SECTIONSETTINGSSEARCHPATH system variable
Section settings search path
Specifies the folder(s) in which BricsCAD should look for BIM section styles, BIM tag styles and drawing customizations. Search paths are separated by a semicolon (;).
BricsCAD only
| Type: |
String |
| Saved in: |
Registry |
| Default value: | " " |
