account
translation
Bricsys Help Center
Add scale dialog box
  • BricsCAD
    • What's new in BricsCAD V21
      • Overview
      • User interface
      • Productivity
      • Drafting
      • Modeling
      • Civil tools
      • Performance and compatibility
    • Installation and licensing
      • Installing BricsCAD
        • Minimum system requirements and recommendations
        • Downloading BricsCAD
        • Overview of install options
          • Interactive installation
          • Silent Installation (Windows only)
        • Trial mode
      • Activating and licensing BricsCAD
        • Overview of licensing options
          • License levels
          • License types
          • Additional license options
        • BricsCAD and AutoCAD feature comparison
        • Trial: online activation
        • Trial: offline (manual) activation
        • Single or volume license: online activation
        • Single or volume license: offline (manual) activation
        • Using a network license on a client computer
      • Setting up a network license server
        • Network license server
        • Quick guide on using a network license
        • Setting up a Windows network license server
        • Setting up a Linux license server
        • Network license: online activation
        • Network license: offline (manual) activation
        • Network license server administration
        • Advanced configurations
      • Managing licenses
        • Modifying a BricsCAD license
        • Deactivating or revoking a BricsCAD license
        • Migrating a single or volume license to another computer
        • Migrating a network license to another server
        • License pooling
        • Network license usage report
        • Roaming
          • Roaming a network license on a client computer
          • Returning a roamed network license to the server
        • Proxy settings on a client computer
    • Getting started with BricsCAD
      • Launching BricsCAD
      • Exploring the interface
        • The Start tab
        • Document tabs
        • Choosing the workspace
        • The drawing area
        • The Command line
        • メニュー
        • Toolbars
        • The ribbon
        • The Quad basics
        • Right-click menus
        • The status bar
        • Panels
        • The clean screen mode
        • Look From widget
      • Working in BricsCAD
        • Creating a drawing
        • Template drawings
        • Entity creation settings
        • How to draw accurately
        • Executing commands
        • View control
        • Selecting entities
        • Using the Manipulator
        • Working with the Structure panel
    • User interface
      • The BricsCAD application window
      • The Command line
      • The Status bar
      • Document tabs
      • Toolbars
      • The Quad cursor menu
      • Rollover tips
      • Prompt menus
      • Keyboard shortcuts
      • Digitizing tablet
      • Panels
        • Animation editor panel
        • Attachments panel
        • BIM BCF panel
        • BIM compositions panel
        • BIM profiles panel
        • BIM project browser panel
        • BOM manager panel
        • Bricsys 24/7 panel
        • Command line panel
        • Content browser panel
        • Details panel
        • Drawing customizations panel
        • Layers panel
        • Library panel
        • Mechanical browser panel
        • Parameters and constraints panel
        • Properties panel
        • Render materials panel
        • Report panel
        • Sheet sets panel
        • Structure panel
        • Tips panel
        • Tool palettes panel
      • Dialog boxes
        • About BricsCAD dialog box
        • Add block to library dialog box
        • Add button item dialog box
        • Add menu item dialog box
        • Add-in manager dialog box
        • Add plot style table dialog box
        • Add scale dialog box
        • Allowed deviations from center axis dialog box
        • Annotation Object Scale dialog box
        • Array dialog box
        • Attach external reference
        • Attach PDF underlay dialog box
        • Attach raster image dialog box
        • Attribute editor dialog box
        • Auto Match dialog box
        • Background dialog box
        • BIM BCF panel - Custom login dialog box
        • BIM project info dialog box
        • BIM properties dialog box
        • Bimify dialog box
        • Blade - BricsCAD LISP advanced development environment dialog box
        • Block attribute manager dialog box
        • Block definition dialog box
        • Boundary dialog box
        • Bricsys license manager dialog box
        • Calculator dialog box
        • Change dictionaries dialog box
        • Change Icon dialog box
        • Choose window style dialog box
        • Column filter dialog box
        • Combine Duplicate Block Definitions dialog box
        • Communicator info dialog box
        • Component Tool Properties
        • Compositions dialog box
        • Configure Settings dialog box
        • Configure structure tree dialog box
        • Confirm deleting selected cache items
        • Create detail dialog box
        • Create new drawing dialog box
        • Create new sheet set dialog box
        • Create or edit block definition dialog box
        • Create Schedule dialog box
        • Create section/elevation dialog box
        • Current Plot Style dialog box
        • Customization groups dialog box
        • Customize dialog box
        • Customize (Tool Palettes) dialog box
        • Custom paper sizes dialog box
        • Custom properties dialog box
        • DataLink edit dialog box
        • Datalink manager dialog box
        • Default scale list dialog box
        • Define attribute dialog box
        • Delete duplicate entities dialog box
        • Drawing explorer dialog box
        • Drawing explorer options dialog box
        • Drawing properties
        • Drawing view presets dialog box
        • Edit attributes dialog box
        • Edit custom properties dialog box
        • Edit hyperlink dialog box
        • Edit scale dialog box
        • Edit scale list dialog box
        • Entity grouping dialog box
        • eTransmit dialog box
        • Extract attributes dialog box
        • Field dialog box
        • Filter Configurator dialog box
        • Find and replace dialog box
        • Flatshot dialog box
        • Format dialog box
        • Geographic location dialog box
        • Geometric tolerance dialog box
        • Hatch and gradient dialog box
        • Hatch Edit dialog box
        • Import Civil 3D dialog box
        • Import page setups dialog box
        • Import sheet set dialog box
        • Insert block dialog box
        • Insert object dialog box
        • Insert table dialog box
        • Layer Property Filter dialog box
        • Layer settings dialog box
        • Layer translator dialog box
        • Layout manager dialog box
        • Links dialog box
        • Load application files dialog box
        • Load linetypes dialog box
        • Load Multiline Styles dialog box
        • Login dialog box
        • Manage Customizations dialog box
        • Manage visibility
        • Map Connect dialog box
        • Match Properties dialog box
        • Motion path animation
        • Navigate Settings dialog box
        • New Layer Name dialog box
        • New Multileader Style dialog box
        • New Multiline Style dialog box
        • New Page Setup dialog box
        • New Sheet(s) dialog box
        • Optimize 2D lines dialog box
        • Page setup dialog box
        • Paste special dialog box
        • Physical materials dialog box
        • Plot stamp dialog box
        • Plot style table editor dialog box
        • Plotter Configuration Editor dialog box
        • Pre-process point cloud data file(s) dialog box
        • Print dialog box
        • Profiles dialog box
        • Project setup dialog box
        • Proxy information dialog box
        • Publish dialog box
        • QLeader Settings dialog box
        • Reassociate entity data dialog box
        • Reference Edit dialog box
        • Render dialog box
        • Run BricsCAD VBA macro dialog box
        • Save block definition dialog box
        • Save detail dialog box
        • Save workspace dialog box
        • Security dialog box
        • Security options dialog box
        • Select color dialog box
        • Select Custom Arrow Block dialog box
        • Select items to delete from cache dialog box
        • Select item to attach to this DWG
        • Settings dialog box
        • Set viewpoint dialog box
        • Sheet Properties dialog box
        • Sheet selection sets dialog box
        • Sheetset setup dialog box
        • Spatial Locations Manager dialog box
        • Spell checking
        • Standard open file dialog box
        • Standard save file dialog box
        • Tags dialog box
        • Tool image dialog box
        • Tool Properties dialog box
        • Upload to Bricsys 24/7 dialog box
        • User coordinate system dialog box
        • User profile manger dialog box
        • VBA manager dialog box
        • View Options dialog box
        • Visual settings dialog box
        • Wall detection options dialog box
        • Wizard page dialog box
        • Working sets dialog box
        • Write block to file dialog box
    • Managing drawings
      • Working in the Drawing Explorer dialog box
      • Drawing security options
      • Opening and saving drawings
      • Getting drawing information
      • Comparing drawings
      • Repairing a drawing
      • Projects
    • Drawing accurately
      • Orthogonal mode
      • Unit settings
      • Coordinate reference system
      • 2D constraints
      • Using dimensional constraints
      • Using geometric constraints
      • Dynamic dimensions
      • Nearest distance
      • Coordinate input
      • Snap and grid
      • Adaptive grid snap
      • Nudge
      • 2D entity snaps
      • 3D entity snaps
      • Polar tracking
      • Entity snap tracking
      • User coordinate systems
      • Dynamic UCS
      • Measuring
      • Entity snaps overview
        • Apparent intersection entity snap
        • Center entity snap
        • Center of a Face 3D entity snap
        • Endpoint entity snap
        • Extension entity snap
        • Geometric center entity snap
        • Insertion entity snap
        • Intersection entity snap
        • Intersection 3D entity snap
        • Knot 3D entity snap
        • Midpoint entity snap
        • Midpoint 3D entity snap
        • Nearest entity snap
        • Nearest 3D entity snap
        • Node entity snap
        • Parallel entity snap
        • Perpendicular entity snap
        • Perpendicular on a face 3D entity snap
