VTFPS system variable
View transition minimum FPS
Specifies the minimum FPS (frames per second) required for enabling animated view transitions. That is 7 by default, which means that the redraw time should take less than 143 (=1000/7) milliseconds. If the computer is not capable to redraw the view fast enough, no animation will be available.
Tipo: | Breve |
Salvato in: | Registro di sistema |
Gamma: |
1 to 30 |
Valore predefinito: |
7 |
