SPAMINVGRIDLINES system variable
Minimum number of V grid lines
Specifies the minimum number of V grid lines. At least this number of grid lines are generated in V direction. This variable is ignored if FACETRES is used. Spa is short for Spatial, the maker of ACIS.
BricsCAD only
| Type: | Long |
| Saved in: | Preference |
| Default value: |
0 |
