UCSORTHO system variable
UCS orthographic
Specifies whether or not the related orthographic UCS setting is activated automatically when selecting an orthographic view with the -VIEW command or the LookFrom widget (unless NAVVCUBEORIENT is set to UCS).
| Type: | Boolean |
| Saved in: | Registry |
| Default value: | Off |
| Possible values: |
Off (0): When an orthographic view is selected, don’t automatically activate the related orthographic UCS On (1): When an orthographic view is selected, automatically activate the related orthographic UCS |
