SMSPLITORTHOGONALBENDSPLIT system variable
Orthogonal bend split
Determines split behavior when split curve touches bend. If enabled, split direction for bend will be orthogonal to bend axis. If disabled, split direction will be tangential to split curve.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Drawing |
| Default value: |
Off |