        • Quadrant entity snap
        • Tangent entity snap
        • Vertex 3D entity snap
    • Viewing your drawing
      • View commands overview
      • Layer utilities
      • Hide and isolate entities
      • Panning
      • Zooming
      • View manipulation using the mouse and keyboard
      • View rotation
      • The LookFrom control
      • Layer states
      • Named views
      • Visual styles
      • Model space and paper space
      • Model space viewports
      • Paper space viewports
      • Creating paper space viewports
      • Layouts
      • Generated drawing views
    • 2D作図
      • Creating entities
      • Working with layers
      • Entity linetype
      • Entity color
      • Lineweight
      • Fill mode
      • Transparency
      • Editing entity properties
      • Drawing linear entities
      • Drawing lines
      • Drawing rays
      • Drawing infinite lines
      • Drawing polylines
      • Drawing multilines
      • Drawing splines
      • Drawing freehand sketches
      • Drawing circles
      • Drawing arcs
      • Drawing ellipses
      • Drawing rectangles
      • Drawing polygons
      • Drawing traces
      • Drawing donuts
      • Drawing solids
      • Drawing revision clouds
      • Drawing points
      • Drawing wipeouts
      • Drawing helixes
      • Drawing 3D polylines
      • Creating regions
      • Creating hatches and gradient fills
      • Editing hatches and gradient fills
    • 3D Modeling
      • Direct modeling overview
      • Navigate in 3D
      • Direct modeling commands
      • Direct modeling operations
      • Design intent recognition
      • Working with sections
      • Create a TIN Surface
      • TIN Surface Edit
      • TIN Surface Direct Modeling
      • Analyzing TIN Surfaces
      • Working with Gradings
      • Create and edit alignments
      • Modeling a Corridor
    • Parametric modeling
      • Operations and functions in expressions
      • 3D constraints
      • Suppression feature
      • Working with design tables
    • Point cloud
      • Working with Point cloud
    • ブロック、属性、外部参照およびコンポーネント
      • Creating blocks
      • Using Blockify
      • Editing blocks
      • Inserting blocks
      • Exploding blocks
      • 2D parametric blocks
      • Dynamic blocks
      • Defining attributes
      • Working with attributes
      • Editing attribute definitions
      • Editing block attributes
      • Inserting blocks with attributes
      • Extracting attribute information
      • Managing Xrefs
      • Attaching an external reference
      • Working with external references
      • Editing blocks and external references
      • Working with groups
      • Working with underlays
      • Components and component inserts
    • Managing images
      • Managing images
      • Image utilities
    • 注釈
    • Dimensions
      • Dimensioning tools overview
      • Associative dimensions
      • Dimension settings
      • Working with dimension styles
      • Using the dimension style tools
      • Creating linear dimensions
      • Creating angular dimensions
      • Creating diametrical and radial dimensions
      • Centerlines and center marks
      • Creating ordinate dimensions
      • Editing dimensions
      • Creating leaders and annotations
      • Creating multileaders
      • Adding geometric tolerances
    • Texts
      • Text system variables
      • Working with text styles
      • Creating text
      • Editing text
      • Exploding text
      • Finding and replacing text
      • Checking spelling
      • Working with fields
      • Working with tables
    • Annotative Entities
      • Annotative entities
      • Annotation scales
      • Annotative texts
      • Annotative blocks
      • Annotative dimensions
      • Annotative leaders
    • Customization
      • Startup options
      • BricsCAD user files
      • Loading and unloading CUI files
      • Creating a partial CUI file
      • Managing toolboxes
      • Creating toolbars
      • Creating menus
      • Creating context menus
      • Creating keyboard shortcuts
      • Customizing the Quad
      • Adding tools to user interface controls
      • Customizing the ribbon
      • Tool palettes
      • Command aliases
      • User profiles
      • Workspaces
      • Express tools
      • Lisp
    • Modifying Entities
      • Modifying commands overview
      • Entity modification settings
      • Match properties
      • Grips editing
      • Selection methods
      • Quick select
      • Draw order
      • The manipulator
      • Moving entities
      • Rotating entities
      • Mirroring entities
      • Aligning entities
      • Changing entities
      • Copying entities
      • Making parallel copies
      • Arraying entities
      • Extending entities
      • Trimming entities
      • Lengthening entities
      • Selection and grip settings
      • Stretching entities
      • Scaling entities
      • Breaking entities
      • Joining entities
      • Chamfering entities
      • Filetting entities
      • Editing polylines
      • Exploding entities
      • Measuring entities
      • Dividing entities
    • Printing and plotting
      • General procedure for printing
      • Plotter configuration
      • Plot style tables
      • The plot styles manager
      • Batch plot
    • Rendering
      • Using TwinMotion
      • Rendering overview
      • Rendering preferences
      • Rendering tools
      • Render materials
      • Lights
      • Creating a rendered image
    • User feedback
      • Diagnostics and usage data collection
  • BricsCAD BIM
    • What's new in BricsCAD V21 BIM
      • Overview
      • Modeling techniques
      • Building data
      • Project collaboration
      • Design documentation
      • Point clouds
    • Getting started
      • Creating a BIM model
      • Quad cursor
      • Viewing entities
      • Level of detail
      • BIM linear solid
      • BIM window create
      • The library panel
      • Connecting solids
      • Creating a custom window
      • Creating roofs
      • Creating slabs
      • Creating walls
      • Curtain wall
      • DmExtrude
      • DmPushPull
      • Editing grids
      • Mass modeling with quickbuilding
      • MEP modeling
      • MEP flow connection points
      • Offset
      • Splitting solids
      • Stair tool
      • Structural steel
      • Using BIM quickdraw
      • Using drag
      • Using parametrize
    • Building data
      • Analytical model
      • AutoComplete BIM data
      • Attaching compositions
      • BIM classify
      • BIM compositions
      • BIM data structure
      • BIM ply editing
      • BIM project info
      • Using Python scripts (beta)
      • Classification codes
      • Custom properties
      • Customizing BIM quantities
      • Project browser
      • Spatial locations
      • Structure browser
    • Design assistance
      • Using bimify
      • Using propagate
      • Propagate planar
      • Propagate linear
      • Propagate pattern
      • Propagate edges
      • Propagate corner
      • Parametrize details
      • Details panel
      • Import and underlay Autodesk® Revit® files in BricsCAD
      • Interference checking
      • Using Xrefs
      • Annotations in 3D
      • BIM sections
      • BIM tags
      • Create drawing types with drawing customization
      • Define detailed section
      • Detailing with BimPatch
      • Editing generated drawings
      • Elevation hatch
      • Enscape integration
      • Generating Drawings
      • Interior elevations
      • Schedules
      • Spot elevation level
  • BricsCAD Mechanical
    • BricsCAD V21 Mechanicalの新機能
      • Overview
      • BOM manager
      • Parts libraries
      • 標準部品
      • Sheet metal
    • Getting started
      • Mechanical workspace
      • 3D comparison
    • 部品設計
      • Thread feature
      • Part Design Methods
      • Sketching
      • Solid Modeling
      • Surface Modeling
      • Freeform Surface Modeling
    • アセンブリ設計
      • Bottom-up and Top-down Assembly Design
      • Assembly Design Commands and Tools
      • Component Properties
      • Assembly mass properties
      • Standard Mechanical Components
      • Piping in Assembly Design
      • Arrays of Components
      • Array Properties
      • Exploded Representations
      • Bill of Materials Manager
      • Bill of Materials
    • Sheet Metal
      • Sheet Metal Design Methods
      • Sheet Metal Commands and Toolbars
      • Sheet Metal Features
      • フィーチャーに色付け
      • Mechanical Browser for Sheet Metal
      • Sheet Metal Global and Feature Properties
      • K-factor
      • Bend Table
      • Sheet Metal Settings
      • Creating Flanges
      • Modifying Flanges
      • Working with Bends and Junctions
      • Working with Hems
      • Working with Tabs
      • Working with T-tabs and T-junctions
      • Working with Bevels
      • Creating and Splitting Lofted Bends
      • Working with Form and Rib Features
      • Working with Hole Features
      • Converting to Sheet Metal and Repairing
      • Unfolding Sheet Metal Parts and Exporting to CAM
      • Associative Unfolded Representations of 3D Solids
      • Smart Features
    • 生成された図面
      • Drawing Views
      • 注釈の作図
  • Communicator for BricsCAD
    • BricsCAD Communicator
  • BricsCAD Shape
    • Introduction to BricsCAD Shape
    • BricsCAD Shape user interface
    • Basic concepts of modeling in BricsCAD Shape
    • Navigation in BricsCAD Shape
    • Components in BricsCAD Shape
    • Materials in BricsCAD Shape
    • Layers in BricsCAD Shape
    • Working with steel profiles
    • Visualization in BricsCAD Shape
    • Solids in BricsCAD Shape
    • Creating walls in BricsCAD Shape
    • Quickdraw in BricsCAD Shape
    • Creating windows and doors in BricsCAD Shape
    • Creating roofs in BricsCAD Shape
  • Command reference
      • +STRUCTUREPANELコマンド
      • ? command
    • 2
      • 2DINTERSECTION command
    • 3
      • 3D command
      • 3DARRAY command
      • 3DCOMPARE command
      • 3DCONVERT command
      • 3DDWF command
      • 3DFACE command
      • 3DINTERSECTION command
      • 3DMESH command
      • 3DOSNAP command
      • -3DOSNAP command
      • 3DPOLY command
    • A
      • ABOUT command
      • ACISIN command
      • ACISOUT command
      • ACTIVATESECTIONVIEW command
      • ADDINMAN command
      • ADDSELECTED command
      • AI_BOX command
      • AI_CONE command
      • AI_CIRCTAN command
      • AI_CYLINDER command
      • AI_DESELECT command
      • AI_DIM_TEXTABOVE command
      • AI_DIM_TEXTCENTER command
      • AI_DIM_TEXTHOME command
      • AI_DISH command
      • AI_DOME command
      • AI_EDGESURF command
      • AI_FMS command
      • AI_PSPACE command
      • AI_PYRAMID command
