account
translation
Bricsys Help Center
New Multileader Style dialog box
  • BricsCAD
    • What's new in BricsCAD V21
      • Overview
      • User interface
      • Productivity
      • Drafting
      • Modeling
      • Civil tools
      • Performance and compatibility
    • Installation and licensing
      • Installing BricsCAD
        • Minimum system requirements and recommendations
        • Downloading BricsCAD
        • Overview of install options
          • Interactive installation
          • Silent Installation (Windows only)
        • Trial mode
      • Activating and licensing BricsCAD
        • Overview of licensing options
          • License levels
          • License types
          • Additional license options
        • BricsCAD and AutoCAD feature comparison
        • Trial: online activation
        • Trial: offline (manual) activation
        • Single or volume license: online activation
        • Single or volume license: offline (manual) activation
        • Using a network license on a client computer
      • Setting up a network license server
        • Network license server
        • Quick guide on using a network license
        • Setting up a Windows network license server
        • Setting up a Linux license server
        • Network license: online activation
        • Network license: offline (manual) activation
        • Network license server administration
        • Advanced configurations
      • Managing licenses
        • Modifying a BricsCAD license
        • Deactivating or revoking a BricsCAD license
        • Migrating a single or volume license to another computer
        • Migrating a network license to another server
        • License pooling
        • Network license usage report
        • Roaming
          • Roaming a network license on a client computer
          • Returning a roamed network license to the server
        • Proxy settings on a client computer
    • Getting started with BricsCAD
      • Launching BricsCAD
      • Exploring the interface
        • The Start tab
        • Document tabs
        • Choosing the workspace
        • The drawing area
        • The Command line
        • メニュー
        • Toolbars
        • The ribbon
        • The Quad basics
        • Right-click menus
        • The status bar
        • Panels
        • The clean screen mode
        • Look From widget
      • Working in BricsCAD
        • Creating a drawing
        • Template drawings
        • Entity creation settings
        • How to draw accurately
        • Executing commands
        • View control
        • Selecting entities
        • Using the Manipulator
        • Working with the Structure panel
    • User interface
      • The BricsCAD application window
      • The Command line
      • The Status bar
      • Document tabs
      • Toolbars
      • The Quad cursor menu
      • Rollover tips
      • Prompt menus
      • Keyboard shortcuts
      • Digitizing tablet
      • Panels
        • Animation editor panel
        • Attachments panel
        • BIM BCF panel
        • BIM compositions panel
        • BIM profiles panel
        • BIM project browser panel
        • BOM manager panel
        • Bricsys 24/7 panel
        • Command line panel
        • Content browser panel
        • Details panel
        • Drawing customizations panel
        • Layers panel
        • Library panel
        • Mechanical browser panel
        • Parameters and constraints panel
        • Properties panel
        • Render materials panel
        • Report panel
        • Sheet sets panel
        • Structure panel
        • Tips panel
        • Tool palettes panel
      • Dialog boxes
        • About BricsCAD dialog box
        • Add block to library dialog box
        • Add button item dialog box
        • Add menu item dialog box
        • Add-in manager dialog box
        • Add plot style table dialog box
        • Add scale dialog box
        • Allowed deviations from center axis dialog box
        • Annotation Object Scale dialog box
        • Array dialog box
        • Attach external reference
        • Attach PDF underlay dialog box
        • Attach raster image dialog box
        • Attribute editor dialog box
        • Auto Match dialog box
        • Background dialog box
        • BIM BCF panel - Custom login dialog box
        • BIM project info dialog box
        • BIM properties dialog box
        • Bimify dialog box
        • Blade - BricsCAD LISP advanced development environment dialog box
        • Block attribute manager dialog box
        • Block definition dialog box
        • Boundary dialog box
        • Bricsys license manager dialog box
        • Calculator dialog box
        • Change dictionaries dialog box
        • Change Icon dialog box
        • Choose window style dialog box
        • Column filter dialog box
        • Combine Duplicate Block Definitions dialog box
        • Communicator info dialog box
        • Component Tool Properties
        • Compositions dialog box
        • Configure Settings dialog box
        • Configure structure tree dialog box
        • Confirm deleting selected cache items
        • Create detail dialog box
        • Create new drawing dialog box
        • Create new sheet set dialog box
        • Create or edit block definition dialog box
        • Create Schedule dialog box
        • Create section/elevation dialog box
        • Current Plot Style dialog box
        • Customization groups dialog box
        • Customize dialog box
        • Customize (Tool Palettes) dialog box
        • Custom paper sizes dialog box
        • Custom properties dialog box
        • DataLink edit dialog box
        • Datalink manager dialog box
        • Default scale list dialog box
        • Define attribute dialog box
        • Delete duplicate entities dialog box
        • Drawing explorer dialog box
        • Drawing explorer options dialog box
        • Drawing properties
        • Drawing view presets dialog box
        • Edit attributes dialog box
        • Edit custom properties dialog box
        • Edit hyperlink dialog box
        • Edit scale dialog box
        • Edit scale list dialog box
        • Entity grouping dialog box
        • eTransmit dialog box
        • Extract attributes dialog box
        • Field dialog box
        • Filter Configurator dialog box
        • Find and replace dialog box
        • Flatshot dialog box
        • Format dialog box
        • Geographic location dialog box
        • Geometric tolerance dialog box
        • Hatch and gradient dialog box
        • Hatch Edit dialog box
        • Import Civil 3D dialog box
        • Import page setups dialog box
        • Import sheet set dialog box
        • Insert block dialog box
        • Insert object dialog box
        • Insert table dialog box
        • Layer Property Filter dialog box
        • Layer settings dialog box
        • Layer translator dialog box
        • Layout manager dialog box
        • Links dialog box
        • Load application files dialog box
        • Load linetypes dialog box
        • Load Multiline Styles dialog box
        • Login dialog box
        • Manage Customizations dialog box
        • Manage visibility
        • Map Connect dialog box
        • Match Properties dialog box
        • Motion path animation
        • Navigate Settings dialog box
        • New Layer Name dialog box
        • New Multileader Style dialog box
        • New Multiline Style dialog box
        • New Page Setup dialog box
        • New Sheet(s) dialog box
        • Optimize 2D lines dialog box
        • Page setup dialog box
        • Paste special dialog box
        • Physical materials dialog box
        • Plot stamp dialog box
        • Plot style table editor dialog box
        • Plotter Configuration Editor dialog box
        • Pre-process point cloud data file(s) dialog box
        • Print dialog box
        • Profiles dialog box
        • Project setup dialog box
        • Proxy information dialog box
        • Publish dialog box
        • QLeader Settings dialog box
        • Reassociate entity data dialog box
        • Reference Edit dialog box
