SNAPISOPAIR system variable
Snap isometric pair
Specifies the current viewport's isometric plane (left, top or right), used if SNAPSTYL is isometric. Press F5 function key to set the appropriate drawing plane: Left, Top or Right.
| Type: | Short |
| Saved in: | Drawing |
| Range: |
0 to 2 |
| Default value: |
0 |
| Possible values: |
0: Left 1: Top 2: Right |
