SSMAUTOOPEN system variable
Sheet set manager auto open
Specifies whether or not BricsCAD displays the Sheet Set Manager when a drawing is opened that is associated with a sheet set. SSMAUTOOPEN and SSLOCATE must both be switched on to display the sheet set automatically.
| Type: | Boolean |
| Saved in: | Workspace |
| Default value: | On |
| Possible values: |
Off (0): Don’t open sheet set panel automatically On (1): Open sheet set panel automatically |
