SINGLETONMODE system variable
Singleton mode
Switch to control whether one or more instances of BricsCAD can run simultaneously. When set to Off, only a single instance of BricsCAD can run. When set to On, you can launch two or more copies of BricsCAD at the same time.
BricsCAD only
| Type: | Boolean |
| Saved in: | Preference |
| Default value: | Off |
| Possible values: |
Off (0): Singleton mode off On (1): Singleton mode on |