        • Render dialog box
        • Run BricsCAD VBA macro dialog box
        • Save block definition dialog box
        • Save detail dialog box
        • Save workspace dialog box
        • Security dialog box
        • Security options dialog box
        • Select color dialog box
        • Select Custom Arrow Block dialog box
        • Select items to delete from cache dialog box
        • Select item to attach to this DWG
        • Settings dialog box
        • Set viewpoint dialog box
        • Sheet Properties dialog box
        • Sheet selection sets dialog box
        • Sheetset setup dialog box
        • Spatial Locations Manager dialog box
        • Spell checking
        • Standard open file dialog box
        • Standard save file dialog box
        • Tags dialog box
        • Tool image dialog box
        • Tool Properties dialog box
        • Upload to Bricsys 24/7 dialog box
        • User coordinate system dialog box
        • User profile manger dialog box
        • VBA manager dialog box
        • View Options dialog box
        • Visual settings dialog box
        • Wall detection options dialog box
        • Wizard page dialog box
        • Working sets dialog box
        • Write block to file dialog box
    • Managing drawings
      • Working in the Drawing Explorer dialog box
      • Drawing security options
      • Opening and saving drawings
      • Getting drawing information
      • Comparing drawings
      • Repairing a drawing
      • Projects
    • Drawing accurately
      • Orthogonal mode
      • Unit settings
      • Coordinate reference system
      • 2D constraints
      • Using dimensional constraints
      • Using geometric constraints
      • Dynamic dimensions
      • Nearest distance
      • Coordinate input
      • Snap and grid
      • Adaptive grid snap
      • Nudge
      • 2D entity snaps
      • 3D entity snaps
      • Polar tracking
      • Entity snap tracking
      • User coordinate systems
      • Dynamic UCS
      • Measuring
      • Entity snaps overview
        • Apparent intersection entity snap
        • Center entity snap
        • Center of a Face 3D entity snap
        • Endpoint entity snap
        • Extension entity snap
        • Geometric center entity snap
        • Insertion entity snap
        • Intersection entity snap
        • Intersection 3D entity snap
        • Knot 3D entity snap
        • Midpoint entity snap
        • Midpoint 3D entity snap
        • Nearest entity snap
        • Nearest 3D entity snap
        • Node entity snap
        • Parallel entity snap
        • Perpendicular entity snap
        • Perpendicular on a face 3D entity snap
        • Quadrant entity snap
        • Tangent entity snap
        • Vertex 3D entity snap
    • Viewing your drawing
      • View commands overview
      • Layer utilities
      • Hide and isolate entities
      • Panning
      • Zooming
      • View manipulation using the mouse and keyboard
      • View rotation
      • The LookFrom control
      • Layer states
      • Named views
      • Visual styles
      • Model space and paper space
      • Model space viewports
      • Paper space viewports
      • Creating paper space viewports
      • Layouts
      • Generated drawing views
    • 2D作図
      • Creating entities
      • Working with layers
      • Entity linetype
      • Entity color
      • Lineweight
      • Fill mode
      • Transparency
      • Editing entity properties
      • Drawing linear entities
      • Drawing lines
      • Drawing rays
      • Drawing infinite lines
      • Drawing polylines
      • Drawing multilines
      • Drawing splines
      • Drawing freehand sketches
      • Drawing circles
      • Drawing arcs
      • Drawing ellipses
      • Drawing rectangles
      • Drawing polygons
      • Drawing traces
      • Drawing donuts
      • Drawing solids
      • Drawing revision clouds
      • Drawing points
      • Drawing wipeouts
      • Drawing helixes
      • Drawing 3D polylines
      • Creating regions
      • Creating hatches and gradient fills
      • Editing hatches and gradient fills
    • 3D Modeling
      • Direct modeling overview
      • Navigate in 3D
      • Direct modeling commands
      • Direct modeling operations
      • Design intent recognition
      • Working with sections
      • Create a TIN Surface
      • TIN Surface Edit
      • TIN Surface Direct Modeling
      • Analyzing TIN Surfaces
      • Working with Gradings
      • Create and edit alignments
      • Modeling a Corridor
    • Parametric modeling
      • Operations and functions in expressions
      • 3D constraints
      • Suppression feature
      • Working with design tables
    • Point cloud
      • Working with Point cloud
    • ブロック、属性、外部参照およびコンポーネント
      • Creating blocks
      • Using Blockify
      • Editing blocks
      • Inserting blocks
      • Exploding blocks
      • 2D parametric blocks
      • Dynamic blocks
      • Defining attributes
      • Working with attributes
      • Editing attribute definitions
      • Editing block attributes
      • Inserting blocks with attributes
      • Extracting attribute information
      • Managing Xrefs
      • Attaching an external reference
      • Working with external references
      • Editing blocks and external references
      • Working with groups
      • Working with underlays
      • Components and component inserts
    • Managing images
      • Managing images
      • Image utilities
    • 注釈
    • Dimensions
      • Dimensioning tools overview
      • Associative dimensions
      • Dimension settings
      • Working with dimension styles
      • Using the dimension style tools
      • Creating linear dimensions
      • Creating angular dimensions
      • Creating diametrical and radial dimensions
      • Centerlines and center marks
      • Creating ordinate dimensions
      • Editing dimensions
      • Creating leaders and annotations
      • Creating multileaders
      • Adding geometric tolerances
    • Texts
      • Text system variables
      • Working with text styles
      • Creating text
      • Editing text
      • Exploding text
      • Finding and replacing text
      • Checking spelling
      • Working with fields
      • Working with tables
    • Annotative Entities
      • Annotative entities
      • Annotation scales
      • Annotative texts
      • Annotative blocks
      • Annotative dimensions
      • Annotative leaders
    • Customization
      • Startup options
      • BricsCAD user files
      • Loading and unloading CUI files
      • Creating a partial CUI file
      • Managing toolboxes
      • Creating toolbars
      • Creating menus
      • Creating context menus
      • Creating keyboard shortcuts
      • Customizing the Quad
      • Adding tools to user interface controls
      • Customizing the ribbon
      • Tool palettes
      • Command aliases
      • User profiles
      • Workspaces
      • Express tools
      • Lisp
    • Modifying Entities
      • Modifying commands overview
      • Entity modification settings
      • Match properties
      • Grips editing
      • Selection methods
      • Quick select
      • Draw order
      • The manipulator
      • Moving entities
      • Rotating entities
      • Mirroring entities
      • Aligning entities
      • Changing entities
      • Copying entities
      • Making parallel copies
      • Arraying entities
      • Extending entities
      • Trimming entities
      • Lengthening entities
      • Selection and grip settings
      • Stretching entities
      • Scaling entities
      • Breaking entities
      • Joining entities
      • Chamfering entities
      • Filetting entities
      • Editing polylines
      • Exploding entities
      • Measuring entities
      • Dividing entities
    • Printing and plotting
      • General procedure for printing
      • Plotter configuration
      • Plot style tables
      • The plot styles manager
      • Batch plot
    • Rendering
      • Using TwinMotion
      • Rendering overview
      • Rendering preferences
      • Rendering tools
      • Render materials
      • Lights
      • Creating a rendered image
