BricsCAD and AutoCAD® feature comparison
The following tables compare BricsCAD features with AutoCAD® features.
Drawings
BricsCAD AutoCAD®
Lite Pro BIM Mechanical Ultimate LT Full
Native DWG file format (thru AutoCAD 2023)
DWG Password Protection - -
eTransmit
Sheet Set Manager
Geographic Location Settings
Drawing Compare
Cloud Collaboration
Interface
BricsCAD AutoCAD®
Dark and Light Color Themes
Industry standard commands, aliases, and variables
Click-able Command Line w/Auto Complete
Start Tab
File (Drawing) tabs
Model and Layout tabs
Layout Manager - -
Menu Bar
Toolbars
Ribbon
Tool Palettes
Contextual Right-click Menus
Contextual Quad Menu - -
Status Bar
Workspaces
Searchable Settings (SysVar) Dialog Box - -
Lockable Interface
Clean Screen Mode
Drawing Explorer - -
Customizable User Interface (CUI)
Drawing Structure Browser - -
Selection, snap & track
BricsCAD AutoCAD®
Selection Filtering (QSELECT)
Add Selected
Select Similar
Selection Cycling
Entity Snaps (OSNAPs)
Polar Tracking
Z-intersection 3D snap - -
Nearest Distance - -
Adaptive Grid Snap - -
Real-time Boundary Detection - -
2D Dynamic UCS - -
3D Dynamic UCS -
Drawing tools
BricsCAD AutoCAD®
Line, Polyline, 3D Polyline, Spline, Ray, Xline
Multi-lines and Multi-line Styles -
Circle, Arc, Ellipse, Elliptical Arc
Polygon, Rectangle, Region, Donut, Point
Helix -
2D Parameters & Constraints -
2D Auto-constrain 1 1
Annotation tools
BricsCAD AutoCAD®
Dimensions, Dimension Styles
Multi-leaders, Multi-leader Styles
Single and Multi-line text, Text Styles, Text Editor
Hatches, Gradients, Hatch/Gradient Editor
Wipeouts
Revision Clouds
Attributes, Attribute Editor
Tables, Table Styles
Fields
Data Extraction -
Data Linking
Annotation Scaling
Spell Check
AutoCAD Mechanical Compatibility: Read, Display, Edit - - - - -
Editing tools
BricsCAD AutoCAD®
Move, Copy, Rotate, Scale, Stretch, Mirror, Align
Trim, Extend, Lengthen, Break, Join
Fillet, Chamfer
CopyGuided - -
MoveGuided - -
Grip Editing
Properties Panel
Manipulator (3D Gizmo) -
Draw Order
Undo Per Entity (Property History) - -
Optimize - -
Simplify - -
Reference tools
BricsCAD AutoCAD®
Blocks, Block Editor
Dynamic Blocks 2 2 2 2 2
Camera-facing Blocks - -
Blockify - -
Associative Arrays
DWG (XREF) Attach, Clip, Bind, & Edit
PDF Attach, & Clip
Image Attach, Clip, & Adjust, with Transparency
Point Cloud Color-mapping - -
Visualization tools
BricsCAD AutoCAD®
Layers & Layer States
Entity Transparency
Visual Styles -
LookFrom (ViewCube) -
Match Perspective - -
Lights - -
Sun Properties - -
Materials - -
Rendering - -
Animation Editor - - -
Walk-through 3D Navigation - -
ANIPATH command - -
Modeling tools
BricsCAD AutoCAD®
ACIS-based Solid Modeling - -
Solid and Surface Modeling - -
Solid Primitives - -
Mesh Primitives - -
Polysolids - -
Union, Subtract, Intersect, Interfere - -
Extrude, Revolve, Loft, Sweep, Thicken - -
Twist - - -
Fillet, Chamfer - -
Slice - -
Multi-slice - - -
T-Connect, L-Connect, & Connect with Nearest Tools - - -
Extract Edges - -
Direct (history-less) Modeling - -
Deformable (Free-form) Modeling - -
Audit, Simplify -
Stitch - -
3D Parameters & Constraints - -
3D Automatic Parameterization - - -
3D Blockify and Parametric Blockify - - -
3D Parametric Design Tables - - -
Section Planes - -
Drawing Views: Base, Projected, Section, Detail and Break Views - -
3D Threads - - -
Point Cloud Align - - -
Point Cloud Bubble Viewer - -
Civil tools
BricsCAD AutoCAD®
TIN Surface Modeling - - -
Civil Points - - -
TIN Volume Surface - - -
Grading - - -
Alignments - - -
Profiles (Vertical Alignments) - - -
Corridors - - -
Autodesk Civil 3D Object Enabler -
Boundary Trim - - -
