SECTIONSHEETSETTEMPLATEIMPERIAL system variable
Section sheet set template imperial
Sets the sheetset file (dst) that will be used as a template when a new sheetset is created on generating sections when MEASUREMENT is 0 (imperial). The default file is BIM-section-imperial.dst, which can be found in the {SheetSetTemplatePath} folder.
BricsCAD only
| Type: |
String |
| Saved in: |
Registry |
| Default value: | BIM-section-imperial.dst |
Note: The SECTIONSHEETSETTEMPLATEIMPERIAL system variable is only available for BIM and Ultimate license levels.
