SPANORMALTOL system variable
Normal tolerance
The normal tolerance specifies the maximum normal deviation allowed between two normals on two adjacent facet nodes in degrees. The proper value is usually independent of the model size. This variable is ignored if FACETRES is used. Spa is short for Spatial, the maker of ACIS.
BricsCAD only
| Type: | Real |
| Saved in: | Preference |
| Default value: |
15.0 |
