SMDEFAULTBENDRADIUSTYPE system variable
Bend radius type
Controls the default sheet metal bend radius.
Absolute value toggles the Thickness ratio. Override bend radius in SMCONVERT controls if the bend radius is taken from SMDEFAULTBENDRADIUSVALUE or from the model.
Solo-BricsCAD
Tipo: |
Breve |
Salvato in: |
Disegno |
Gamma: |
0 to 3 |
Valore predefinito: |
2 |
Valori possibili: |
1: Absolute value 2: Override bend radius in SMCONVERT |
