RULERTEXTCOLOR system variable
Ruler Text Color
Controls the text color of the Manipulator ruler.
Applies only if the RULERDISPLAY system variable is on (1).
Tipo: |
Stringa |
Salvato in: |
Preferenza |
Valore predefinito: |
#c8c8c8 |
Valori possibili: |
RGB color code Hex color code Index color code |
A new value for the variable can be entered in the Command line.
