SHEETSETTEMPLATEPATH system variable
Sheet Set template path
Specifies the path to the Sheet Set Templates folder. The default path is: \Users\<user name>\AppData\Local\ Bricsys\BricsCAD\V23x64\en_US\Templates
| Type: |
String |
| Saved in: | Preference |