    • User feedback
      • Diagnostics and usage data collection
  • BricsCAD BIM
    • What's new in BricsCAD V21 BIM
      • Overview
      • Modeling techniques
      • Building data
      • Project collaboration
      • Design documentation
      • Point clouds
    • Getting started
      • Creating a BIM model
      • Quad cursor
      • Viewing entities
      • Level of detail
      • BIM linear solid
      • BIM window create
      • The library panel
      • Connecting solids
      • Creating a custom window
      • Creating roofs
      • Creating slabs
      • Creating walls
      • Curtain wall
      • DmExtrude
      • DmPushPull
      • Editing grids
      • Mass modeling with quickbuilding
      • MEP modeling
      • MEP flow connection points
      • Offset
      • Splitting solids
      • Stair tool
      • Structural steel
      • Using BIM quickdraw
      • Using drag
      • Using parametrize
    • Building data
      • Analytical model
      • AutoComplete BIM data
      • Attaching compositions
      • BIM classify
      • BIM compositions
      • BIM data structure
      • BIM ply editing
      • BIM project info
      • Using Python scripts (beta)
      • Classification codes
      • Custom properties
      • Customizing BIM quantities
      • Project browser
      • Spatial locations
      • Structure browser
    • Design assistance
      • Using bimify
      • Using propagate
      • Propagate planar
      • Propagate linear
      • Propagate pattern
      • Propagate edges
      • Propagate corner
      • Parametrize details
      • Details panel
      • Import and underlay Autodesk® Revit® files in BricsCAD
      • Interference checking
      • Using Xrefs
      • Annotations in 3D
      • BIM sections
      • BIM tags
      • Create drawing types with drawing customization
      • Define detailed section
      • Detailing with BimPatch
      • Editing generated drawings
      • Elevation hatch
      • Enscape integration
      • Generating Drawings
      • Interior elevations
      • Schedules
      • Spot elevation level
  • BricsCAD Mechanical
    • BricsCAD V21 Mechanicalの新機能
      • Overview
      • BOM manager
      • Parts libraries
      • 標準部品
      • Sheet metal
    • Getting started
      • Mechanical workspace
      • 3D comparison
    • 部品設計
      • Thread feature
      • Part Design Methods
      • Sketching
      • Solid Modeling
      • Surface Modeling
      • Freeform Surface Modeling
    • アセンブリ設計
      • Bottom-up and Top-down Assembly Design
      • Assembly Design Commands and Tools
      • Component Properties
      • Assembly mass properties
      • Standard Mechanical Components
      • Piping in Assembly Design
      • Arrays of Components
      • Array Properties
      • Exploded Representations
      • Bill of Materials Manager
      • Bill of Materials
    • Sheet Metal
      • Sheet Metal Design Methods
      • Sheet Metal Commands and Toolbars
      • Sheet Metal Features
      • フィーチャーに色付け
      • Mechanical Browser for Sheet Metal
      • Sheet Metal Global and Feature Properties
      • K-factor
      • Bend Table
      • Sheet Metal Settings
      • Creating Flanges
      • Modifying Flanges
      • Working with Bends and Junctions
      • Working with Hems
      • Working with Tabs
      • Working with T-tabs and T-junctions
      • Working with Bevels
      • Creating and Splitting Lofted Bends
      • Working with Form and Rib Features
      • Working with Hole Features
      • Converting to Sheet Metal and Repairing
      • Unfolding Sheet Metal Parts and Exporting to CAM
      • Associative Unfolded Representations of 3D Solids
      • Smart Features
    • 生成された図面
      • Drawing Views
      • 注釈の作図
  • Communicator for BricsCAD
    • BricsCAD Communicator
  • BricsCAD Shape
    • Introduction to BricsCAD Shape
    • BricsCAD Shape user interface
    • Basic concepts of modeling in BricsCAD Shape
    • Navigation in BricsCAD Shape
    • Components in BricsCAD Shape
    • Materials in BricsCAD Shape
    • Layers in BricsCAD Shape
    • Working with steel profiles
    • Visualization in BricsCAD Shape
    • Solids in BricsCAD Shape
    • Creating walls in BricsCAD Shape
    • Quickdraw in BricsCAD Shape
    • Creating windows and doors in BricsCAD Shape
    • Creating roofs in BricsCAD Shape
  • Command reference
      • +STRUCTUREPANELコマンド
      • ? command
    • 2
      • 2DINTERSECTION command
    • 3
      • 3D command
      • 3DARRAY command
      • 3DCOMPARE command
      • 3DCONVERT command
      • 3DDWF command
      • 3DFACE command
      • 3DINTERSECTION command
      • 3DMESH command
      • 3DOSNAP command
      • -3DOSNAP command
      • 3DPOLY command
    • A
      • ABOUT command
      • ACISIN command
      • ACISOUT command
      • ACTIVATESECTIONVIEW command
      • ADDINMAN command
      • ADDSELECTED command
      • AI_BOX command
      • AI_CONE command
      • AI_CIRCTAN command
      • AI_CYLINDER command
      • AI_DESELECT command
      • AI_DIM_TEXTABOVE command
      • AI_DIM_TEXTCENTER command
      • AI_DIM_TEXTHOME command
      • AI_DISH command
      • AI_DOME command
      • AI_EDGESURF command
      • AI_FMS command
      • AI_PSPACE command
      • AI_PYRAMID command
      • AI_REVSURF command
      • AI_RULESURF command
      • AI_SELALL command
      • AI_SPHERE command
      • AI_TABSURF command
      • AI_TORUS command
      • AI_WEDGE command
      • AIMLEADEREDITADD command
      • AIMLEADEREDITREMOVE command
      • AIDIMFLIPARROW command
      • AIDIMPREC command
      • AIDIMSTYLE command
      • ALIGN command
      • ALIGNMENT command
      • ALIGNMENTEDIT command
      • ALIGNMENTVIEW command
      • ALIGNMENTVINITIAL command
      • ALIGNSPACE command
      • ANIMATIONEDITORCLOSE command
      • ANIMATIONEDITOROPEN command
      • ANIPATH command
      • ANNORESET command
      • ANNOUPDATE command
      • APERTURE command
      • APPARENT command
      • APPLOAD command
      • ARC command
      • AREA command
      • ARRAY command
      • -ARRAY command
      • ARRAYCLASSIC command
      • ARRAYCLOSE command
      • -ARRAYCLOSE command
      • ARRAYEDIT command
      • ARRAYEDITEXT command
      • ARRAYPATH command
      • ARRAYPOLAR command
      • ARRAYRECT command
      • ATTACHMENTSPANELCLOSE command
      • ATTACHMENTSPANELOPEN command
      • ATTDEF コマンド
      • -ATTDEF command
      • ATTDISP command
      • ATTEDIT command
      • ATTEXT command
      • -ATTEXT command
      • ATTREDEF command
      • ATTSYNC command
      • AUDIT command
      • AUTOCOMPLETE command
      • AUTOCONSTRAIN command
    • B
      • BACKGROUND command
      • BASE command
      • BATTMAN command
      • BCLOSE command
      • BEDIT command
      • -BEDIT command
      • BHATCH command
      • -BHATCH command
      • BIMACTIVATEPYTHON command
      • BIMADDECCENTRICITY command
      • BIMANALYTICALMODEL command
      • BIMAPPLYPROFILE command
      • BIMATTACHCOMPOSITION command
      • BIMATTACHSPATIALLOCATION command
      • BIMAUTOMATCH command
      • BIMCLASSIFY command
      • BIMCOPY command
      • BIMCREATEDETAIL command
      • BIMCURTAINWALL command
      • BIMDECOMPOSE command
      • BIMFLIP command
      • BIMFLOWCONNECT command
      • BIMGRID command
      • BIMIFY command
      • -BIMINSERT command
      • BIMINSERT command
      • BIMLINEARSOLID command
      • BIMLIST command
      • BIMMULTISELECT command
      • BIMPARAMETRIZEDETAIL command
      • BIMPATCH command
      • BIMPROFILES command
      • BIMPROJECTINFO command
      • BIMPROPAGATE command
      • BIMPROPAGATECORNER command
      • BIMPROPAGATEEDGES command
      • BIMPROPAGATELINEAR command
      • BIMPROPAGATEPATTERN command
      • BIMPROPAGATEPLANAR command
      • BIMPROPERTIES command
      • BIMPYTHON command
      • BIMROOM command
      • BIMQUICKBUILDING command
      • BIMQUICKDRAW command
      • BIMRECALCULATEAXIS command
      • BIMREGENERATETAGS command
      • BIMSECTION command
      • BIMSECTIONOPEN command
      • BIMSECTIONUPDATE command
      • BIMSETLOADBEARINGDIRECTION command
      • BIMSETREFERENCEFACE command
