SSFOUND system variable
Sheet set found
Displays the sheet set file name and path that is associated with the current drawing file (if it is currently open).
Read-only
Type: | String |
Saved in: | Not saved |
SSFOUND system variable - BricsCAD Lite & Pro | Centro Assistenza Bricsys