      • AI_REVSURF command
      • AI_RULESURF command
      • AI_SELALL command
      • AI_SPHERE command
      • AI_TABSURF command
      • AI_TORUS command
      • AI_WEDGE command
      • AIMLEADEREDITADD command
      • AIMLEADEREDITREMOVE command
      • AIDIMFLIPARROW command
      • AIDIMPREC command
      • AIDIMSTYLE command
      • ALIGN command
      • ALIGNMENT command
      • ALIGNMENTEDIT command
      • ALIGNMENTVIEW command
      • ALIGNMENTVINITIAL command
      • ALIGNSPACE command
      • ANIMATIONEDITORCLOSE command
      • ANIMATIONEDITOROPEN command
      • ANIPATH command
      • ANNORESET command
      • ANNOUPDATE command
      • APERTURE command
      • APPARENT command
      • APPLOAD command
      • ARC command
      • AREA command
      • ARRAY command
      • -ARRAY command
      • ARRAYCLASSIC command
      • ARRAYCLOSE command
      • -ARRAYCLOSE command
      • ARRAYEDIT command
      • ARRAYEDITEXT command
      • ARRAYPATH command
      • ARRAYPOLAR command
      • ARRAYRECT command
      • ATTACHMENTSPANELCLOSE command
      • ATTACHMENTSPANELOPEN command
      • ATTDEF コマンド
      • -ATTDEF command
      • ATTDISP command
      • ATTEDIT command
      • ATTEXT command
      • -ATTEXT command
      • ATTREDEF command
      • ATTSYNC command
      • AUDIT command
      • AUTOCOMPLETE command
      • AUTOCONSTRAIN command
    • B
      • BACKGROUND command
      • BASE command
      • BATTMAN command
      • BCLOSE command
      • BEDIT command
      • -BEDIT command
      • BHATCH command
      • -BHATCH command
      • BIMACTIVATEPYTHON command
      • BIMADDECCENTRICITY command
      • BIMANALYTICALMODEL command
      • BIMAPPLYPROFILE command
      • BIMATTACHCOMPOSITION command
      • BIMATTACHSPATIALLOCATION command
      • BIMAUTOMATCH command
      • BIMCLASSIFY command
      • BIMCOPY command
      • BIMCREATEDETAIL command
      • BIMCURTAINWALL command
      • BIMDECOMPOSE command
      • BIMFLIP command
      • BIMFLOWCONNECT command
      • BIMGRID command
      • BIMIFY command
      • -BIMINSERT command
      • BIMINSERT command
      • BIMLINEARSOLID command
      • BIMLIST command
      • BIMMULTISELECT command
      • BIMPARAMETRIZEDETAIL command
      • BIMPATCH command
      • BIMPROFILES command
      • BIMPROJECTINFO command
      • BIMPROPAGATE command
      • BIMPROPAGATECORNER command
      • BIMPROPAGATEEDGES command
      • BIMPROPAGATELINEAR command
      • BIMPROPAGATEPATTERN command
      • BIMPROPAGATEPLANAR command
      • BIMPROPERTIES command
      • BIMPYTHON command
      • BIMROOM command
      • BIMQUICKBUILDING command
      • BIMQUICKDRAW command
      • BIMRECALCULATEAXIS command
      • BIMREGENERATETAGS command
      • BIMSECTION command
      • BIMSECTIONOPEN command
      • BIMSECTIONUPDATE command
      • BIMSETLOADBEARINGDIRECTION command
      • BIMSETREFERENCEFACE command
      • BIMSPACE command
      • BIMSPATIALLOCATIONS command
      • BIMSPLIT command
      • BIMSTAIR command
      • BIMSTRETCH command
      • BIMSTRUCTURALCONNECT command
      • BIMTAG command
      • BIMUPDATESPACE command
      • BIMUPDATETHICKNESS command
      • BIMWINDOWCREATE command
      • -BIMWINDOWCREATE command
      • BIMWINDOWPRINT command
      • BIMWINDOWUPDATE command
      • BLADE command
      • BLCOMPOSITIONS command
      • BLIPMODE command
      • BLMATERIALS command
      • BLOCK command
      • -BLOCK command
      • BLOCKICON command
      • BLOCKIFY command
      • BMBALLOON command
      • BMBOM command
      • BMBOMEDIT command
      • BMBOMPANELCLOSE コマンド
      • BMBOMPANELOPEN command
      • BMCONNECT command
      • BMCREATECOMPONENT command
      • -BMCREATECOMPONENT command
      • BMDEPENDENCIES command
      • BMDISSOLVE command
      • BMEXPLODE command
      • BMEXPLODEMOVE command
      • BMEXPLODESTEPEDIT command
      • BMEXTERNALIZE command
      • BMFORM command
      • BMHARDWARE command
      • -BMHARDWARE command
      • BMHIDE command
      • BMINSERT command
      • -BMINSERT command
      • BMLINK command
      • BMLOCALIZE command
      • BMMASSPROP command
      • BMMECH command
      • BMNEW command
      • BMOPEN command
      • BMOPENCOPY command
      • -BMPARAMETERS command
      • BMPOUT command
      • BMRECOVER command
      • BMREPLACE command
      • BMSHOW コマンド
      • BMTRAILINGLINES command
      • BMUNLINK command
      • BMUNMECH command
      • BMUPDATE command
      • BMVSTYLE command
      • BMXCONVERT command
      • BOUNDARY command
      • -BOUNDARY command
      • BOX command
      • BREAK command
      • BROWSER command
      • BSAVEAS コマンド
    • C
      • CALコマンド
      • CALLOUT command
      • CAMERA command
      • CENTER command
      • CENTERDISASSOCIATE command
      • CENTERLINE command
      • CENTERMARK command
      • CENTERREASSOCIATE command
      • CENTERRESET command
      • CHAMFER command
      • CHANGE command
      • CHPROP command
      • CHSPACE command
      • CIRCLE command
      • CIVIL3DIMPORT command
      • CIVILDWGEXPORT command
      • CLEANSCREENOFF command
      • CLEANSCREENON command
      • CLEANUNUSEDVARIABLES command
      • CLIPDISPLAY command
      • CLOSE command
      • COLOR command
      • -COLOR command
      • COMMANDLINE command
      • COMMANDLINEHIDE command
      • COMMANDS command
      • COMMUNICATORINFO command
      • COMPONENTSPANELCLOSE command
      • COMPONENTSPANELOPEN command
      • CONE command
      • CONSTRAINTBAR command
      • CONTENTBROWSERCLOSE command
      • CONTENTBROWSEROPEN command
      • CONVERTCTB command
      • CONVERTOLDLIGHTS command
      • CONVERTOLDMATERIALS command
      • CONVERTPOLY command
      • CONVERTPSTYLES command
      • CONVTOMESH command
      • CONVTOSOLID command
      • CONVTOSURFACE command
      • COPY command
      • COPYBASE command
      • COPYCLIP command
      • COPYEDATA command
      • COPYGUIDED command
      • COPYHIST command
      • COPYTOLAYER command
      • CORRIDOR command
      • CORRIDOREDIT command
      • CORRIDOREXTRACT command
      • CORRIDORTEMPLATE command
      • CORRIDORTEMPLATEELEMENT command
      • CPAGESETUP コマンド
      • CREATELIBRARYBLOCK command
      • -CREATELIBRARYBLOCK command
      • CREATETHUMBNAIL command
      • CUILOAD command
      • CUIUNLOAD command
      • CUSTOMIZE command
      • CUTCLIP command
      • CYLINDER command
    • D
      • DATAEXTRACTION command
      • -DATAEXTRACTION command
      • DATALINK command
      • DATALINKUPDATE command
      • DATASMITHEXPORT command
      • DBLIST command
      • DCALIGNED command
      • DCANGULAR command
      • DCCONVERT command
      • DCDIAMETER command
      • DCDISPLAY command
      • DCHORIZONTAL command
      • DCLINEAR command
      • DCRADIUS command
      • DCVERTICAL command
      • DDATTE command
      • DDEDIT command
      • DDEMODES command
      • DDFILTER command
      • DDGRIPS command
      • DDPTYPE コマンド
      • DDSELECT コマンド
      • DDSETVAR command
      • DDSTRACK command
      • DDVPOINT command
      • DEFAULTSCALELIST command
      • DELAY command
      • DELCONSTRAINT command
      • DELEDATA command
      • DESIGNTABLE command
      • -DESIGNTABLEEDIT command
      • DETAILSPANELCLOSE command
      • DETAILSPANELOPEN command
      • DGNEXPORT command
      • -DGNEXPORT command
      • DGNIMPORT command
      • DGNIMPORTOPTIONS コマンド
      • DIM command
      • DIM1 Command
      • DIMALIGNED command
      • DIMANGULAR command
      • DIMARC command
      • DIMBASELINE command
      • DIMBREAK command
      • DIMCENTER コマンド
      • DIMCONSTRAINT command
      • DIMCONTINUE command
      • DIMDIAMETER command
      • DIMDISASSOCIATE command
      • DIMEDIT command
      • DIMLEADER command
      • DIMLINEAR command
      • DIMORDINATE command
      • DIMOVERRIDE command
      • DIMRADIUS command
      • DIMREASSOCIATE command
      • DIMREGEN command
      • DIMSTYLE command
      • -DIMSTYLE command
      • DIMSTYLESET command
      • DIMTEDIT command
      • DISH command
      • DIST command
      • DISTANTLIGHT command
      • DIVIDE command
      • DMANGLE3D command
      • DMAUDIT command
      • DMAUDITALL command
      • DMCHAMFER command
      • DMCOINCIDENT3D command
      • DMCONCENTRIC3D command
      • DMCONSTRAINT3D command
      • DMCOPYFACES command
      • DMDEFORMCURVE command
      • DMDEFORMMOVE command
      • DMDEFORMPOINT command
      • DMDELETE コマンド
      • DMDISTANCE3D command
      • DMEXTRUDE command
      • DMFILLET command
      • DMFIX3D command
      • DMGROUP command
      • DMMOVE command
      • DMPARALLEL3D command
      • DMPATH3D command
      • DMPERPENDICULAR3D command
      • DMPUSHPULL command
      • DMRADIUS3D command
      • DMREPAIR command
      • DMREVOLVE command
      • DMRIGIDSET3D command
      • DMROTATE command
      • DMSELECT command
      • DMSELECTEDGES command
      • DMSIMPLIFY command
      • DMSIMPLIFYALL command
      • DMSTITCH command
      • DMTANGENT3D command
      • DMTHICKEN command
      • DMTHREAD command
      • DMTWIST command
      • DMUPDATE command
      • DOME command
      • DONUT command
      • DRAG command
      • DRAGMODE command
      • DRAWORDER command
      • DRAWORDERBYLAYER command
      • DSETTINGS command
      • DTEXT command
      • DUMPSTATE command
      • DVIEW command
      • DWFOUT command
      • DWGCODEPAGE command
      • DWGCOMPARE command
      • DWGPROPS command
      • DXFIN command
      • DXFOUT command
    • E
      • EATTEDIT command
      • EDGESURF command
      • EDITEDATA command
      • ELEV command
      • ELLIPSE command
      • ENABLEASSOCVIEWS command
      • ENDCOMPARE command
      • ENDPOINT command
      • ERASE command
      • ETRANSMIT command
      • -ETRANSMIT command
      • EXECUTETOOL command
      • EXPBLOCKS command
      • EXPFOLDERS command
      • EXPIMAGES command
      • EXPLAYERS command
      • EXPLODE command
      • EXPLORER command
      • EXPORT command
      • EXPORTLAYOUT command
      • EXPORTPDF command
      • EXPPDFS command
      • EXPUCS command
      • EXPXREF command
      • EXTEND command
      • EXTENSION コマンド
      • EXTRUDE command
    • F
      • FBXEXPORT command
      • -FBXEXPORT command
      • FIELD command
      • FILEOPEN command
      • FILES command
      • FILL command
      • FILLET command
      • FIND command
      • FITARC command
      • FITLINE command
      • FLATSHOT command
      • FLATTEN command
      • FROM command
    • G
      • GCCOINCIDENT command
      • GCCOLINEAR command
      • GCCONCENTRIC command
      • GCENTER command
      • GCEQUAL command
      • GCFIX command
      • GCHORIZONTAL command
      • GCPARALLEL command
      • GCPERPENDICULAR command
      • GCSMOOTH command