      • BIMSPACE command
      • BIMSPATIALLOCATIONS command
      • BIMSPLIT command
      • BIMSTAIR command
      • BIMSTRETCH command
      • BIMSTRUCTURALCONNECT command
      • BIMTAG command
      • BIMUPDATESPACE command
      • BIMUPDATETHICKNESS command
      • BIMWINDOWCREATE command
      • -BIMWINDOWCREATE command
      • BIMWINDOWPRINT command
      • BIMWINDOWUPDATE command
      • BLADE command
      • BLCOMPOSITIONS command
      • BLIPMODE command
      • BLMATERIALS command
      • BLOCK command
      • -BLOCK command
      • BLOCKICON command
      • BLOCKIFY command
      • BMBALLOON command
      • BMBOM command
      • BMBOMEDIT command
      • BMBOMPANELCLOSE コマンド
      • BMBOMPANELOPEN command
      • BMCONNECT command
      • BMCREATECOMPONENT command
      • -BMCREATECOMPONENT command
      • BMDEPENDENCIES command
      • BMDISSOLVE command
      • BMEXPLODE command
      • BMEXPLODEMOVE command
      • BMEXPLODESTEPEDIT command
      • BMEXTERNALIZE command
      • BMFORM command
      • BMHARDWARE command
      • -BMHARDWARE command
      • BMHIDE command
      • BMINSERT command
      • -BMINSERT command
      • BMLINK command
      • BMLOCALIZE command
      • BMMASSPROP command
      • BMMECH command
      • BMNEW command
      • BMOPEN command
      • BMOPENCOPY command
      • -BMPARAMETERS command
      • BMPOUT command
      • BMRECOVER command
      • BMREPLACE command
      • BMSHOW コマンド
      • BMTRAILINGLINES command
      • BMUNLINK command
      • BMUNMECH command
      • BMUPDATE command
      • BMVSTYLE command
      • BMXCONVERT command
      • BOUNDARY command
      • -BOUNDARY command
      • BOX command
      • BREAK command
      • BROWSER command
      • BSAVEAS コマンド
    • C
      • CALコマンド
      • CALLOUT command
      • CAMERA command
      • CENTER command
      • CENTERDISASSOCIATE command
      • CENTERLINE command
      • CENTERMARK command
      • CENTERREASSOCIATE command
      • CENTERRESET command
      • CHAMFER command
      • CHANGE command
      • CHPROP command
      • CHSPACE command
      • CIRCLE command
      • CIVIL3DIMPORT command
      • CIVILDWGEXPORT command
      • CLEANSCREENOFF command
      • CLEANSCREENON command
      • CLEANUNUSEDVARIABLES command
      • CLIPDISPLAY command
      • CLOSE command
      • COLOR command
      • -COLOR command
      • COMMANDLINE command
      • COMMANDLINEHIDE command
      • COMMANDS command
      • COMMUNICATORINFO command
      • COMPONENTSPANELCLOSE command
      • COMPONENTSPANELOPEN command
      • CONE command
      • CONSTRAINTBAR command
      • CONTENTBROWSERCLOSE command
      • CONTENTBROWSEROPEN command
      • CONVERTCTB command
      • CONVERTOLDLIGHTS command
      • CONVERTOLDMATERIALS command
      • CONVERTPOLY command
      • CONVERTPSTYLES command
      • CONVTOMESH command
      • CONVTOSOLID command
      • CONVTOSURFACE command
      • COPY command
      • COPYBASE command
      • COPYCLIP command
      • COPYEDATA command
      • COPYGUIDED command
      • COPYHIST command
      • COPYTOLAYER command
      • CORRIDOR command
      • CORRIDOREDIT command
      • CORRIDOREXTRACT command
      • CORRIDORTEMPLATE command
      • CORRIDORTEMPLATEELEMENT command
      • CPAGESETUP コマンド
      • CREATELIBRARYBLOCK command
      • -CREATELIBRARYBLOCK command
      • CREATETHUMBNAIL command
      • CUILOAD command
      • CUIUNLOAD command
      • CUSTOMIZE command
      • CUTCLIP command
      • CYLINDER command
    • D
      • DATAEXTRACTION command
      • -DATAEXTRACTION command
      • DATALINK command
      • DATALINKUPDATE command
      • DATASMITHEXPORT command
      • DBLIST command
      • DCALIGNED command
      • DCANGULAR command
      • DCCONVERT command
      • DCDIAMETER command
      • DCDISPLAY command
      • DCHORIZONTAL command
      • DCLINEAR command
      • DCRADIUS command
      • DCVERTICAL command
      • DDATTE command
      • DDEDIT command
      • DDEMODES command
      • DDFILTER command
      • DDGRIPS command
      • DDPTYPE コマンド
      • DDSELECT コマンド
      • DDSETVAR command
      • DDSTRACK command
      • DDVPOINT command
      • DEFAULTSCALELIST command
      • DELAY command
      • DELCONSTRAINT command
      • DELEDATA command
      • DESIGNTABLE command
      • -DESIGNTABLEEDIT command
      • DETAILSPANELCLOSE command
      • DETAILSPANELOPEN command
      • DGNEXPORT command
      • -DGNEXPORT command
      • DGNIMPORT command
      • DGNIMPORTOPTIONS コマンド
      • DIM command
      • DIM1 Command
      • DIMALIGNED command
      • DIMANGULAR command
      • DIMARC command
      • DIMBASELINE command
      • DIMBREAK command
      • DIMCENTER コマンド
      • DIMCONSTRAINT command
      • DIMCONTINUE command
      • DIMDIAMETER command
      • DIMDISASSOCIATE command
      • DIMEDIT command
      • DIMLEADER command
      • DIMLINEAR command
      • DIMORDINATE command
      • DIMOVERRIDE command
      • DIMRADIUS command
      • DIMREASSOCIATE command
      • DIMREGEN command
      • DIMSTYLE command
      • -DIMSTYLE command
      • DIMSTYLESET command
      • DIMTEDIT command
      • DISH command
      • DIST command
      • DISTANTLIGHT command
      • DIVIDE command
      • DMANGLE3D command
      • DMAUDIT command
      • DMAUDITALL command
      • DMCHAMFER command
      • DMCOINCIDENT3D command
      • DMCONCENTRIC3D command
      • DMCONSTRAINT3D command
      • DMCOPYFACES command
      • DMDEFORMCURVE command
      • DMDEFORMMOVE command
      • DMDEFORMPOINT command
      • DMDELETE コマンド
      • DMDISTANCE3D command
      • DMEXTRUDE command
      • DMFILLET command
      • DMFIX3D command
      • DMGROUP command
      • DMMOVE command
      • DMPARALLEL3D command
      • DMPATH3D command
      • DMPERPENDICULAR3D command
      • DMPUSHPULL command
      • DMRADIUS3D command
      • DMREPAIR command
      • DMREVOLVE command
      • DMRIGIDSET3D command
      • DMROTATE command
      • DMSELECT command
      • DMSELECTEDGES command
      • DMSIMPLIFY command
      • DMSIMPLIFYALL command
      • DMSTITCH command
      • DMTANGENT3D command
      • DMTHICKEN command
      • DMTHREAD command
      • DMTWIST command
      • DMUPDATE command
      • DOME command
      • DONUT command
      • DRAG command
      • DRAGMODE command
      • DRAWORDER command
      • DRAWORDERBYLAYER command
      • DSETTINGS command
      • DTEXT command
      • DUMPSTATE command
      • DVIEW command
      • DWFOUT command
      • DWGCODEPAGE command
      • DWGCOMPARE command
      • DWGPROPS command
      • DXFIN command
      • DXFOUT command
    • E
      • EATTEDIT command
      • EDGESURF command
      • EDITEDATA command
      • ELEV command
      • ELLIPSE command
      • ENABLEASSOCVIEWS command
      • ENDCOMPARE command
      • ENDPOINT command
      • ERASE command
      • ETRANSMIT command
      • -ETRANSMIT command
      • EXECUTETOOL command
      • EXPBLOCKS command
      • EXPFOLDERS command
      • EXPIMAGES command
      • EXPLAYERS command
      • EXPLODE command
      • EXPLORER command
      • EXPORT command
      • EXPORTLAYOUT command
      • EXPORTPDF command
      • EXPPDFS command
      • EXPUCS command
      • EXPXREF command
      • EXTEND command
      • EXTENSION コマンド
      • EXTRUDE command
    • F
      • FBXEXPORT command
      • -FBXEXPORT command
      • FIELD command
      • FILEOPEN command
      • FILES command
      • FILL command
      • FILLET command
      • FIND command
      • FITARC command
      • FITLINE command
      • FLATSHOT command
      • FLATTEN command
      • FROM command
    • G
      • GCCOINCIDENT command
      • GCCOLINEAR command
      • GCCONCENTRIC command
      • GCENTER command
      • GCEQUAL command
      • GCFIX command
      • GCHORIZONTAL command
      • GCPARALLEL command
      • GCPERPENDICULAR command
      • GCSMOOTH command
      • GCSYMMETRIC command
      • GCTANGENT command
      • GCVERTICAL command
      • GENERATEBOUNDARY command
      • GEOGRAPHICLOCATION command
      • GEOIMPORT command
      • GEOMCONSTRAINT command
      • GOTOSTART command
      • GRADIENT command
