SMDEFAULTRIBFILLETRADIUSTYPE system variable
Bead fillet radius type
Determines whether bead fillet radius to be treated as ratio to profile radius or absolute value. Value will be used to initialize sheet metal settings in the document.
Solo-BricsCAD
Tipo: |
Breve |
Salvato in: |
Disegno |
Valore predefinito: | 0 |
Valori possibili: |
0: Profile radius ratio 1: Absolute value |