      • GCSYMMETRIC command
      • GCTANGENT command
      • GCVERTICAL command
      • GENERATEBOUNDARY command
      • GEOGRAPHICLOCATION command
      • GEOIMPORT command
      • GEOMCONSTRAINT command
      • GOTOSTART command
      • GRADIENT command
      • -GRADIENT command
      • GRADIENTBKGOFF command
      • GRADIENTBKGON command
      • GRADING command
      • GRADINGBALANCE command
      • GRAPHSCR command
      • GRID command
      • GROUP command
      • -GROUP command
    • H
      • HATCH コマンド
      • -HATCH command
      • HATCHEDIT Command
      • -HATCHEDIT command
      • HATCHEDITEXT command
      • HATCHGENERATEBOUNDARY command
      • HATCHTOBACK command
      • HELIX command
      • HELP command
      • HELPSEARCH command
      • HIDE command
      • HIDEOBJECTS command
      • HYPERLINK command
      • -HYPERLINK command
      • HYPERLINKOPTIONS command
    • I
      • ID command
      • IEMBED command
      • IFCEXPORT command
      • IMAGE command
      • IMAGEADJUST command
      • -IMAGEATTACH
      • IMAGEATTACH command
      • IMAGECLIP command
      • IMAGEFRAME command
      • IMAGEQUALITY コマンド
      • -IMPORT command
      • IMPORT command
      • IMPRINT command
      • INSERT command
      • -INSERT command
      • INSERTALIGNED command
      • INSERTION command
      • INSERTOBJ command
      • INTERFERE command
      • -INTERFERE command
      • INTERSECT command
      • INTERSECTION コマンド
      • INVOKETESTAPP command
      • ISAVEAS command
      • ISOLATEOBJECTS command
      • ISOPLANE command
      • IUNEMBED command
    • J
      • JOIN command
    • K
      • KEEPME command
    • L
      • LANDXMLEXPORT command
      • LANDXMLIMPORT command
      • LAYCUR command
      • -LAYER command
      • LAYER command
      • LAYERP コマンド
      • LAYERSPANELCLOSE command
      • LAYERSPANELOPEN command
      • LAYERSTATE command
      • LAYFRZ command
      • LAYISO command
      • LAYLCK command
      • LAYMCUR command
      • LAYOFF command
      • LAYON command
      • LAYOUT command
      • LAYOUTMANAGER command
      • LAYTHW command
      • LAYTRANS command
      • LAYULK command
      • LAYUNISO command
      • LCONNECT command
      • LEADER command
      • LENGTHEN command
      • LIBRARYPANELCLOSE command
      • LIBRARYPANELOPEN command
      • LICENSEMANAGER command
      • LIGHT command
      • LIGHTLIST command
      • LIMITS command
      • LINE command
      • -LINETYPE command
      • LINETYPE command
      • LIST command
      • LIVESECTION command
      • LOAD command
      • LOFT command
      • LOGFILEOFF command
      • LOGFILEON command
      • -LOGIN command
      • -LOGOUT command
      • LOOKFROM command
      • LWEIGHT command
    • M
      • MAIL command
      • MANIPULATE command
      • MAPCONNECT command
      • MASSPROP command
      • MATBROWSERCLOSE command
      • MATBROWSEROPEN command
      • MATCHPERSPECTIVE command
      • MATCHPROP command
      • MATERIALASSIGN command
      • MATERIALMAP command
      • MATERIALS command
      • MATLIB command
      • MEASURE command
      • MECHANICALBROWSERCLOSE command
      • MECHANICALBROWSEROPEN command
      • MENU command
      • MENULOAD command
      • MENUUNLOAD command
      • MIDPOINT command
      • MINSERT command
      • MIRROR command
      • MIRROR3D command
      • MLEADER command
      • MLEADERALIGN command
      • MLEADERCOLLECT command
      • MLEADEREDIT command
      • MLEADEREDITEXT command
      • MLEADERSTYLE command
      • MLINE command
      • MLSTYLE command
      • MODELERPROPERTIES コマンド
      • -MODELERPROPERTIES command
      • MOVE command
      • MOVEEDATA command
      • MOVEGUIDED command
      • MSLIDE command
      • MSPACE command
      • MTEXT command
      • -MTEXT command
      • MTP command
      • MULTIPLE command
      • MVIEW command
      • MVSETUP command
    • N
      • NAVIGATE command
      • NEARESTコマンド
      • NETLOAD command
      • NEW command
      • NEWSHEETSET command
      • NEWWIZ command
      • NODE command
      • NONE command
      • NUMBER command
    • O
      • OBJECTSCALE command
      • -OBJECTSCALE command
      • OFFSET command
      • OLELINKS command
      • OLEOPEN command
      • ONWEB command
      • OOPS コマンド
      • OPEN command
      • OPENSHEETSET command
      • -OPENSHEETSET command
      • OPTIMIZE コマンド
      • -OPTIMIZE command
      • OPTIONS command
      • ORTHOGONAL command
      • OSNAP command
      • -OSNAP command
      • OVERKILL command
      • -OVERKILL command
    • P
      • PACKAGE command
      • PAGESETUP command
      • PAN command
      • -PAN command
      • PANELIZE command
      • PARALLEL command
      • PARAMETERCOPYMODE command
      • -PARAMETERS command
      • PARAMETERSPANELCLOSE command
      • PARAMETERSPANELOPEN command
      • PARAMETRICBLOCKIFY command
      • PARAMETRIZE command
      • PARAMETRIZE2D command
      • PASTEBLOCK command
      • PASTECLIP command
      • PASTEORIG command
      • PASTESPEC command
      • PDF command
      • PDFADJUST command
      • PDFATTACH command
      • -PDFATTACH command
      • PDFCLIP command
      • PDFIMPORT command
      • -PDFIMPORT command
      • PDFLAYERS command
      • PDFOPTIONS command
      • PEDIT command
      • PEDITEXT command
      • PERPENDICULAR command
      • PFACE command
      • PLACEVIEW command
      • PLAN command
      • PLINE command
      • PLOT command
      • -PLOT command
      • PLOTSTAMP command
      • PLOTSTYLE command
      • PLOTTERMANAGER command
      • PNGOUT command
      • POINT コマンド
      • POINTCLOUD command
      • POINTCLOUDALIGN command
      • POINTCLOUDATTACH command
      • -POINTCLOUDATTACH command
      • POINTCLOUDCOLORMAP command
      • POINTCLOUDCROP command
      • POINTCLOUDCROPSOLID command
      • POINTCLOUDDELETEITEM command
      • POINTCLOUDDETECTFLOORS command
      • POINTCLOUDEXPORT command
      • POINTCLOUDFITPLANAR command
      • POINTCLOUDIMPORT command
      • POINTCLOUDPOINTSIZE_MINUS command
      • POINTCLOUDPOINTSIZE_PLUS command
      • POINTCLOUDPREPROCESS command
      • -POINTCLOUDPREPROCESS command
      • POINTCLOUDPROJECTSECTION command
      • POINTCLOUDREFERENCE command
      • POINTCLOUDSHOWBUBBLES command
      • POINTCLOUDUNCROP command
      • POINTLIGHT command
      • POLYGON command
      • POLYSOLID command
      • PREVIEW command
      • PRINT command
      • PROFILEMANAGER command
      • PROJECTGEOMETRY command
      • PROPERTIES command
      • PROPERTIESCLOSE command
      • PROXYINFO command
      • PSETUPIN command
      • -PSETUPIN command
      • PSPACE command
      • PUBLISH command
      • -PUBLISH command
      • PURGE command
      • -PURGE command
      • PYRAMID command
    • Q
      • QLEADER command
      • QNEW command
      • QPRINT command
      • QSAVE command
      • QSELECT command
      • QTEXT command
      • QUADRANT command
      • QUIT command
    • R
      • RAY command
      • REASSOCAPP command
      • RECOVER command
      • RECOVERALL command
      • RECSCRIPT command
      • RECTANG command
      • REDEFINE command
      • REDO command
      • REDRAW command
      • REDRAWALL command
      • REDSDKINFO command
      • REFCLOSE command
      • REFEDIT command
      • -REFEDIT command
      • REFERENCECURVES command
      • REFSET command
      • REGEN command
      • REGENALL command
      • REGENAUTO command
      • REGION command
      • REINIT command
      • RENAME command
      • -RENAME command
      • RENDER command
      • -RENDER command
      • RENDERCOMPOSITIONSMATERIAL command
      • RENDERPRESETS command
      • RENDERWINCLOSE command
      • REPORTPANELCLOSE command
      • REPORTPANELOPEN command
      • RESETASSOCVIEWS command
      • RESETBLOCK command
      • RESUME command
      • REVCLOUD command
      • REVOLVE command
      • REVSURF command
      • RIBBON command
      • RIBBONCLOSE command
      • ROTATE command
      • ROTATE3D command
      • RSCRIPT command
      • RTLOOK command
      • RTPAN command
      • RTROT command
      • RTROTCTR command
      • RTROTF command
      • RTROTX command
      • RTROTY command
      • RTROTZ command
      • RTUPDOWN command
      • RTWALK command
      • RTZOOM command
      • RULESURF command
      • RUNASLEVEL command
    • S
      • SAVE command
      • SAVEALL command
      • SAVEAS command
      • SAVEASR12 Command
      • SAVEFILEFOLDER command
      • SCALE command
      • SCALELISTEDIT command
      • -SCALELISTEDIT command
      • SCREENSHOT command
      • SCRIPT command
      • SCROLLBAR command
      • SECTION command
      • SECTIONPLANE command
      • SECTIONPLANESETTINGS command
      • SECTIONPLANETOBLOCK command
      • SECURITY コマンド
      • SECURITYOPTIONS command
      • SELECT command
      • SELECTALIGNEDFACES command
      • SELECTALIGNEDSOLIDS command
      • SELECTCONNECTEDFACES command
      • SELECTSIMILAR command
      • SELGRIPS command
      • SETBYLAYER command
      • -SETBYLAYER command
      • SETLICENSELEVEL command
      • SETTINGS command
      • SETTINGSSEARCH command
      • SETUCS command
      • SETVAR command
      • SH command
      • SHADE command
      • SHADEMODE command
      • -SHADEMODE command
      • SHAPE command
      • SHEETSET command
      • SHEETSETHIDE command
      • SHELL command
      • SIMPLIFY command
      • SINGLETON command
      • SKETCH command
      • SLICE command
      • SMASSEMBLYEXPORT command
      • SMBENDCREATE command
      • SMBENDSWITCH command
      • SMCONVERT command
      • SMDELETE command
      • SMDISSOLVE command
      • SMEXPLODE command
      • SMEXPORT2D command
      • SMEXPORTOSM command
      • SMEXTRUDE command
      • SMFLANGEBASE command
      • SMFLANGEBEND command
      • SMFLANGECONNECT command
      • SMFLANGECONTOUR command
      • SMFLANGEEDGE command
      • SMFLANGEROTATE command
      • SMFLIP command
      • SMFORM command
      • SMHEMCREATE command
      • SMIMPRINT command
      • SMJUNCTIONCREATE command
      • SMJUNCTIONSWITCH command
      • SMLISPGET command
      • SMLISPSET command
      • SMLOFT command
      • SMPARAMETRIZE command
      • SMRELIEFCREATE command
      • SMRELIEFSWITCH command
      • SMREPAIR command
      • SMREPLACE command
      • SMRIBCREATE command
      • SMSELECT command
      • SMSPLIT command
      • SMTABCREATE command
      • SMUNFOLD command
      • SNAP command
      • SOLID command
      • SOLIDEDIT command
      • SOLPROF command
      • SPELL command
      • SPHERE コマンド
      • SPLINE command
      • SPLINEDIT command
      • SPOTLIGHT command
      • STANDARDPARTSPANELCLOSE command
      • STANDARDPARTSPANELOPEN command
      • START command
      • STATBAR command
      • STATUS command