      • -GRADIENT command
      • GRADIENTBKGOFF command
      • GRADIENTBKGON command
      • GRADING command
      • GRADINGBALANCE command
      • GRAPHSCR command
      • GRID command
      • GROUP command
      • -GROUP command
    • H
      • HATCH コマンド
      • -HATCH command
      • HATCHEDIT Command
      • -HATCHEDIT command
      • HATCHEDITEXT command
      • HATCHGENERATEBOUNDARY command
      • HATCHTOBACK command
      • HELIX command
      • HELP command
      • HELPSEARCH command
      • HIDE command
      • HIDEOBJECTS command
      • HYPERLINK command
      • -HYPERLINK command
      • HYPERLINKOPTIONS command
    • I
      • ID command
      • IEMBED command
      • IFCEXPORT command
      • IMAGE command
      • IMAGEADJUST command
      • -IMAGEATTACH
      • IMAGEATTACH command
      • IMAGECLIP command
      • IMAGEFRAME command
      • IMAGEQUALITY コマンド
      • -IMPORT command
      • IMPORT command
      • IMPRINT command
      • INSERT command
      • -INSERT command
      • INSERTALIGNED command
      • INSERTION command
      • INSERTOBJ command
      • INTERFERE command
      • -INTERFERE command
      • INTERSECT command
      • INTERSECTION コマンド
      • INVOKETESTAPP command
      • ISAVEAS command
      • ISOLATEOBJECTS command
      • ISOPLANE command
      • IUNEMBED command
    • J
      • JOIN command
    • K
      • KEEPME command
    • L
      • LANDXMLEXPORT command
      • LANDXMLIMPORT command
      • LAYCUR command
      • -LAYER command
      • LAYER command
      • LAYERP コマンド
      • LAYERSPANELCLOSE command
      • LAYERSPANELOPEN command
      • LAYERSTATE command
      • LAYFRZ command
      • LAYISO command
      • LAYLCK command
      • LAYMCUR command
      • LAYOFF command
      • LAYON command
      • LAYOUT command
      • LAYOUTMANAGER command
      • LAYTHW command
      • LAYTRANS command
      • LAYULK command
      • LAYUNISO command
      • LCONNECT command
      • LEADER command
      • LENGTHEN command
      • LIBRARYPANELCLOSE command
      • LIBRARYPANELOPEN command
      • LICENSEMANAGER command
      • LIGHT command
      • LIGHTLIST command
      • LIMITS command
      • LINE command
      • -LINETYPE command
      • LINETYPE command
      • LIST command
      • LIVESECTION command
      • LOAD command
      • LOFT command
      • LOGFILEOFF command
      • LOGFILEON command
      • -LOGIN command
      • -LOGOUT command
      • LOOKFROM command
      • LWEIGHT command
    • M
      • MAIL command
      • MANIPULATE command
      • MAPCONNECT command
      • MASSPROP command
      • MATBROWSERCLOSE command
      • MATBROWSEROPEN command
      • MATCHPERSPECTIVE command
      • MATCHPROP command
      • MATERIALASSIGN command
      • MATERIALMAP command
      • MATERIALS command
      • MATLIB command
      • MEASURE command
      • MECHANICALBROWSERCLOSE command
      • MECHANICALBROWSEROPEN command
      • MENU command
      • MENULOAD command
      • MENUUNLOAD command
      • MIDPOINT command
      • MINSERT command
      • MIRROR command
      • MIRROR3D command
      • MLEADER command
      • MLEADERALIGN command
      • MLEADERCOLLECT command
      • MLEADEREDIT command
      • MLEADEREDITEXT command
      • MLEADERSTYLE command
      • MLINE command
      • MLSTYLE command
      • MODELERPROPERTIES コマンド
      • -MODELERPROPERTIES command
      • MOVE command
      • MOVEEDATA command
      • MOVEGUIDED command
      • MSLIDE command
      • MSPACE command
      • MTEXT command
      • -MTEXT command
      • MTP command
      • MULTIPLE command
      • MVIEW command
      • MVSETUP command
    • N
      • NAVIGATE command
      • NEARESTコマンド
      • NETLOAD command
      • NEW command
      • NEWSHEETSET command
      • NEWWIZ command
      • NODE command
      • NONE command
      • NUMBER command
    • O
      • OBJECTSCALE command
      • -OBJECTSCALE command
      • OFFSET command
      • OLELINKS command
      • OLEOPEN command
      • ONWEB command
      • OOPS コマンド
      • OPEN command
      • OPENSHEETSET command
      • -OPENSHEETSET command
      • OPTIMIZE コマンド
      • -OPTIMIZE command
      • OPTIONS command
      • ORTHOGONAL command
      • OSNAP command
      • -OSNAP command
      • OVERKILL command
      • -OVERKILL command
    • P
      • PACKAGE command
      • PAGESETUP command
      • PAN command
      • -PAN command
      • PANELIZE command
      • PARALLEL command
      • PARAMETERCOPYMODE command
      • -PARAMETERS command
      • PARAMETERSPANELCLOSE command
      • PARAMETERSPANELOPEN command
      • PARAMETRICBLOCKIFY command
      • PARAMETRIZE command
      • PARAMETRIZE2D command
      • PASTEBLOCK command
      • PASTECLIP command
      • PASTEORIG command
      • PASTESPEC command
      • PDF command
      • PDFADJUST command
      • PDFATTACH command
      • -PDFATTACH command
      • PDFCLIP command
      • PDFIMPORT command
      • -PDFIMPORT command
      • PDFLAYERS command
      • PDFOPTIONS command
      • PEDIT command
      • PEDITEXT command
      • PERPENDICULAR command
      • PFACE command
      • PLACEVIEW command
      • PLAN command
      • PLINE command
      • PLOT command
      • -PLOT command
      • PLOTSTAMP command
      • PLOTSTYLE command
      • PLOTTERMANAGER command
      • PNGOUT command
      • POINT コマンド
      • POINTCLOUD command
      • POINTCLOUDALIGN command
      • POINTCLOUDATTACH command
      • -POINTCLOUDATTACH command
      • POINTCLOUDCOLORMAP command
      • POINTCLOUDCROP command
      • POINTCLOUDCROPSOLID command
      • POINTCLOUDDELETEITEM command
      • POINTCLOUDDETECTFLOORS command
      • POINTCLOUDEXPORT command
      • POINTCLOUDFITPLANAR command
      • POINTCLOUDIMPORT command
      • POINTCLOUDPOINTSIZE_MINUS command
      • POINTCLOUDPOINTSIZE_PLUS command
      • POINTCLOUDPREPROCESS command
      • -POINTCLOUDPREPROCESS command
      • POINTCLOUDPROJECTSECTION command
      • POINTCLOUDREFERENCE command
      • POINTCLOUDSHOWBUBBLES command
      • POINTCLOUDUNCROP command
      • POINTLIGHT command
      • POLYGON command
      • POLYSOLID command
      • PREVIEW command
      • PRINT command
      • PROFILEMANAGER command
      • PROJECTGEOMETRY command
      • PROPERTIES command
      • PROPERTIESCLOSE command
      • PROXYINFO command
      • PSETUPIN command
      • -PSETUPIN command
      • PSPACE command
      • PUBLISH command
      • -PUBLISH command
      • PURGE command
      • -PURGE command
      • PYRAMID command
    • Q
      • QLEADER command
      • QNEW command
      • QPRINT command
      • QSAVE command
      • QSELECT command
      • QTEXT command
      • QUADRANT command
      • QUIT command
    • R
      • RAY command
      • REASSOCAPP command
      • RECOVER command
      • RECOVERALL command
      • RECSCRIPT command
      • RECTANG command
      • REDEFINE command
      • REDO command
      • REDRAW command
      • REDRAWALL command
      • REDSDKINFO command
      • REFCLOSE command
      • REFEDIT command
      • -REFEDIT command
      • REFERENCECURVES command
      • REFSET command
      • REGEN command
      • REGENALL command
      • REGENAUTO command
      • REGION command
      • REINIT command
      • RENAME command
      • -RENAME command
      • RENDER command
      • -RENDER command
      • RENDERCOMPOSITIONSMATERIAL command
      • RENDERPRESETS command
      • RENDERWINCLOSE command
      • REPORTPANELCLOSE command
      • REPORTPANELOPEN command
      • RESETASSOCVIEWS command
      • RESETBLOCK command
      • RESUME command
      • REVCLOUD command
      • REVOLVE command
      • REVSURF command
      • RIBBON command
      • RIBBONCLOSE command
      • ROTATE command
      • ROTATE3D command
      • RSCRIPT command
      • RTLOOK command
      • RTPAN command
      • RTROT command
      • RTROTCTR command
      • RTROTF command
      • RTROTX command
      • RTROTY command
      • RTROTZ command
      • RTUPDOWN command
      • RTWALK command
      • RTZOOM command
      • RULESURF command
      • RUNASLEVEL command
    • S
      • SAVE command
      • SAVEALL command
      • SAVEAS command
