADGOTRANSPARENT system variable
Quad go transparent
Specifies if the quad starts should go transparent while the mouse is moving away from it.
BricsCAD only
| Type: | Boolean |
| Saved in: | Preference |
| Default value: | Off |
| Possible values: |
Off (0): Don’t go transparent On (1): Go transparent |
