SINGLETONMODE system variable
Singleton mode
Switch to control whether one or more instances of BricsCAD can run simultaneously. When set to Off, only a single instance of BricsCAD can run. When set to On, you can launch two or more copies of BricsCAD at the same time.
Solo-BricsCAD
Tipo: | Booleana |
Salvato in: | Preferenza |
Valore predefinito: | OFF |
Valori possibili: |
Off (0): Singleton mode off On (1): Singleton mode on |