      • STLOUT command
      • STOPSCRIPT command
      • STRETCH command
      • STRUCTUREPANEL command
      • STRUCTUREPANELCLOSE command
      • STYLE command
      • -STYLE command
      • STYLESMANAGER command
      • SUBTRACT command
      • SUNPROPERTIES command
      • SUPPORTFOLDER command
      • SUPPRESS command
      • SVGOPTIONS command
      • SWEEP command
      • SYSWINDOWS command
    • T
      • TABLE command
      • -TABLE command
      • TABLEDIT command
      • TABLEEXPORT command
      • TABLEMOD command
      • TABLESTYLE command
      • TABLET command
      • TABSURF command
      • TANGENT command
      • TCONNECT command
      • TEMPLATEFOLDER command
      • TESTDBUSERIO command
      • TESTDLG command
      • TESTFATAL command
      • TESTINTERNAL command
      • TESTSELECTION command
      • TEXT command
      • -TEXT command
      • TEXTSCR command
      • TEXTTOFRONT command
      • TFLOAD command
      • TFSAVE command
      • TIME command
      • TIN command
      • TINASSIGNIMAGE command
      • TINEDIT
      • TINEXTRACT command
      • TINMERGE command
      • TINMODIFY command
      • TINPROJECT command
      • TINSERT command
      • TINVOLUME command
      • TINWATERDROP command
      • TIPS command
      • TOLERANCE command
      • TOOLBAR command
      • -TOOLBAR command
      • TOOLPALETTES command
      • TOOLPALETTESCLOSE command
      • -TOOLPANEL command
      • TORUS command
      • TPNAVIGATE command
      • TRACE command
      • TRANSPARENCY command
      • TRIM command
      • TXT2MTXT command
      • TXTEXP command
    • U
      • U command
      • UCS command
      • UCSICON command
      • UNDEFINE command
      • UNDO command
      • UNDOENT command
      • UNGROUP command
      • UNION command
      • UNISOLATEOBJECTS command
      • UNITS command
      • -UNITS command
      • UPDATEFIELD command
      • URL command
    • V
      • VBAIDE command
      • VBALOAD command
      • -VBALOAD command
      • VBAMAN command
      • VBANEW command
      • VBARUN command
      • -VBARUN command
      • VBASECURITY command
      • VBAUNLOAD command
      • VERSIONCONTROL command
      • VIEW command
      • -VIEW command
      • VIEWBASE command
      • VIEWBREAK command
      • VIEWDETAIL command
      • VIEWDETAILSTYLE command
      • VIEWEDIT command
      • VIEWEXPORT command
      • VIEWHORIZONTAL command
      • VIEWLABEL command
      • VIEWPOINT command
      • VIEWPROJ command
      • VIEWRES command
      • VIEWSECTION command
      • VIEWSECTIONSTYLE command
      • VIEWUPDATE command
      • VISIBILITYSTATES command
      • VISIBLE command
      • VISUALSTYLES command
      • -VISUALSTYLES command
      • VLIDE command
      • VMLOUT command
      • VPCLIP command
      • VPLAYER command
      • VPMAX command
      • VPMIN command
      • VPOINT command
      • VPORTS command
      • -VPORTS command
      • VSCURRENT command
      • VSLIDE command
      • VTOPTIONS command
    • W
      • WBLOCK command
      • -WBLOCK command
      • WCASCADE command
      • WCLOSE command
      • WCLOSEALL command
      • WEBLIGHT command
      • WEDGE command
      • WHOHAS command
      • WHTILE command
      • WIARRANGE command
      • WIPEOUT command
      • WMFOUT command
      • WNEXT command
      • WORKSETS command
      • WORKSPACE command
      • WPREV command
      • WSSAVE command
      • WSSETTINGS command
      • WVTILE command
    • X
      • XATTACH command
      • XCLIP command
      • XEDGES command
      • XFACES command
      • XLINE command
      • XMLSAVE command
      • XOPEN command
      • XPLODE command
      • XREF command
      • -XREF command
    • Y
    • Z
      • ZCENTER command
      • ZINTERSECTION command
      • ZKNOT command
      • ZMIDPOINT command
      • ZNEAREST command
      • ZNONE command
      • ZOOM command
      • ZPERPENDICULAR command
      • ZVERTEX command
  • System variable reference
    • _
      • _PKSER system variable
      • _QUADTABFLAGS システム変数
      • _VERNUM システム変数
    • 3
      • 3DCOMPAREMODE system variable
      • 3DOSMODE システム変数
      • 3DSNAPMARKERCOLOR システム変数
    • A
      • ACADLSPASDOC system variable
      • ACADPREFIX システム変数
      • ACADVER system variable
      • ACISHLRRESOLUTION system variable
      • ACISOUTVER system variable
      • ADAPTIVEGRIDSTEPSIZE システム変数
      • AFLAGS system variable
      • ALLOWTABEXTERNALMOVE system variable
      • ALLOWTABMOVE システム変数
      • ALLOWTABSPLIT system variable
      • ANGBASE システム変数
      • ANGDIR システム変数
      • ANNOALLVISIBLE system variable
      • ANNOAUTOSCALE system variable
      • ANNOSELECTED system variable
      • ANNOTATIVEDWG システム変数
      • ANTIALIASRENDER システム変数
      • ANTIALIASSCREEN system variable
      • APBOX system variable
      • APERTURE システム変数
      • AREA system variable
      • AREAPREC システム変数
      • AREAUNITS システム変数
      • ARRAYASSOCIATIVITY system variable
      • ARRAYEDITSTATE system variable
      • ARRAYTYPE system variable
      • ASSOCIATIVITY system variable
      • ATTDIA システム変数
      • ATTMODE system variable
      • ATTRACTIONDISTANCE system variable
      • ATTREQ システム変数
      • AUDITCTL システム変数
      • AUDITERRORCOUNT システム変数
      • AUNITS システム変数
      • AUPREC system variable
      • AUTOADOPTSIZES system variable
      • AUTOCOMPLETEDELAY システム変数
      • AUTOCOMPLETEMODE system variable
      • AUTOMENULOAD システム変数
      • AUTORESETSCALES システム変数
      • AUTOSAVECHECKSONLYFIRSTBITDBMOD システム変数
      • AUTOSNAP システム変数
      • AUTOTRACKINGVECCOLOR system variable
      • AUTOVPFITTING システム変数
      • AXISMODE system variable
      • AXISUNIT システム変数
    • B
      • BACKGROUNDPLOT system variable
      • BACKZ system variable
      • BASEFILE システム変数
      • BCFSOURCEURL system variable
      • BIMACTIVATEPYTHON system variable
      • BIMOSMODE システム変数
      • BIMPROFILESTANDARDS system variable
      • BINDTYPE system variable
      • BKGCOLOR system variable
      • BKGCOLORPS system variable
      • BLIPMODE システム変数
      • BLOCKEDITLOCK システム変数
      • BLOCKEDITOR system variable
      • BLOCKIFYMODE システム変数
      • BLOCKIFYTOLERANCE システム変数
      • BLOCKSPATH システム変数
      • BMAUTOUPDATE system variable
      • BMFORMTEMPLATEPATH システム変数
      • BMUPDATEMODE システム変数
      • BOUNDARYCOLOR system variable
      • BSYSLIBCOPYOVERWRITE システム変数
      • BVMODE system variable
    • C
      • CACHELAYOUT system variable
      • CAMERADISPLAY システム変数
      • CAMERAHEIGHT system variable
      • CANNOSCALE system variable
      • CANNOSCALEVALUE システム変数
      • CDATE system variable
      • CECOLOR system variable
      • CELTSCALE システム変数
      • CELTYPE system variable
      • CELWEIGHT system variable
      • CENTERCROSSGAP system variable
      • CENTERCROSSSIZE システム変数
      • CENTEREXE システム変数
      • CENTERLAYER system variable
      • CENTERLTSCALE システム変数
      • CENTERLTYPE system variable
      • CENTERLTYPEFILE システム変数
      • CENTERMARKEXE システム変数
      • CETRANSPARENCY システム変数
      • CHAMFERA system variable
      • CHAMFERB system variable
      • CHAMFERC system variable
      • CHAMFERD システム変数
      • CHAMMODE system variable
      • CHECKDWLPRESENCE system variable
      • CIRCLERAD system variable
      • CLAYER システム変数
      • CLEANSCREENOPTIONS system variable
      • CLEANSCREENSTATE システム変数
      • CLIPBOARDFORMAT システム変数
      • CLIPBOARDFORMATS システム変数
      • CLIPROMPTLINES システム変数
      • CLISTATE system variable
      • CLOSECHECKSONLYFIRSTBITDBMOD システム変数
      • CLOUDDOWNLOADPATH system variable
      • CLOUDLOG システム変数
      • CLOUDLOGVERBOSE system variable
      • CLOUDONMODIFIED system variable
      • CLOUDSERVER system variable
      • CLOUDTEMPFOLDER システム変数
      • CLOUDUPLOADDEPENDENCIES システム変数
      • CMATERIAL システム変数
      • CMDACTIVE システム変数
      • CMDDIA システム変数
      • CMDECHO system variable
      • CMDLINEEDITBGCOLOR システム変数
      • CMDLINEEDITFGCOLOR システム変数
      • CMDLINEFADINGLOGBGCOLOR システム変数
      • CMDLINEFADINGLOGFADEDELAY system variable
      • CMDLINEFADINGLOGFGCOLOR システム変数
      • CMDLINEFADINGLOGTRANSPARENCY システム変数
      • CMDLINEFONTNAME system variable
      • CMDLINEFONTSIZE system variable
      • CMDLINEFRAMEACTIVETRANSPARENCY system variable
      • CMDLINEFRAMEINACTIVETRANSPARENCY system variable
      • CMDLINELISTBGCOLOR システム変数
      • CMDLINELISTFGCOLOR システム変数
      • CMDLINEOPTIONBGCOLOR system variable
      • CMDLINEOPTIONSHORTCUTCOLOR システム変数
      • CMDLINEUSENEWFRAME システム変数
      • CMDLNTEXT システム変数
      • CMDNAMES システム変数
      • CMLEADERSTYLE システム変数
      • CMLJUST システム変数
      • CMLSCALE system variable
      • CMLSTYLE システム変数
      • CMPCLRMISS システム変数
      • CMPCLRMOD1 システム変数
      • CMPCLRMOD2 システム変数
      • CMPCLRNEW システム変数
      • CMPDIFFLIMIT system variable
      • CMPFADECTL システム変数
      • CMPLOG system variable
      • COLORBOOKPATH system variable
      • COLORTHEME system variable
      • COLORX システム変数
      • COLORY システム変数
      • COLORZ system variable
      • COMACADCOMPATIBILITY システム変数
      • COMBINETEXTMODE system variable
      • COMMUNICATORPATH システム変数
      • COMPASS system variable
      • COMPONENTSCONFIG システム変数
      • COMPONENTSPATH システム変数
      • CONSTRAINTBARDISPLAY システム変数
      • CONTINUOUSMOTION system variable
      • COORDS system variable
      • COPYMODE system variable
      • CPLOTSTYLE system variable
      • CPROFILE system variable
      • CREATETHUMBNAILONTHEFLY システム変数
      • CREATEVIEWPORTS system variable
      • CROSSHAIRDRAWMODE システム変数
      • CROSSINGAREACOLOR システム変数
      • CTAB システム変数
      • CTABLESTYLE system variable
      • CTRL3DMOUSE システム変数
      • CTRLMOUSE system variable
      • CURSORSIZE システム変数
      • CVPORT システム変数
    • D
      • DATACOLLECTION システム変数
      • DATALINKNOTIFY system variable
      • DATE system variable
      • DBCSTATE system variable
      • DBLCLKEDIT system variable
      • DBMOD system variable
      • DCTCUST システム変数
      • DCTMAIN system variable
      • DEFAULTBSYSLIBIMPERIAL system variable
      • DEFAULTBSYSLIBMETRIC system variable
      • DEFAULTLIGHTING システム変数
      • DEFAULTCURVETYPEHA system variable
      • DEFAULTCURVETYPEVA system variable
      • DEFAULTLIGHTSHADOWBLUR システム変数
      • DEFAULTNEWSHEETTEMPLATE system variable
      • DEFLPLSTYLE system variable
      • DEFPLSTYLE システム変数
      • DELETEINTERFERENCE システム変数
      • DELETETOOL システム変数
      • DELOBJ システム変数
      • DEMANDLOAD システム変数
      • DETAILSPATH system variable
      • DGNEXPXREFMODE システム変数
      • DGNFRAME system variable
      • DGNIMP2DCLOSEDBSPLINECURVEIMPORTMODE system variable
      • DGNIMP2DELLIPSEIMPORTMODE システム変数
      • DGNIMP2DSHAPEIMPORTMODE system variable
      • DGNIMP3DCLOSEDBSPLINECURVEIMPORTMODE system variable
      • DGNIMP3DELLIPSEIMPORTMODE システム変数
      • DGNIMP3DOBJECTIMPORTMODE システム変数
