SMDEFAULTRIBROUNDRADIUSTYPE system variable
Bead round radius type
Determines whether bead round radius to be treated as ratio to thickness or absolute value. Value will be used to initialize sheet metal settings in the document.
Solo-BricsCAD
Tipo: |
Breve |
Salvato in: |
Disegno |
Valore predefinito: | 0 |
Valori possibili: |
0: Thickness ratio 1: Absolute value |
