SHOWDOCTABS system variable
Tabs visibility
Toggles showing of the document tabs On/Off. You can make the drawing area larger by hiding the document tabs from the user interface.
Solo-BricsCAD
Tipo: | Booleana |
Salvato in: | Registro di sistema |
Valore predefinito: | On |
Valori possibili: |
Off (0): Don’t make tabs visible On (1): Make tabs visible |
