SAVEFIDELITY system variable
Save fidelity
Specifies whether the drawing is saved with visual fidelity. Controls whether the current display of the drawing is preserved when opened in a program that does not support annotative entities.
| Type: | Boolean |
| Saved in: | Registry |
| Range: |
0 to 1 |
| Default value: |
On |
| Possible values: |
Off (0): Don’t save with visual fidelity On (1): Save with visual fidelity |
