SSMSTATE system variable
Sheet set manager state
Specifies if the Sheet Set Manager is active or not.
Read-only
| Type: | Short |
| Saved in: | Not saved |
| Range: |
0 to 1 |
| Default value: |
0 |
| Possible values: |
0: Sheet Set Manager is not active 1: Sheet Set Manager is active |