      • DGNIMP3DSHAPEIMPORTMODE system variable
      • DGNIMPBREAKDIMENSIONASSOCIATION システム変数
      • DGNIMPCONVERTDGNCOLORINDICESTOTRUECOLORS system variable
      • DGNIMPCONVERTEMPTYDATAFIELDSTOSPACES system variable
      • DGNIMPERASEUNUSEDRESOURCES system variable
      • DGNIMPEXPLODETEXTNODES システム変数
      • DGNIMPIMPORTACTIVEMODELTOMODELSPACE system variable
      • DGNIMPIMPORTINVISIBLEELEMENTS システム変数
      • DGNIMPIMPORTPAPERSPACEMODELS システム変数
      • DGNIMPIMPORTVIEWINDEX system variable
      • DGNIMPRECOMPUTEDIMENSIONSAFTERIMPORT システム変数
      • DGNIMPSYMBOLRESOURCEFILES system variable
      • DGNIMPXREFIMPORTMODE system variable
      • DGNOSNAP システム変数
      • DIASTAT システム変数
      • DIMADEC system variable
      • DIMALT システム変数
      • DIMALTD システム変数
      • DIMALTF システム変数
      • DIMALTRND システム変数
      • DIMALTTD システム変数
      • DIMALTTZ system variable
      • DIMALTU システム変数
      • DIMALTZ システム変数
      • DIMANNO システム変数
      • DIMAPOST システム変数
      • DIMARCSYM システム変数
      • DIMASO system variable
      • DIMASSOC システム変数
      • DIMASZ システム変数
      • DIMATFIT system variable
      • DIMAUNIT システム変数
      • DIMAZIN システム変数
      • DIMBLK system variable
      • DIMBLK1 システム変数
      • DIMBLK2 system variable
      • DIMCEN system variable
      • DIMCLRD システム変数
      • DIMCLRE システム変数
      • DIMCLRT システム変数
      • DIMDEC system variable
      • DIMDLE system variable
      • DIMDLI system variable
      • DIMDSEP system variable
      • DIMEXE システム変数
      • DIMEXO system variable
      • DIMFIT システム変数
      • DIMFRAC システム変数
      • DIMFXL system variable
      • DIMFXLON システム変数
      • DIMGAP system variable
      • DIMJOGANG system variable
      • DIMJUST system variable
      • DIMLAYER システム変数
      • DIMLDRBLK system variable
      • DIMLFAC システム変数
      • DIMLIM システム変数
      • DIMLTEX1 system variable
      • DIMLTEX2 system variable
      • DIMLTYPE system variable
      • DIMLUNIT system variable
      • DIMLWD system variable
      • DIMLWE system variable
      • DIMPOST システム変数
      • DIMRND システム変数
      • DIMSAH システム変数
      • DIMSCALE system variable
      • DIMSD1 system variable
      • DIMSD2 システム変数
      • DIMSE1 システム変数
      • DIMSE2 システム変数
      • DIMSHO システム変数
      • DIMSOXD システム変数
      • DIMSTYLE system variable
      • DIMTAD システム変数
      • DIMTDEC システム変数
      • DIMTFAC システム変数
      • DIMTFILL システム変数
      • DIMTFILLCLR システム変数
      • DIMTIH システム変数
      • DIMTIX システム変数
      • DIMTM システム変数
      • DIMTMOVE システム変数
      • DIMTOFL システム変数
      • DIMTOH システム変数
      • DIMTOL system variable
      • DIMTOLJ システム変数
      • DIMTP システム変数
      • DIMTSZ システム変数
      • DIMTVP system variable
      • DIMTXSTY system variable
      • DIMTXT system variable
      • DIMTXTDIRECTION システム変数
      • DIMTZIN システム変数
      • DIMUNIT システム変数
      • DIMUPT システム変数
      • DIMZIN system variable
      • DISPLAYAXES system variable
      • DISPLAYSCALING system variable
      • DISPLAYSIDESANDENDS system variable
      • DISPLAYSNAPMARKERINALLVIEWS system variable
      • DISPLAYTOOLTIPS system variable
      • DISPPAPERBKG システム変数
      • DISPPAPERMARGINS system variable
      • DISPSILH システム変数
      • DISTANCE システム変数
      • DMAUDITLEVEL システム変数
      • DMAUTOUPDATE system variable
      • DMCONNECTIONCUTTYPE システム変数
      • DMEXTRUDEMODE system variable
      • DMPUSHPULLSUBTRACT システム変数
      • DMRECOGNIZE system variable
      • DOCKPRIORITY システム変数
      • DOCTABPOSITION システム変数
      • DONUTID system variable
      • DONUTOD システム変数
      • DRAGMODE system variable
      • DRAGMODEHIDE システム変数
      • DRAGMODEINTERRUPT system variable
      • DRAGOPEN system variable
      • DRAGP1 システム変数
      • DRAGP2 システム変数
      • DRAGSNAP system variable
      • DRAWINGPATH システム変数
      • DRAWINGVIEWPRESET system variable
      • DRAWINGVIEWPRESETHIDDEN system variable
      • DRAWINGVIEWPRESETSCALE システム変数
      • DRAWINGVIEWPRESETTANGENT システム変数
      • DRAWINGVIEWPRESETTRAILING システム変数
      • DRAWING VIEWQUALITY システム変数
      • DRAWORDERCTL システム変数
      • DWFFORMAT system variable
      • DWFFRAME システム変数
      • DWFOSNAP システム変数
      • DWFVERSION システム変数
      • DWGCHECK system variable
      • DWGCODEPAGE system variable
      • DWGNAME system variable
      • DWGPREFIX system variable
      • DWGTITLED system variable
      • DXEVAL システム変数
      • DXFTEXTADJUSTALIGNMENT system variable
      • DYNCONSTRAINTMODE system variable
      • DYNDIGRIP system variable
      • DYNDIMAPERTURE システム変数
      • DYNDIMCOLORHOT システム変数
      • DYNDIMCOLORHOVER システム変数
      • DYNDIMDISTANCE システム変数
      • DYNDIMLINETYPE システム変数
      • DYNDIVIS system variable
      • DYNINPUTTRANSPARENCY システム変数
      • DYNMODE system variable
      • DYNPICOORDS システム変数
    • E
      • EDGEMODE system variable
      • ELEVATION system variable
      • ENABLEATTRACTION system variable
      • ENABLEHYPERLINKMENU システム変数
      • ENABLEHYPERLINKTOOLTIP システム変数
      • ERRNO system variable
      • EXPERT システム変数
      • EXPINSALIGN system variable
      • EXPINSANGLE システム変数
      • EXPINSFIXANGLE システム変数
      • EXPINSFIXSCALE system variable
      • EXPINSSCALE システム変数
      • EXPLMODE システム変数
      • EXPORTACISFORMATVERSION system variable
      • EXPORTMODELSPACE system variable
      • EXPORTPAGESETUP システム変数
      • EXPORTPAPERSPACE システム変数
      • EXTMAX system variable
      • EXTMIN システム変数
      • EXTNAMES system variable
    • F
      • FACETRATIO system variable
      • FACETRES system variable
      • FBXEXPORTCAMERAS system variable
      • FBXEXPORTENTITIES システム変数
      • FBXEXPORTENTITIESSELTYPE system variable
      • FBXEXPORTLIGHTS システム変数
      • FBXEXPORTMATERIALS システム変数
      • FBXEXPORTTEXTURES システム変数
      • FBXEXPORTTEXTURESPATH system variable
      • FEATURECOLORS system variable
      • FIELDDISPLAY system variable
      • FIELDEVAL システム変数
      • FILEDIA system variable
      • FILLETRAD システム変数
      • FILLMODE システム変数
      • FLOORTOFLOORDISTANCE system variable
      • FONTALT システム変数
      • FONTMAP system variable
      • FRAME system variable
      • FRAMESELECTION システム変数
      • FRONTZ system variable
      • FULLOPEN system variable
    • G
      • GENERATEASSOCATTRS システム変数
      • GENERATEASSOCVIEWS システム変数
      • GEOLATLONGFORMAT システム変数
      • GEOMARKERVISIBILITY system variable
      • GEOMRELATIONS システム変数
      • GETSTARTED system variable
      • GFANG system variable
      • GFCLR1 システム変数
      • GFCLR2 システム変数
      • GFCLRLUM システム変数
      • GFCLRSTATE system variable
      • GFNAME system variable
      • GFSHIFT システム変数
      • GLSWAPMODE システム変数
      • GRADIENTCOLORBOTTOM システム変数
      • GRADIENTCOLORMIDDLE system variable
      • GRADIENTCOLORTOP システム変数
      • GRADIENTMODE システム変数
      • GRIDAXISCOLOR システム変数
      • GRIDDISPLAY システム変数
      • GRIDMAJOR system variable
      • GRIDMAJORCOLOR system variable
      • GRIDMINORCOLOR システム変数
      • GRIDMODE システム変数
      • GRIDSTYLE システム変数
      • GRIDUNIT システム変数
      • GRIDXYZTINT system variable
      • GRIPBLOCK システム変数
      • GRIPCOLOR システム変数
      • GRIPDYNCOLOR system variable
      • GRIPHOT システム変数
      • GRIPHOVER システム変数
      • GRIPOBJLIMIT system variable
      • GRIPS システム変数
      • GRIPSIZE システム変数
      • GRIPTIPS system variable
      • GSDEVICETYPE2D system variable
      • GSDEVICETYPE3D system variable
    • H
      • HALOGAP システム変数
      • HANDLES システム変数
      • HANDSEED system variable
      • HIDEPRECISION system variable
      • HIDESYSTEMPRINTERS システム変数
      • HIDETEXT システム変数
      • HIDEXREFSCALES system variable
      • HIGHLIGHT system variable
      • HIGHLIGHTCOLOR システム変数
      • HIGHLIGHTEFFECT system variable
      • HORIZONBKG_ENABLE システム変数
      • HORIZONBKG_GROUNDHORIZON system variable
      • HORIZONBKG_GROUNDORIGIN システム変数
      • HORIZONBKG_SKYHIGH system variable
      • HORIZONBKG_SKYHORIZON システム変数
      • HORIZONBKG_SKYLOW システム変数
      • HOTKEYASSISTANT システム変数
      • HPANG system variable
      • HPANNOTATIVE system variable
      • HPASSOC システム変数
      • HPBACKGROUNDCOLOR システム変数
      • HPBOUND システム変数
      • HPBOUNDRETAIN システム変数
      • HPCOLOR system variable
      • HPDOUBLE システム変数
      • HPDRAWORDER システム変数
      • HPGAPTOL システム変数
      • HPISLANDDETECTION システム変数
      • HPLAYER システム変数
      • HPLINETYPE システム変数
      • HPMAXAREAS system variable
      • HPNAME システム変数
      • HPOBJWARNING system variable
      • HPORIGIN システム変数
      • HPSCALE system variable
      • HPSEPARATE システム変数
      • HPSPACE system variable
      • HPTRANSPARENCY system variable
      • HYPERLINKBASE システム変数
    • I
      • IMAGECACHEFOLDER システム変数
      • IMAGECACHEMAXMEMORY system variable
      • IMAGEDISKCACHE システム変数
      • IMAGEFRAME system variable
      • IMAGEHLT システム変数
      • IMAGENOTIFY system variable
      • IMPORTCUIFILEEXISTS system variable
      • IMPORTPRODUCTSTRUCTURE system variable
      • IMPORTREPAIR system variable
      • INCLUDEPLOTSTAMP システム変数
      • INDEXCTLシステム変数
      • INETLOCATION システム変数
      • INSBASE システム変数
      • INSNAME system variable
      • INSUNITS system variable
      • INSUNITSDEFSOURCE システム変数
      • INSUNITSDEFTARGET システム変数
      • INSUNITSSCALING システム変数
      • INTERFERECOLOR システム変数
      • INTERFERELAYER system variable
      • INTERFEREOBJVS システム変数
      • INTERFEREVPVS system variable
      • INTERSECTIONCOLOR system variable
      • INTERSECTIONDISPLAY system variable
      • ISAVEBAK system variable
      • ISAVEPERCENT system variable
      • ISOLINESシステム変数
    • J
    • K
    • L
      • LASTANGLE system variable
      • LASTPOINT system variable
      • LASTPROMPT システム変数
      • LATITUDE システム変数
      • LAYERFILTEREXCESS system variable
      • LAYERPMODE システム変数
      • LAYLOCKFADECTL システム変数
      • LAYOUTREGENCTL system variable
      • LAYOUTTAB system variable
      • LEGACYCODESEARCH システム変数
      • LENGTHUNITS システム変数
      • LENSLENGTH system variable
      • LEVELOFDETAIL system variable
      • LICFLAGS システム変数
      • LIGHTGLYPHCOLOR システム変数
      • LIGHTGLYPHDISPLAY システム変数
      • LIGHTINGUNITS システム変数
      • LIGHTWEBGLYPHCOLOR system variable
      • LIMCHECK システム変数
      • LIMMAX system variable
      • LIMMIN system variable
      • LINEARBRIGHTNESS システム変数
      • LINEARCONTRAST system variable
      • LISPINIT system variable
      • LOADMECHANICAL2D システム変数
      • LOCALE system variable
      • LOCALROOTPREFIX システム変数
      • LOCKUI system variable
      • LOFTANG1 system variable
      • LOFTANG2 システム変数
      • LOFTMAG1 システム変数
      • LOFTMAG2 システム変数
      • LOFTNORMALS システム変数
      • LOFTPARAM システム変数
      • LOGFILEMODE システム変数
      • LOGFILENAME system variable
      • LOGFILEPATH システム変数
      • LOGGEDIN システム変数
      • LOGINNAME system variable
      • LONGITUDE システム変数
      • LOOKFROMDIRECTIONMODE システム変数
      • LOOKFROMFEEDBACK system variable
