USENEWRIBBON system variable
Use the new Ribbon
Controls whether the new Ribbon is used.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Registry |
| Default value: |
Off |
| Possible values: |
Off (0): Disable the new Ribbon On (1): Enable the new Ribbon after restart |
