REPORTPANELMODE system variable
Report panel mode
Specifies the mode of report panel. Applicable only for commands which support it.
- Classic: Report panel has its classic appearance as dockable window.
- Modern: Report panel is a transparent window.
- Hidden: Report panel is a transparent window that is hidden into the status bar.
BricsCAD only
| Type: | Short |
| Saved in: |
Workspace |
| Range: |
0 to 2 |
| Default value: |
2 |
| Possible values: |
0: Classic 1: Modern 2: Hidden |