Building tools
BricsCAD AutoCAD®
CAD-based BIM features - - - - -
IFC Import/Export - - - - -
RVT/RFA Import - - - - -
Structural Modeling Toolset - - - - -
Project Database - - - - -
Project Browser - - - - -
Library Database - - - - -
Site, Building and Stories - - - - -
Windows and Doors - - - - -
Fully Parametric BIM Component Creation - - - - -
BOM Manager - - - -
3D Spaces - - - - -
Quickwall - - - - -
Quickdraw - - - - -
Quickbuilding - - - - -
Point Cloud Floor Detection - - - - -
Point Cloud Projection - - - - -
Point Cloud Geometry Detection - - - - -
Point Cloud FitPlanar (geometry detection) - - - - -
Propagate - - - - -
Custom BIM Properties - - - - -
Graphical Override - - - - -
Drawing Customizations - - - - -
BIM Dimensions - - - - -
Analytical Models - - - - -
Python Scripts (Beta) - - - - -
Manufacturing tools
BricsCAD AutoCAD®
Mechanical Browser - - -
Parts Library - -
Piping - - -
Assembly Modeling - - - - -
Exploded Views - - - - -
Kinematic Analysis - - - - -
Bill of Materials - - - - -
Balloons associated with BOM and Drawing Views - - - - -
Sheet Metal Design - - - - -
3D Solids to Sheet Metal Parts Recognition and Conversion - - - - -
Corner Relief for Adjacent Edge Flanges - - - - -
Lofted Bends - - - - -
Other features: Junctions, Miters, Tabs, Form Features - - - - -
Feature Coloring - - - - -
Diagnostic & Repair for Sheet Metal Features - - - - -
Batch Processing of Sheet Metal Features - - - - -
Import, export, output
BricsCAD AutoCAD®
Print/Plot
Publish/Batch Plot
CTB & STB Files
PC3 Printer Configuration Files
Named Page Setups
PDF Import, Export
DAE Import, Export - -
IFC Import, Export - - - -
3DM Import, Export - - -
LandXML Import, Export - - -
Import Autodesk Civil 3D Data - - -
SKP Import - - -
DGN Import
RVT Import - - - - -
DWF Export
SVG Export - -
FBX Export - -
STL Export -
Point Cloud Export (available formats below) - - 3
.LAS - - 3
.PTS - - 3
Point Cloud Import (available formats below) - - 3
.LAS - - 3
.LAZ - - 3
.PTS - - 3
.PTX - - 3
.e57 - - 3
.RCS - -
.RCP - -
Additional file formats accessible via BricsCAD Communicator (available formats below)
CATIA V4 4.1.9 − 4.2.4 - -
CATIA V5 V5R8 − V5−6 R2021 - -
IGES up to 5.3 - -
Inventor V11 − V2022 - -
JT 8.x, 9.x, 10, 10.2, 10.3, and 10.5 - -
NX 1 − NX 195311 − NX 1953 - -
Parasolid 9.0.x − 33.0.x - -
Pro/E / Creo 16 − Creo 8.0 - -
Solid Edge V18 − SE 2021 - - -
SolidWorks 2003 − 2021 - -
STEP AP203, AP214, AP242 - -
STL All (Graphical data only) - - -
VDA−FS 1.0 − 2.0 - - -
XCGM R2012 − 2021 1.0 - - -
Programming
BricsCAD AutoCAD®
ActiveX -
Extended Entity Data Editor -
Script Recorder -
Full LISP Support (vl, vlr, vla and vlax) -
Solutions Development System (SDS/ADS) -
Dialog Control Language (DCL) -
COM API - -
VBA Project Support - -
.NET - -
BRX (ARX-compatible API) - -
TX (Teigha eXtensions) - -
CUI Menu File Support, with Diesel Expressions
Licensing
BricsCAD AutoCAD®
Multi-platform Licenses - -
Perpetual Licenses - -
Perpetual + (Optional) Maintenance - -
Subscriptions
Network Multi-user - -
Volume (Perpetual) - -
Academic
(1) You can automatically apply geometric constraints but you cannot automatically apply a combination of geometric and dimensional constraints.
(2) You can manipulate Dynamic block insertions but you cannot create Dynamic block definitions. You can convert some Dynamic blocks to Parametric blocks that can be further edited. You can also create new Parametric block definitions.
(3) In the Autodesk® product suite, Recap is needed to import non-native point cloud formats and convert to AutoCAD's native rcs/rcp. For las/laz/pts/ptx, Map 3D and/or Civil 3D may be sufficient.
