SPAUSEFACETRES system variable
Use FACETRES system variable
Specifies whether the FACETRES system variable will be used instead of normal tolerance. Spa is short for Spatial, the maker of ACIS.
BricsCAD only
| Type: | Boolean |
| Saved in: | Preference |
| Default value: | On |