      • LOOKFROMZOOMXTENTS システム変数
      • LTGAPSELECTION system variable
      • LTSCALE システム変数
      • LUNITS system variable
      • LUPREC システム変数
      • LWDEFAULT system variable
      • LWDISPLAY システム変数
      • LWDISPSCALE system variable
      • LWUNITS system variable
    • M
      • MACROREC system variable
      • MACROTRACE システム変数
      • MAKEBAK システム変数
      • MANIPULATOR システム変数
      • MANIPULATORCOLORTHEME system variable
      • MANIPULATORDURATION システム変数
      • MANIPULATORHANDLE system variable
      • MANIPULATORSIZE システム変数
      • MASSPREC システム変数
      • MASSPROPACCURACY システム変数
      • MASSUNITS システム変数
      • MAXACTVP システム変数
      • MAXHATCH システム変数
      • MAXSORTシステム変数
      • MAXTHREADS system variable
      • MBSTATE システム変数
      • MBUTTONPAN system variable
      • MEASUREINIT システム変数
      • MEASUREMENT system variable
      • MECH2DSAVEFORMAT システム変数
      • MENUBAR (EXCEPT OS X) システム変数
      • MENUCTL system variable
      • MENUECHO system variable
      • MENUNAME システム変数
      • MESHTYPE システム変数
      • MIDDLECLICKCLOSE システム変数
      • MILLISECS system variable
      • MIRRTEXT system variable
      • MLEADERSCALE システム変数
      • MODEMACRO system variable
      • MSLTSCALE system variable
      • MSOLESCALE システム変数
      • MTEXTCOLUMN system variable
      • MTEXTDETECTSPACE システム変数
      • MTEXTED system variable
      • MTEXTFIXED system variable
      • MTEXTTOOLBAR システム変数
      • MTFLAGS システム変数
      • MYDOCUMENTSFOLDER システム変数
      • MYDOCUMENTSPREFIX system variable
      • MECHANICALBROWSERSETTINGS system variable
    • N
      • NAVVCUBEDISPLAY システム変数
      • NAVVCUBELOCATION システム変数
      • NAVVCUBEOPACITY システム変数
      • NAVVCUBEORIENT system variable
      • NAVVCUBESIZE システム変数
      • NEARESTDISTANCE システム変数
      • NOMUTT system variable
      • NORTHDIRECTION システム変数
    • O
      • OBJECTISOLATIONMODE system variable
      • OBSCUREDCOLOR システム変数
      • OBSCUREDLTYPE システム変数
      • OFFSETDIST system variable
      • OFFSETERASE システム変数
      • OFFSETGAPTYPE system variable
      • OLEFRAME システム変数
      • OLEHIDE システム変数
      • OLEQUALITY システム変数
      • OLESTARTUP system variable
      • OPMSTATE system variable
      • ORBITAUTOTARGET system variable
      • ORTHOMODE システム変数
      • OSMODE システム変数
      • OSNAPCOORD system variable
      • OSNAPZ システム変数
      • OSOPTIONS システム変数
      • OVERKILLLAYER システム変数
    • P
      • PANBUFFER system variable
      • PANELBUTTONSIZE system variable
      • PAPERUPDATE システム変数
      • PARAMETERCOPYMODE system variable
      • PARAMETRICBLOCKS2DPATH システム変数
      • PDFCACHE システム変数
      • PDFEMBEDDEDTTF system variable
      • PDFEXPORTHYPERLINKS システム変数
      • PDFEXPORTSOLIDHATCHTYPE システム変数
      • PDFFRAME system variable
      • PDFHATCHTOBMPDPI システム変数
      • PDFIMAGEANTIALIAS system variable
      • PDFIMAGECOMPRESSION システム変数
      • PDFIMAGEDPI system variable
      • PDFIMPORTAPPLYLINEWEIGHT システム変数
      • PDFIMPORTASBLOCK システム変数
      • PDFIMPORTCONVERTSOLIDSTOHATCHES システム変数
      • PDFIMPORTIMAGEPATH システム変数
      • PDFIMPORTJOINLINEANDARCSEGMENTS system variable
      • PDFIMPORTLAYERSUSETYPE system variable
      • PDFIMPORTRASTERIMAGES system variable
      • PDFIMPORTSOLIDFILLS system variable
      • PDFIMPORTTRUETYPETEXT システム変数
      • PDFIMPORTTRUETYPETEXTASGEOMETRY システム変数
      • PDFIMPORTUSEGEOMETRYOPTIMIZATION system variable
      • PDFIMPORTVECTORGEOMETRY システム変数
      • PDFLAYERSSETTING system variable
      • PDFLAYOUTSTOEXPORT system variable
      • PDFMERGECONTROL システム変数
      • PDFNOTIFY system variable
      • PDFOSNAP system variable
      • PDFPAPERHEIGHT システム変数
      • PDFPAPERSIZEOVERRIDE system variable
      • PDFPAPERWIDTH システム変数
      • PDFPRCCOMPRESSION system variable
      • PDFPRCEXPORT system variable
      • PDFPRCEXPORTPRODUCTSTRUCTUREMODE システム変数
      • PDFPRCSINGLEVIEWMODE system variable
      • PDFRENDERDPI system variable
      • PDFSHXTEXTASGEOMETRY システム変数
      • PDFSIMPLEGEOMOPTIMIZATION システム変数
      • PDFTTFTEXTASGEOMETRY system variable
      • PDFUSEPLOTSTYLES system variable
      • PDFVECTORRESOLUTIONDPI system variable
      • PDFZOOMTOEXTENTSMODE system variable
      • PDMODE system variable
      • PDSIZE system variable
      • PEDITACCEPT システム変数
      • PELLIPSE system variable
      • PERIMETER システム変数
      • PERSPECTIVE system variable
      • PFACEVMAX system variable
      • PHANDLE システム変数
      • PICKADD システム変数
      • PICKAUTO システム変数
      • PICKBOX システム変数
      • PICKDRAG システム変数
      • PICKFIRST system variable
      • PICKSTYLE (EXCEPT OS X) system variable
      • PICTUREEXPORTSCALE system variable
      • PLACESBARFOLDER1 システム変数
      • PLACESBARFOLDER2 system variable
      • PLACESBARFOLDER3 システム変数
      • PLACESBARFOLDER4 system variable
      • PLATFORMシステム変数
      • PLINECACHE system variable
      • PLINECONVERTMODE system variable
      • PLINEGENシステム変数
      • PLINETYPE システム変数
      • PLINEWID システム変数
      • PLOTCFGPATH system variable
      • PLOTID システム変数
      • PLOTOUTPUTPATH システム変数
      • PLOTROTMODE system variable
      • PLOTSTYLEPATH システム変数
      • PLOTTER システム変数
      • PLOTTRANSPARENCYOVERRIDE システム変数
      • PLQUIET システム変数
      • POINTCLOUD2DVSDISPLAY system variable
      • POINTCLOUDADAPTIVEDISPLAY システム変数
      • POINTCLOUDBOUNDARY system variable
      • POINTCLOUDCACHEFOLDER system variable
      • POINTCLOUDCACHESIZE システム変数
      • POINTCLOUDPOINTMAX システム変数
      • POINTCLOUDPOINTSIZE システム変数
      • POLARADDANG システム変数
      • POLARANG システム変数
      • POLARDIST システム変数
      • POLARMODE system variable
      • POLYSIDES system variable
      • POPUPS システム変数
      • PREVIEW_HEIGHT system variable
      • PREVIEW_WIDTH system variable
      • PREVIEWDELAY system variable
      • PREVIEWEFFECT システム変数
      • PREVIEWFILTER システム変数
      • PREVIEWTYPE システム変数
      • PREVIEWWNDINOPENDLG システム変数
      • PRINTFILE system variable
      • PRINTPDFPREVIEW system variable
      • PRODUCT システム変数
      • PROGBAR システム変数
      • PROGRAM システム変数
      • PROJECTIONTYPE system variable
      • PROJECTNAME システム変数
      • PROJECTSEARCHPATHS システム変数
      • PROJMODE system variable
      • PROMPTMENU システム変数
      • PROMPTMENUFLAGS システム変数
      • PROMPTOPTIONFORMAT system variable
      • PROMPTOPTIONTRANSLATEKEYWORDS system variable
      • PROPERTYPREVIEW system variable
      • PROPERTYPREVIEWDELAY システム変数
      • PROPERTYPREVIEWOBJLIMIT system variable
      • PROPPREVTIMEOUT システム変数
      • PROPUNITS システム変数
      • PROXYGRAPHICS system variable
      • PROXYNOTICE system variable
      • PROXYSHOW システム変数
      • PROXYWEBSEARCH system variable
      • PSLTSCALE system variable
      • PSOLHEIGHT システム変数
      • PSOLWIDTH システム変数
      • PSPROLOG system variable
      • PSQUALITY システム変数
      • PSTYLEMODE システム変数
      • PSTYLEPOLICY システム変数
      • PSVPSCALE システム変数
      • PUBLISHALLSHEETS システム変数
      • PUCSBASE system variable
    • Q
      • QAFLAGS システム変数
      • QTEXTMODE システム変数
      • QUADCOMMANDLAUNCH system variable
      • QUADDISPLAY システム変数
      • QUADEXPANDDELAY システム変数
      • QUADEXPANDTABDELAY system variable
      • QUADGOTRANSPARENT システム変数
      • QUADHIDEDELAY system variable
      • QUADHIDEMARGIN システム変数
      • QUADICONSIZE system variable
      • QUADICONSPACE システム変数
      • QUADMOSTRECENTITEMS system variable
      • QUADPOPUPCORNER システム変数
      • QUADROLLOVERDELAY system variable
      • QUADSHOWDELAY system variable
      • QUADWIDTH system variable
    • R
      • R12SAVEACCURACY system variable
      • R12SAVEDEVIATION システム変数
      • RASTERPREVIEW system variable
      • RE_INIT システム変数
      • REALTIMESPEEDUP system variable
      • REALWORLDSCALE システム変数
      • RECENTFILES システム変数
      • RECENTPATH system variable
      • REDHILITE_DUCSLOCKED_FACE_ALPHA system variable
      • REDHILITE_DUCSLOCKED_FACE_COLOR system variable
      • REDHILITE_HIDDENEDGE_ALPHA システム変数
      • REDHILITE_HIDDENEDGE_COLOR システム変数
      • REDHILITEFULL_EDGE_ALPHA システム変数
      • REDHILITEFULL_EDGE_COLOR system variable
      • REDHILITEFULL_EDGE_SHOWHIDDEN システム変数
      • REDHILITEFULL_EDGE_SMOOTHING システム変数
      • REDHILITEFULL_EDGE_THICKNESS システム変数
      • REDHILITEFULL_FACE_ALPHA system variable
      • REDHILITEFULL_FACE_COLOR システム変数
      • REDHILITEPARTIAL_SELECTEDEDGE_ALPHA system variable
      • REDHILITEPARTIAL_SELECTEDEDGE_COLOR システム変数
      • REDHILITEPARTIAL_SELECTEDEDGE_SHOWGLOW システム変数
      • REDHILITEPARTIAL_SELECTEDEDGE_SMOOTHING システム変数
      • REDHILITEPARTIAL_SELECTEDEDGE_THICKNESS システム変数
      • REDHILITEPARTIAL_SELECTEDEDGEGLOW_ALPHA システム変数
      • REDHILITEPARTIAL_SELECTEDEDGEGLOW_COLOR システム変数
      • REDHILITEPARTIAL_SELECTEDEDGEGLOW_SMOOTHING システム変数
      • REDHILITEPARTIAL_SELECTEDEDGEGLOW_THICKNESS system variable
      • REDHILITEPARTIAL_SELECTEDFACE_ALPHA system variable
      • REDHILITEPARTIAL_SELECTEDFACE_COLOR システム変数
      • REDHILITEPARTIAL_UNSELECTEDEDGE_SHOWHIDDEN システム変数
      • REDSDKLINESMOOTHING システム変数
      • REFEDITLOCKNOTINWORKSET system variable
      • REFEDITNAME system variable
      • REGENMODE システム変数
      • REGEXPAND system variable
      • REMEMBERFOLDERS system variable
      • RENDERCOMPOSITIONMATERIAL system variable
      • RENDERMATERIALDOWNLOAD system variable
      • RENDERMATERIALSPATH システム変数
      • RENDERUSINGHARDWARE system variable
      • REPORTPANELMODE system variable
      • REPOSITORYFOLDER system variable
      • RESTORELOSTFOCUS システム変数
      • RETINADISPLAY システム変数
      • REVCLOUDARCSTYLE システム変数
      • REVCLOUDCREATEMODE システム変数
      • REVCLOUDGRIPS system variable
      • REVCLOUDMAXARCLENGTH システム変数
      • REVCLOUDMINARCLENGTH システム変数
      • RHINOVERSION システム変数
      • RIBBONDOCKEDHEIGHT system variable
      • RIBBONPANELMARGIN system variable
      • RIBBONSTATE system variable
      • RIBBONTOOLSIZE system variable
      • ROAMABLEROOTFOLDER システム変数
      • ROAMABLEROOTPREFIX システム変数
      • ROLLOVEROPACITY システム変数
      • ROLLOVERSELECTIONSET system variable
      • ROLLOVERTIPS システム変数
      • RTDISPLAY system variable
      • RTROTATIONSPEEDFACTOR system variable
      • RUBBERBANDCOLOR system variable
      • RUBBERBANDSTYLE system variable
      • RUBBERSHEET (for OS X) system variable
      • RUBBERSHEETSENSIBILITY (FOR OS X) システム変数
      • RUNASLEVEL system variable
    • S
      • SAFEMODE system variable
      • SAVECHANGETOLAYOUT system variable
      • SAVEFIDELITY システム変数
      • SAVEFILE システム変数
      • SAVEFILEPATH system variable
      • SAVEFORMAT システム変数
      • SAVELAYERSNAPSHOT システム変数
      • SAVENAME システム変数
      • SAVEONDOCSWITCH system variable
      • SAVEROUNDTRIP system variable
      • SAVETIME システム変数
      • SCREENBOXES system variable
      • SCREENMODE システム変数
      • SCREENSIZE システム変数
      • SCRLHIST システム変数
      • SDI system variable
      • SECURELOAD system variable
