RULERDISPLAY system variable
Ruler Display
Specifies the display of the ruler when moving objects using the manipulator or the DMPUSHPULL command.
| Type: |
Boolean |
| Saved in: |
Registry |
| Default value: |
On |
| Possible values: |
Off (0): Do not display ruler On (1): Display ruler when objects are moved using the manipulator or the DMPUSHPULL command. |