      • SAVEASR12 Command
      • SAVEFILEFOLDER command
      • SCALE command
      • SCALELISTEDIT command
      • -SCALELISTEDIT command
      • SCREENSHOT command
      • SCRIPT command
      • SCROLLBAR command
      • SECTION command
      • SECTIONPLANE command
      • SECTIONPLANESETTINGS command
      • SECTIONPLANETOBLOCK command
      • SECURITY コマンド
      • SECURITYOPTIONS command
      • SELECT command
      • SELECTALIGNEDFACES command
      • SELECTALIGNEDSOLIDS command
      • SELECTCONNECTEDFACES command
      • SELECTSIMILAR command
      • SELGRIPS command
      • SETBYLAYER command
      • -SETBYLAYER command
      • SETLICENSELEVEL command
      • SETTINGS command
      • SETTINGSSEARCH command
      • SETUCS command
      • SETVAR command
      • SH command
      • SHADE command
      • SHADEMODE command
      • -SHADEMODE command
      • SHAPE command
      • SHEETSET command
      • SHEETSETHIDE command
      • SHELL command
      • SIMPLIFY command
      • SINGLETON command
      • SKETCH command
      • SLICE command
      • SMASSEMBLYEXPORT command
      • SMBENDCREATE command
      • SMBENDSWITCH command
      • SMCONVERT command
      • SMDELETE command
      • SMDISSOLVE command
      • SMEXPLODE command
      • SMEXPORT2D command
      • SMEXPORTOSM command
      • SMEXTRUDE command
      • SMFLANGEBASE command
      • SMFLANGEBEND command
      • SMFLANGECONNECT command
      • SMFLANGECONTOUR command
      • SMFLANGEEDGE command
      • SMFLANGEROTATE command
      • SMFLIP command
      • SMFORM command
      • SMHEMCREATE command
      • SMIMPRINT command
      • SMJUNCTIONCREATE command
      • SMJUNCTIONSWITCH command
      • SMLISPGET command
      • SMLISPSET command
      • SMLOFT command
      • SMPARAMETRIZE command
      • SMRELIEFCREATE command
      • SMRELIEFSWITCH command
      • SMREPAIR command
      • SMREPLACE command
      • SMRIBCREATE command
      • SMSELECT command
      • SMSPLIT command
      • SMTABCREATE command
      • SMUNFOLD command
      • SNAP command
      • SOLID command
      • SOLIDEDIT command
      • SOLPROF command
      • SPELL command
      • SPHERE コマンド
      • SPLINE command
      • SPLINEDIT command
      • SPOTLIGHT command
      • STANDARDPARTSPANELCLOSE command
      • STANDARDPARTSPANELOPEN command
      • START command
      • STATBAR command
      • STATUS command
      • STLOUT command
      • STOPSCRIPT command
      • STRETCH command
      • STRUCTUREPANEL command
      • STRUCTUREPANELCLOSE command
      • STYLE command
      • -STYLE command
      • STYLESMANAGER command
      • SUBTRACT command
      • SUNPROPERTIES command
      • SUPPORTFOLDER command
      • SUPPRESS command
      • SVGOPTIONS command
      • SWEEP command
      • SYSWINDOWS command
    • T
      • TABLE command
      • -TABLE command
      • TABLEDIT command
      • TABLEEXPORT command
      • TABLEMOD command
      • TABLESTYLE command
      • TABLET command
      • TABSURF command
      • TANGENT command
      • TCONNECT command
      • TEMPLATEFOLDER command
      • TESTDBUSERIO command
      • TESTDLG command
      • TESTFATAL command
      • TESTINTERNAL command
      • TESTSELECTION command
      • TEXT command
      • -TEXT command
      • TEXTSCR command
      • TEXTTOFRONT command
      • TFLOAD command
      • TFSAVE command
      • TIME command
      • TIN command
      • TINASSIGNIMAGE command
      • TINEDIT
      • TINEXTRACT command
      • TINMERGE command
      • TINMODIFY command
      • TINPROJECT command
      • TINSERT command
      • TINVOLUME command
      • TINWATERDROP command
      • TIPS command
      • TOLERANCE command
      • TOOLBAR command
      • -TOOLBAR command
      • TOOLPALETTES command
      • TOOLPALETTESCLOSE command
      • -TOOLPANEL command
      • TORUS command
      • TPNAVIGATE command
      • TRACE command
      • TRANSPARENCY command
      • TRIM command
      • TXT2MTXT command
      • TXTEXP command
    • U
      • U command
      • UCS command
      • UCSICON command
      • UNDEFINE command
      • UNDO command
      • UNDOENT command
      • UNGROUP command
      • UNION command
      • UNISOLATEOBJECTS command
      • UNITS command
      • -UNITS command
      • UPDATEFIELD command
      • URL command
    • V
      • VBAIDE command
      • VBALOAD command
      • -VBALOAD command
      • VBAMAN command
      • VBANEW command
      • VBARUN command
      • -VBARUN command
      • VBASECURITY command
      • VBAUNLOAD command
      • VERSIONCONTROL command
      • VIEW command
      • -VIEW command
      • VIEWBASE command
      • VIEWBREAK command
      • VIEWDETAIL command
      • VIEWDETAILSTYLE command
      • VIEWEDIT command
      • VIEWEXPORT command
      • VIEWHORIZONTAL command
      • VIEWLABEL command
      • VIEWPOINT command
      • VIEWPROJ command
      • VIEWRES command
      • VIEWSECTION command
      • VIEWSECTIONSTYLE command
      • VIEWUPDATE command
      • VISIBILITYSTATES command
      • VISIBLE command
      • VISUALSTYLES command
      • -VISUALSTYLES command
      • VLIDE command
      • VMLOUT command
      • VPCLIP command
      • VPLAYER command
      • VPMAX command
      • VPMIN command
      • VPOINT command
      • VPORTS command
      • -VPORTS command
      • VSCURRENT command
      • VSLIDE command
      • VTOPTIONS command
    • W
      • WBLOCK command
      • -WBLOCK command
      • WCASCADE command
      • WCLOSE command
      • WCLOSEALL command
      • WEBLIGHT command
      • WEDGE command
      • WHOHAS command
      • WHTILE command
      • WIARRANGE command
      • WIPEOUT command
      • WMFOUT command
      • WNEXT command
      • WORKSETS command
      • WORKSPACE command
      • WPREV command
      • WSSAVE command
      • WSSETTINGS command
      • WVTILE command
    • X
      • XATTACH command
      • XCLIP command
      • XEDGES command
      • XFACES command
      • XLINE command
      • XMLSAVE command
      • XOPEN command
      • XPLODE command
      • XREF command
      • -XREF command
    • Y
    • Z
      • ZCENTER command
      • ZINTERSECTION command
      • ZKNOT command
      • ZMIDPOINT command
      • ZNEAREST command
      • ZNONE command
      • ZOOM command
      • ZPERPENDICULAR command
      • ZVERTEX command
  • System variable reference
    • _
      • _PKSER system variable
      • _QUADTABFLAGS システム変数
      • _VERNUM システム変数
    • 3
      • 3DCOMPAREMODE system variable
      • 3DOSMODE システム変数
      • 3DSNAPMARKERCOLOR システム変数
    • A
      • ACADLSPASDOC system variable
      • ACADPREFIX システム変数
      • ACADVER system variable
      • ACISHLRRESOLUTION system variable
      • ACISOUTVER system variable
      • ADAPTIVEGRIDSTEPSIZE システム変数
      • AFLAGS system variable
      • ALLOWTABEXTERNALMOVE system variable
      • ALLOWTABMOVE システム変数
      • ALLOWTABSPLIT system variable
      • ANGBASE システム変数
      • ANGDIR システム変数
      • ANNOALLVISIBLE system variable
      • ANNOAUTOSCALE system variable
      • ANNOSELECTED system variable
      • ANNOTATIVEDWG システム変数
      • ANTIALIASRENDER システム変数
      • ANTIALIASSCREEN system variable
      • APBOX system variable
      • APERTURE システム変数
      • AREA system variable
      • AREAPREC システム変数
      • AREAUNITS システム変数
      • ARRAYASSOCIATIVITY system variable
      • ARRAYEDITSTATE system variable
      • ARRAYTYPE system variable
      • ASSOCIATIVITY system variable
      • ATTDIA システム変数
      • ATTMODE system variable
      • ATTRACTIONDISTANCE system variable
      • ATTREQ システム変数
      • AUDITCTL システム変数
      • AUDITERRORCOUNT システム変数
      • AUNITS システム変数
      • AUPREC system variable
      • AUTOADOPTSIZES system variable
      • AUTOCOMPLETEDELAY システム変数
      • AUTOCOMPLETEMODE system variable
      • AUTOMENULOAD システム変数
      • AUTORESETSCALES システム変数
      • AUTOSAVECHECKSONLYFIRSTBITDBMOD システム変数
      • AUTOSNAP システム変数
      • AUTOTRACKINGVECCOLOR system variable
      • AUTOVPFITTING システム変数
      • AXISMODE system variable
      • AXISUNIT システム変数
    • B
      • BACKGROUNDPLOT system variable
      • BACKZ system variable
      • BASEFILE システム変数
      • BCFSOURCEURL system variable
