SSLOCATE system variable
Sheet set locate
Specifies whether BricsCAD will try to locate and open a sheet set for the drawing that is being opened.
| Type: | Boolean |
| Saved in: | Registry |
| Default value: | On |
| Possible values: |
Off (0): Don’t open a drawing's sheet set with the drawing On (1): Open a drawing's sheet set with the drawing |
