QUADHIDEMARGIN system variable
Quad hide margin
Controls the width of the active margin area around the Quad.
As long as the mouse keeps moving inside this margin, the Quad will stay visible. The Quad will still gradually go transparent if QUADGOTRANSPARENT system variable is on.
As soon as the mouse movement stops, or when the mouse is moved beyond the margin, the quad will disappear.
Solo-BricsCAD
Tipo: | Breve |
Salvato in: | Preferenza |
Valore predefinito: |
50 |