      • BIMACTIVATEPYTHON system variable
      • BIMOSMODE システム変数
      • BIMPROFILESTANDARDS system variable
      • BINDTYPE system variable
      • BKGCOLOR system variable
      • BKGCOLORPS system variable
      • BLIPMODE システム変数
      • BLOCKEDITLOCK システム変数
      • BLOCKEDITOR system variable
      • BLOCKIFYMODE システム変数
      • BLOCKIFYTOLERANCE システム変数
      • BLOCKSPATH システム変数
      • BMAUTOUPDATE system variable
      • BMFORMTEMPLATEPATH システム変数
      • BMUPDATEMODE システム変数
      • BOUNDARYCOLOR system variable
      • BSYSLIBCOPYOVERWRITE システム変数
      • BVMODE system variable
    • C
      • CACHELAYOUT system variable
      • CAMERADISPLAY システム変数
      • CAMERAHEIGHT system variable
      • CANNOSCALE system variable
      • CANNOSCALEVALUE システム変数
      • CDATE system variable
      • CECOLOR system variable
      • CELTSCALE システム変数
      • CELTYPE system variable
      • CELWEIGHT system variable
      • CENTERCROSSGAP system variable
      • CENTERCROSSSIZE システム変数
      • CENTEREXE システム変数
      • CENTERLAYER system variable
      • CENTERLTSCALE システム変数
      • CENTERLTYPE system variable
      • CENTERLTYPEFILE システム変数
      • CENTERMARKEXE システム変数
      • CETRANSPARENCY システム変数
      • CHAMFERA system variable
      • CHAMFERB system variable
      • CHAMFERC system variable
      • CHAMFERD システム変数
      • CHAMMODE system variable
      • CHECKDWLPRESENCE system variable
      • CIRCLERAD system variable
      • CLAYER システム変数
      • CLEANSCREENOPTIONS system variable
      • CLEANSCREENSTATE システム変数
      • CLIPBOARDFORMAT システム変数
      • CLIPBOARDFORMATS システム変数
      • CLIPROMPTLINES システム変数
      • CLISTATE system variable
      • CLOSECHECKSONLYFIRSTBITDBMOD システム変数
      • CLOUDDOWNLOADPATH system variable
      • CLOUDLOG システム変数
      • CLOUDLOGVERBOSE system variable
      • CLOUDONMODIFIED system variable
      • CLOUDSERVER system variable
      • CLOUDTEMPFOLDER システム変数
      • CLOUDUPLOADDEPENDENCIES システム変数
      • CMATERIAL システム変数
      • CMDACTIVE システム変数
      • CMDDIA システム変数
      • CMDECHO system variable
      • CMDLINEEDITBGCOLOR システム変数
      • CMDLINEEDITFGCOLOR システム変数
      • CMDLINEFADINGLOGBGCOLOR システム変数
      • CMDLINEFADINGLOGFADEDELAY system variable
      • CMDLINEFADINGLOGFGCOLOR システム変数
      • CMDLINEFADINGLOGTRANSPARENCY システム変数
      • CMDLINEFONTNAME system variable
      • CMDLINEFONTSIZE system variable
      • CMDLINEFRAMEACTIVETRANSPARENCY system variable
      • CMDLINEFRAMEINACTIVETRANSPARENCY system variable
      • CMDLINELISTBGCOLOR システム変数
      • CMDLINELISTFGCOLOR システム変数
      • CMDLINEOPTIONBGCOLOR system variable
      • CMDLINEOPTIONSHORTCUTCOLOR システム変数
      • CMDLINEUSENEWFRAME システム変数
      • CMDLNTEXT システム変数
      • CMDNAMES システム変数
      • CMLEADERSTYLE システム変数
      • CMLJUST システム変数
      • CMLSCALE system variable
      • CMLSTYLE システム変数
      • CMPCLRMISS システム変数
      • CMPCLRMOD1 システム変数
      • CMPCLRMOD2 システム変数
      • CMPCLRNEW システム変数
      • CMPDIFFLIMIT system variable
      • CMPFADECTL システム変数
      • CMPLOG system variable
      • COLORBOOKPATH system variable
      • COLORTHEME system variable
      • COLORX システム変数
      • COLORY システム変数
      • COLORZ system variable
      • COMACADCOMPATIBILITY システム変数
      • COMBINETEXTMODE system variable
      • COMMUNICATORPATH システム変数
      • COMPASS system variable
      • COMPONENTSCONFIG システム変数
      • COMPONENTSPATH システム変数
      • CONSTRAINTBARDISPLAY システム変数
      • CONTINUOUSMOTION system variable
      • COORDS system variable
      • COPYMODE system variable
      • CPLOTSTYLE system variable
      • CPROFILE system variable
      • CREATETHUMBNAILONTHEFLY システム変数
      • CREATEVIEWPORTS system variable
      • CROSSHAIRDRAWMODE システム変数
      • CROSSINGAREACOLOR システム変数
      • CTAB システム変数
      • CTABLESTYLE system variable
      • CTRL3DMOUSE システム変数
      • CTRLMOUSE system variable
      • CURSORSIZE システム変数
      • CVPORT システム変数
    • D
      • DATACOLLECTION システム変数
      • DATALINKNOTIFY system variable
      • DATE system variable
      • DBCSTATE system variable
      • DBLCLKEDIT system variable
      • DBMOD system variable
      • DCTCUST システム変数
      • DCTMAIN system variable
      • DEFAULTBSYSLIBIMPERIAL system variable
      • DEFAULTBSYSLIBMETRIC system variable
      • DEFAULTLIGHTING システム変数
      • DEFAULTCURVETYPEHA system variable
      • DEFAULTCURVETYPEVA system variable
      • DEFAULTLIGHTSHADOWBLUR システム変数
      • DEFAULTNEWSHEETTEMPLATE system variable
      • DEFLPLSTYLE system variable
      • DEFPLSTYLE システム変数
      • DELETEINTERFERENCE システム変数
      • DELETETOOL システム変数
      • DELOBJ システム変数
      • DEMANDLOAD システム変数
      • DETAILSPATH system variable
      • DGNEXPXREFMODE システム変数
      • DGNFRAME system variable
      • DGNIMP2DCLOSEDBSPLINECURVEIMPORTMODE system variable
      • DGNIMP2DELLIPSEIMPORTMODE システム変数
      • DGNIMP2DSHAPEIMPORTMODE system variable
      • DGNIMP3DCLOSEDBSPLINECURVEIMPORTMODE system variable
      • DGNIMP3DELLIPSEIMPORTMODE システム変数
      • DGNIMP3DOBJECTIMPORTMODE システム変数
      • DGNIMP3DSHAPEIMPORTMODE system variable
      • DGNIMPBREAKDIMENSIONASSOCIATION システム変数
      • DGNIMPCONVERTDGNCOLORINDICESTOTRUECOLORS system variable
      • DGNIMPCONVERTEMPTYDATAFIELDSTOSPACES system variable
      • DGNIMPERASEUNUSEDRESOURCES system variable
      • DGNIMPEXPLODETEXTNODES システム変数
      • DGNIMPIMPORTACTIVEMODELTOMODELSPACE system variable
      • DGNIMPIMPORTINVISIBLEELEMENTS システム変数
      • DGNIMPIMPORTPAPERSPACEMODELS システム変数
      • DGNIMPIMPORTVIEWINDEX system variable
      • DGNIMPRECOMPUTEDIMENSIONSAFTERIMPORT システム変数
      • DGNIMPSYMBOLRESOURCEFILES system variable
      • DGNIMPXREFIMPORTMODE system variable
      • DGNOSNAP システム変数
      • DIASTAT システム変数
      • DIMADEC system variable
      • DIMALT システム変数
      • DIMALTD システム変数
      • DIMALTF システム変数
      • DIMALTRND システム変数
      • DIMALTTD システム変数
      • DIMALTTZ system variable
      • DIMALTU システム変数
      • DIMALTZ システム変数
      • DIMANNO システム変数
      • DIMAPOST システム変数
      • DIMARCSYM システム変数
      • DIMASO system variable
      • DIMASSOC システム変数
      • DIMASZ システム変数
      • DIMATFIT system variable
      • DIMAUNIT システム変数
      • DIMAZIN システム変数
      • DIMBLK system variable
      • DIMBLK1 システム変数
      • DIMBLK2 system variable
      • DIMCEN system variable
      • DIMCLRD システム変数
      • DIMCLRE システム変数
      • DIMCLRT システム変数
      • DIMDEC system variable
      • DIMDLE system variable
      • DIMDLI system variable
      • DIMDSEP system variable
      • DIMEXE システム変数
      • DIMEXO system variable
      • DIMFIT システム変数
      • DIMFRAC システム変数
      • DIMFXL system variable
      • DIMFXLON システム変数
      • DIMGAP system variable
      • DIMJOGANG system variable
      • DIMJUST system variable
      • DIMLAYER システム変数
      • DIMLDRBLK system variable
      • DIMLFAC システム変数
      • DIMLIM システム変数
      • DIMLTEX1 system variable
      • DIMLTEX2 system variable
      • DIMLTYPE system variable
      • DIMLUNIT system variable
      • DIMLWD system variable
      • DIMLWE system variable
      • DIMPOST システム変数
      • DIMRND システム変数
      • DIMSAH システム変数
      • DIMSCALE system variable
      • DIMSD1 system variable
      • DIMSD2 システム変数
      • DIMSE1 システム変数
      • DIMSE2 システム変数
      • DIMSHO システム変数
      • DIMSOXD システム変数
      • DIMSTYLE system variable
      • DIMTAD システム変数
      • DIMTDEC システム変数
      • DIMTFAC システム変数
      • DIMTFILL システム変数
      • DIMTFILLCLR システム変数
      • DIMTIH システム変数
      • DIMTIX システム変数
      • DIMTM システム変数
      • DIMTMOVE システム変数
      • DIMTOFL システム変数
      • DIMTOH システム変数
      • DIMTOL system variable
      • DIMTOLJ システム変数
      • DIMTP システム変数
      • DIMTSZ システム変数
      • DIMTVP system variable
      • DIMTXSTY system variable
      • DIMTXT system variable
      • DIMTXTDIRECTION システム変数
      • DIMTZIN システム変数
      • DIMUNIT システム変数
      • DIMUPT システム変数
      • DIMZIN system variable
      • DISPLAYAXES system variable
      • DISPLAYSCALING system variable
      • DISPLAYSIDESANDENDS system variable
      • DISPLAYSNAPMARKERINALLVIEWS system variable
      • DISPLAYTOOLTIPS system variable
      • DISPPAPERBKG システム変数
      • DISPPAPERMARGINS system variable
