TSPACETYPE system variable
Text space type
Specifies the type of line spacing used for multiline text.
- At least: adjusts line spacing based on the tallest character(s) in a line.
- Exactly: uses the specified line spacing, regardless of individual character sizes.
Note: The mtexts created with the MLEADER command are also influenced by this system variable's value.
| Type: |
Short |
| Saved in: |
Registry |
| Range: |
1 to 2 |
| Default value: |
1 |
| Possible values: |
1: At least 2: Exactly |