      • SECTIONSETTINGSSEARCHPATH system variable
      • SELECTIONANNODISPLAY system variable
      • SELECTIONAREA システム変数
      • SELECTIONAREAOPACITY system variable
      • SELECTIONMODES system variable
      • SELECTIONPREVIEW system variable
      • SELECTSIMILARMODE システム変数
      • SETBYLAYERMODE system variable
      • SHADEDGE system variable
      • SHADEDIF system variable
      • SHEETNUMBERLEADINGZEROES system variable
      • SHEETSETAUTOBACKUP システム変数
      • SHEETSETTEMPLATEPATH システム変数
      • SHORTCUTMENU システム変数
      • SHORTCUTMENUDURATION system variable
      • SHOWDOCTABS system variable
      • SHOWFULLPATHINTITLE システム変数
      • SHOWLAYERUSAGE システム変数
      • SHOWSCROLLBUTTONS system variable
      • SHOWTABCLOSEBUTTON システム変数
      • SHOWTABCLOSEBUTTONACTIVE system variable
      • SHOWTABCLOSEBUTTONALL システム変数
      • SHOWWINDOWLISTBUTTON システム変数
      • SHPNAME system variable
      • SINGLETONMODE システム変数
      • SKETCHINC system variable
      • SKPOLY システム変数
      • SKYSTATUS system variable
      • SLABTHICKNESS system variable
      • SMASSEMBLYEXPORTMODE システム変数
      • SMASSEMBLYEXPORTREPORTPATHTYPE system variable
      • SMASSEMBLYEXPORTSOLIDTYPESINREPORTS system variable
      • SMATTRIBUTESLAYERCOLOR system variable
      • SMATTRIBUTESLAYERTEXTHEIGHT system variable
      • SMATTRIBUTESLAYERTEXTHEIGHTTYPE system variable
      • SMBENDANNOTATIONSLAYERCOLOR system variable
      • SMBENDANNOTATIONSLAYERTEXTHEIGHT system variable
      • SMBENDANNOTATIONSLAYERTEXTHEIGHTTYPE system variable
      • SMBENDLINESUPLAYERCOLOR system variable
      • SMBENDLINESUPLAYERLINETYPE system variable
      • SMBENDLINESUPLAYERLINEWEIGHT system variable
      • SMBENDLINESDOWNLAYERCOLOR system variable
      • SMBENDLINESDOWNLAYERLINETYPE system variable
      • SMBENDLINESDOWNLAYERLINEWEIGHT system variable
      • SMCOLORBEND system variable
      • SMCOLORBENDRELIEF system variable
      • SMCOLORBEVEL system variable
      • SMCOLORCORNERRELIEF system variable
      • SMCONTOURSLAYERLINETYPE system variable
      • SMCONTOURSLAYERLINEWEIGHT system variable
      • SMCONTOURSLAYERCOLOR system variable
      • SMCONVERTMAXIMALBEVELANGLE system variable
      • SMCONVERTMINIMALBEVELANGLE system variable
      • SMCONVERTPREFERFORMFEATURES system variable
      • SMCONVERTPREFERHEMFEATURES system variable
      • SMCONVERTPREFERZEROBENDFEATURES system variable
      • SMCONVERTRECOGNIZEHOLES system variable
      • SMCONVERTRECOGNIZERIBCONTROLCURVES system variable
      • SMCONVERTWRONGFEATURETHICKNESSDEVIATIONTYPE system variable
      • SMCONVERTWRONGFEATURETHICKNESSDEVIATIONVALUE system variable
      • SMDEFAULTKFACTOR system variable
      • SMDEFAULTHEMRELATIVEBENDDEDUCTION system variable
      • SMDEFAULTFORMFEATUREUNFOLDMODE system variable
      • SMDEFAULTBENDLINEEXTENTTYPE system variable
      • SMDEFAULTBENDLINEEXTENTVALUE system variable
      • SMDEFAULTBEVELFEATUREUNFOLDMODE system variable
      • SMEXPORTOSMAPPROXIMATIONACCURACY system variable
      • SMEXPORTOSMMINIMALEDGELENGTH system variable
      • SMFORMFEATURESUPCOLOR system variable
      • SMFORMFEATURESUPLAYERLINETYPE system variable
      • SMFORMFEATURESDOWNCOLOR system variable
      • SMFORMFEATURESUPLAYERLINEWEIGHT system variable
      • SMFORMFEATURESDOWNLAYERLINETYPE system variable
      • SMFORMFEATURESDOWNLAYERLINEWEIGHT system variable
      • SMJUNCTIONCREATEHEALCOINCIDENT system variable
      • SMOOTHMESHCONVERT システム変数
      • SMPARAMETRIZEHOLESPARAMETRIZATION system variable
      • SMREPAIRLOFTEDBENDMERGE system variable
      • SMSMARTFEATURES システム変数
      • SMSPLITAMBIGUOUSINPUT system variable
      • SMSPLITCONVERTBENDTOJUNCTION system variable
      • SMSPLITHEALCOINCIDENT system variable
      • SMSPLITORTHOGONALBENDSPLIT system variable
      • SMTARGETCAM system variable
      • SMOVERALLANNOTATIONSLAYERCOLOR system variable
      • SMOVERALLANNOTATIONSLAYERLINETYPE system variable
      • SMOVERALLANNOTATIONSLAYERLINEWEIGHT system variable
      • SMBEVELFEATURECOLOR system variable
      • SNAPANG system variable
      • SNAPBASE システム変数
      • SNAPCOLOR システム変数
      • SNAPISOPAIR system variable
      • SNAPMARKERCOLOR system variable
      • SNAPMARKERSIZE システム変数
      • SNAPMARKERTHICKNESS システム変数
      • SNAPMODE システム変数
      • SNAPSIZE システム変数
      • SNAPSTYL system variable
      • SNAPTHICKNESS システム変数
      • SNAPTYPE システム変数
      • SNAPUNIT system variable
      • SOLIDCHECK システム変数
      • SORTENTS システム変数
      • SPAADJUSTMODE システム変数
      • SPACHECKLEVEL システム変数
      • SPAGRIDASPECTRATIO システム変数
      • SPAGRIDMODE system variable
      • SPAMAXFACETEDGELENGTH system variable
      • SPAMAXNUMGRIDLINES system variable
      • SPAMINUGRIDLINES システム変数
      • SPAMINVGRIDLINES システム変数
      • SPANORMALTOL system variable
      • SPASURFACETOL system variable
      • SPATRIANGMODE system variable
      • SPAUSEFACETRES system variable
      • SPLFRAME system variable
      • SPLINESEGS system variable
      • SPLINETYPE system variable
      • SRCHPATH システム変数
      • SSFOUND システム変数
      • SSLOCATE システム変数
      • SSMAUTOOPEN system variable
      • SSMPOLLTIME システム変数
      • SSMSHEETSTATUS システム変数
      • SSMSTATE システム変数
      • STACKPANELTYPE システム変数
      • STAMPFONTSIZE system variable
      • STAMPFONTSTYLE system variable
      • STAMPFOOTER システム変数
      • STAMPFOOTEROFFSETX system variable
      • STAMPFOOTEROFFSETY システム変数
      • STAMPHEADER system variable
      • STAMPHEADEROFFSETX システム変数
      • STAMPHEADEROFFSETY system variable
      • STAMPUNITS システム変数
      • STARTUP システム変数
      • STARTUPTODAY システム変数
      • STATUSBAR システム変数
      • STEPSIZEシステム変数
      • STEPSPERSECシステム変数
      • STLPOSITIVEQUADRANT システム変数
      • STRUCTUREDISPLAYMODE システム変数
      • STRUCTURETREECONFIG system variable
      • SURFTAB1 system variable
      • SURFTAB2 システム変数
      • SURFTYPE システム変数
      • SURFU システム変数
      • SURFV system variable
      • SVGBLENDEDGRADIENTS システム変数
      • SVGDEFAULTIMAGEEXTENSION システム変数
      • SVGGENERICFONTFAMILY system variable
      • SVGIMAGEBASE system variable
      • SVGIMAGEURL system variable
      • SVGLINEWEIGHTSCALE system variable
      • SVGOUTPUTHEIGHT system variable
      • SVGOUTPUTWIDTH システム変数
      • SVGPRECISION system variable
      • SVGSCALEFACTOR system variable
      • SYSCODEPAGE システム変数
    • T
      • TABCONTROLHEIGHT system variable
      • TABMODE システム変数
      • TABSFIXEDWIDTH system variable
      • TARGET システム変数
      • TDCREATE system variable
      • TDINDWG システム変数
      • TDUCREATE system variable
      • TDUPDATE システム変数
      • TDUSRTIMER system variable
      • TDUUPDATE システム変数
      • TEMPLATEPATH システム変数
      • TEMPPREFIX system variable
      • TEXTANGLE システム変数
      • TEXTED システム変数
      • TEXTEDITMODE システム変数
      • TEXTEVAL system variable
      • TEXTFILL システム変数
      • TEXTQLTY システム変数
      • TEXTSIZE system variable
      • TEXTSTYLE system variable
      • TEXTUREMAPPATH システム変数
      • THICKNESS システム変数
      • THUMBSIZE system variable
      • TILEMODE system variable
      • TILEMODELIGHTSYNCH system variable
      • TIMEZONE system variable
      • TOOLBARMARGIN システム変数
      • TOOLBUTTONSIZE システム変数
      • TOOLICONPADDING システム変数
      • TOOLPALETTEPATH system variable
      • TOOLTIPDELAY システム変数
      • TOOLTIPS システム変数
      • TPSTATE システム変数
      • TRACEWID システム変数
      • TRACKPATH system variable
      • TRANSPARENCYDISPLAY system variable
      • TRAYICONS システム変数
      • TRAYNOTIFY システム変数
      • TRAYTIMEOUT システム変数
      • TREEDEPTH system variable
      • TREEMAX システム変数
      • TRIMMODE system variable
      • TRUSTEDPATHS system variable
      • TSPACEFAC system variable
      • TSPACETYPE システム変数
      • TSTACKALIGN システム変数
      • TSTACKSIZE システム変数
      • TTFASTEXT システム変数
    • U
      • UCSAXISANG system variable
      • UCSBASE system variable
      • UCSDETECT システム変数
      • UCSFOLLOW system variable
      • UCSICON system variable
      • UCSICONPOS システム変数
      • UCSNAME システム変数
      • UCSORG system variable
      • UCSORTHO システム変数
      • UCSVIEW システム変数
      • UCSVP system variable
      • UCSXDIR system variable
      • UCSYDIR システム変数
      • UNDOCTL system variable
      • UNDOMARKS システム変数
      • UNITMODE system variable
      • USECOMMUNICATOR システム変数
      • USERI1 システム変数
      • USERI2 システム変数
      • USERI3 システム変数
      • USERI4 system variable
      • USERI5 system variable
      • USERR1 system variable
      • USERR2 system variable
      • USERR3 システム変数
      • USERR4 システム変数
      • USERR5 システム変数
      • USERS1 system variable
      • USERS2 システム変数
      • USERS3 システム変数
      • USERS4 システム変数
      • USERS5 system variable
      • USESTANDARDOPENFILEDIALOG system variable
      • USRTIMER system variable
    • V
      • VBAMACROS system variable
      • VENDORNAME システム変数
      • VERSIONCONTROLPATH system variable
      • VERSIONCUSTOMIZABLEFILES システム変数
      • VIEWCTR システム変数
      • VIEWDIR システム変数
      • VIEWMODE system variable
      • VIEWSIZE system variable
      • VIEWTWIST システム変数
      • VIEWUPDATEAUTO system variable
      • VISRETAIN システム変数
      • VOLUMEPREC システム変数
      • VOLUMEUNITS システム変数
      • VPMAXIMIZEDSTATE システム変数
      • VPROTATEASSOC system variable
      • VSMAX system variable
      • VSMIN system variable
      • VTDURATION システム変数
      • VTENABLE システム変数
      • VTFPS システム変数
    • W
      • WALLWIDTH system variable
      • WARNINGMESSAGES system variable
      • WHIPARC system variable
      • WHIPTHREAD system variable
      • WINDOWAREACOLOR システム変数
      • WIPEOUTFRAME システム変数
      • WMFBKGND システム変数
      • WMFFOREGND system variable
      • WNDLMAIN システム変数
      • WNDLSCRL system variable
      • WNDLTEXT システム変数
      • WNDPMAIN system variable
      • WNDPTEXT システム変数
      • WNDSMAIN システム変数
      • WNDSTEXT システム変数
      • WORLDUCS システム変数
      • WORLDVIEW システム変数
      • WRITESTAT システム変数
      • WSAUTOSAVE システム変数
      • WSCURRENT システム変数
    • X
      • XCLIPFRAME system variable
      • XDWGFADECTL システム変数
      • XEDIT system variable
      • XFADECTL システム変数
      • XLOADCTL システム変数
      • XLOADPATH system variable
      • XNOTIFYTIME システム変数
      • XREFCTL システム変数
      • XREFNOTIFY システム変数
      • XREFOVERRIDE system variable
    • Y
    • Z
      • ZOOMFACTOR システム変数
      • ZOOMWHEEL システム変数
Add scale dialog box
The Add Scale dialog box allows you to add a new scale factor to the list.
  1. Scale name
  2. Scale properties
Scale name
Specifies the scale name as it will appear in the scale list.
Scale properties
Specifies the scale factor in paper (size when plotted) and drawing units.
Parent topic: Dialog boxes
Related commands
  • PAGESETUP command
  • PRINT command
© 2025 Bricsys NV. All rights reserved.Privacy statement -Terms of use -Cookie statement
