SHOWDOCTABS system variable
Tabs visibility
Toggles showing of the document tabs On/Off. You can make the drawing area larger by hiding the document tabs from the user interface.
BricsCAD only
| Type: | Boolean |
| Saved in: | Registry |
| Default value: | On |
| Possible values: |
Off (0): Don’t make tabs visible On (1): Make tabs visible |