      • DISPSILH システム変数
      • DISTANCE システム変数
      • DMAUDITLEVEL システム変数
      • DMAUTOUPDATE system variable
      • DMCONNECTIONCUTTYPE システム変数
      • DMEXTRUDEMODE system variable
      • DMPUSHPULLSUBTRACT システム変数
      • DMRECOGNIZE system variable
      • DOCKPRIORITY システム変数
      • DOCTABPOSITION システム変数
      • DONUTID system variable
      • DONUTOD システム変数
      • DRAGMODE system variable
      • DRAGMODEHIDE システム変数
      • DRAGMODEINTERRUPT system variable
      • DRAGOPEN system variable
      • DRAGP1 システム変数
      • DRAGP2 システム変数
      • DRAGSNAP system variable
      • DRAWINGPATH システム変数
      • DRAWINGVIEWPRESET system variable
      • DRAWINGVIEWPRESETHIDDEN system variable
      • DRAWINGVIEWPRESETSCALE システム変数
      • DRAWINGVIEWPRESETTANGENT システム変数
      • DRAWINGVIEWPRESETTRAILING システム変数
      • DRAWING VIEWQUALITY システム変数
      • DRAWORDERCTL システム変数
      • DWFFORMAT system variable
      • DWFFRAME システム変数
      • DWFOSNAP システム変数
      • DWFVERSION システム変数
      • DWGCHECK system variable
      • DWGCODEPAGE system variable
      • DWGNAME system variable
      • DWGPREFIX system variable
      • DWGTITLED system variable
      • DXEVAL システム変数
      • DXFTEXTADJUSTALIGNMENT system variable
      • DYNCONSTRAINTMODE system variable
      • DYNDIGRIP system variable
      • DYNDIMAPERTURE システム変数
      • DYNDIMCOLORHOT システム変数
      • DYNDIMCOLORHOVER システム変数
      • DYNDIMDISTANCE システム変数
      • DYNDIMLINETYPE システム変数
      • DYNDIVIS system variable
      • DYNINPUTTRANSPARENCY システム変数
      • DYNMODE system variable
      • DYNPICOORDS システム変数
    • E
      • EDGEMODE system variable
      • ELEVATION system variable
      • ENABLEATTRACTION system variable
      • ENABLEHYPERLINKMENU システム変数
      • ENABLEHYPERLINKTOOLTIP システム変数
      • ERRNO system variable
      • EXPERT システム変数
      • EXPINSALIGN system variable
      • EXPINSANGLE システム変数
      • EXPINSFIXANGLE システム変数
      • EXPINSFIXSCALE system variable
      • EXPINSSCALE システム変数
      • EXPLMODE システム変数
      • EXPORTACISFORMATVERSION system variable
      • EXPORTMODELSPACE system variable
      • EXPORTPAGESETUP システム変数
      • EXPORTPAPERSPACE システム変数
      • EXTMAX system variable
      • EXTMIN システム変数
      • EXTNAMES system variable
    • F
      • FACETRATIO system variable
      • FACETRES system variable
      • FBXEXPORTCAMERAS system variable
      • FBXEXPORTENTITIES システム変数
      • FBXEXPORTENTITIESSELTYPE system variable
      • FBXEXPORTLIGHTS システム変数
      • FBXEXPORTMATERIALS システム変数
      • FBXEXPORTTEXTURES システム変数
      • FBXEXPORTTEXTURESPATH system variable
      • FEATURECOLORS system variable
      • FIELDDISPLAY system variable
      • FIELDEVAL システム変数
      • FILEDIA system variable
      • FILLETRAD システム変数
      • FILLMODE システム変数
      • FLOORTOFLOORDISTANCE system variable
      • FONTALT システム変数
      • FONTMAP system variable
      • FRAME system variable
      • FRAMESELECTION システム変数
      • FRONTZ system variable
      • FULLOPEN system variable
    • G
      • GENERATEASSOCATTRS システム変数
      • GENERATEASSOCVIEWS システム変数
      • GEOLATLONGFORMAT システム変数
      • GEOMARKERVISIBILITY system variable
      • GEOMRELATIONS システム変数
      • GETSTARTED system variable
      • GFANG system variable
      • GFCLR1 システム変数
      • GFCLR2 システム変数
      • GFCLRLUM システム変数
      • GFCLRSTATE system variable
      • GFNAME system variable
      • GFSHIFT システム変数
      • GLSWAPMODE システム変数
      • GRADIENTCOLORBOTTOM システム変数
      • GRADIENTCOLORMIDDLE system variable
      • GRADIENTCOLORTOP システム変数
      • GRADIENTMODE システム変数
      • GRIDAXISCOLOR システム変数
      • GRIDDISPLAY システム変数
      • GRIDMAJOR system variable
      • GRIDMAJORCOLOR system variable
      • GRIDMINORCOLOR システム変数
      • GRIDMODE システム変数
      • GRIDSTYLE システム変数
      • GRIDUNIT システム変数
      • GRIDXYZTINT system variable
      • GRIPBLOCK システム変数
      • GRIPCOLOR システム変数
      • GRIPDYNCOLOR system variable
      • GRIPHOT システム変数
      • GRIPHOVER システム変数
      • GRIPOBJLIMIT system variable
      • GRIPS システム変数
      • GRIPSIZE システム変数
      • GRIPTIPS system variable
      • GSDEVICETYPE2D system variable
      • GSDEVICETYPE3D system variable
    • H
      • HALOGAP システム変数
      • HANDLES システム変数
      • HANDSEED system variable
      • HIDEPRECISION system variable
      • HIDESYSTEMPRINTERS システム変数
      • HIDETEXT システム変数
      • HIDEXREFSCALES system variable
      • HIGHLIGHT system variable
      • HIGHLIGHTCOLOR システム変数
      • HIGHLIGHTEFFECT system variable
      • HORIZONBKG_ENABLE システム変数
      • HORIZONBKG_GROUNDHORIZON system variable
      • HORIZONBKG_GROUNDORIGIN システム変数
      • HORIZONBKG_SKYHIGH system variable
      • HORIZONBKG_SKYHORIZON システム変数
      • HORIZONBKG_SKYLOW システム変数
      • HOTKEYASSISTANT システム変数
      • HPANG system variable
      • HPANNOTATIVE system variable
      • HPASSOC システム変数
      • HPBACKGROUNDCOLOR システム変数
      • HPBOUND システム変数
      • HPBOUNDRETAIN システム変数
      • HPCOLOR system variable
      • HPDOUBLE システム変数
      • HPDRAWORDER システム変数
      • HPGAPTOL システム変数
      • HPISLANDDETECTION システム変数
      • HPLAYER システム変数
      • HPLINETYPE システム変数
      • HPMAXAREAS system variable
      • HPNAME システム変数
      • HPOBJWARNING system variable
      • HPORIGIN システム変数
      • HPSCALE system variable
      • HPSEPARATE システム変数
      • HPSPACE system variable
      • HPTRANSPARENCY system variable
      • HYPERLINKBASE システム変数
    • I
      • IMAGECACHEFOLDER システム変数
      • IMAGECACHEMAXMEMORY system variable
      • IMAGEDISKCACHE システム変数
      • IMAGEFRAME system variable
      • IMAGEHLT システム変数
      • IMAGENOTIFY system variable
      • IMPORTCUIFILEEXISTS system variable
      • IMPORTPRODUCTSTRUCTURE system variable
      • IMPORTREPAIR system variable
      • INCLUDEPLOTSTAMP システム変数
      • INDEXCTLシステム変数
      • INETLOCATION システム変数
      • INSBASE システム変数
      • INSNAME system variable
      • INSUNITS system variable
      • INSUNITSDEFSOURCE システム変数
      • INSUNITSDEFTARGET システム変数
      • INSUNITSSCALING システム変数
      • INTERFERECOLOR システム変数
      • INTERFERELAYER system variable
      • INTERFEREOBJVS システム変数
      • INTERFEREVPVS system variable
      • INTERSECTIONCOLOR system variable
      • INTERSECTIONDISPLAY system variable
      • ISAVEBAK system variable
      • ISAVEPERCENT system variable
      • ISOLINESシステム変数
    • J
    • K
    • L
      • LASTANGLE system variable
      • LASTPOINT system variable
      • LASTPROMPT システム変数
      • LATITUDE システム変数
      • LAYERFILTEREXCESS system variable
      • LAYERPMODE システム変数
      • LAYLOCKFADECTL システム変数
      • LAYOUTREGENCTL system variable
      • LAYOUTTAB system variable
      • LEGACYCODESEARCH システム変数
      • LENGTHUNITS システム変数
      • LENSLENGTH system variable
      • LEVELOFDETAIL system variable
      • LICFLAGS システム変数
      • LIGHTGLYPHCOLOR システム変数
      • LIGHTGLYPHDISPLAY システム変数
      • LIGHTINGUNITS システム変数
      • LIGHTWEBGLYPHCOLOR system variable
      • LIMCHECK システム変数
      • LIMMAX system variable
      • LIMMIN system variable
      • LINEARBRIGHTNESS システム変数
      • LINEARCONTRAST system variable
      • LISPINIT system variable
      • LOADMECHANICAL2D システム変数
      • LOCALE system variable
      • LOCALROOTPREFIX システム変数
      • LOCKUI system variable
      • LOFTANG1 system variable
      • LOFTANG2 システム変数
      • LOFTMAG1 システム変数
      • LOFTMAG2 システム変数
      • LOFTNORMALS システム変数
      • LOFTPARAM システム変数
      • LOGFILEMODE システム変数
      • LOGFILENAME system variable
      • LOGFILEPATH システム変数
      • LOGGEDIN システム変数
      • LOGINNAME system variable
      • LONGITUDE システム変数
      • LOOKFROMDIRECTIONMODE システム変数
      • LOOKFROMFEEDBACK system variable
      • LOOKFROMZOOMXTENTS システム変数
      • LTGAPSELECTION system variable
      • LTSCALE システム変数
      • LUNITS system variable
      • LUPREC システム変数
      • LWDEFAULT system variable
      • LWDISPLAY システム変数
      • LWDISPSCALE system variable
      • LWUNITS system variable
    • M
      • MACROREC system variable
      • MACROTRACE システム変数
      • MAKEBAK システム変数
      • MANIPULATOR システム変数
      • MANIPULATORCOLORTHEME system variable
      • MANIPULATORDURATION システム変数
      • MANIPULATORHANDLE system variable
      • MANIPULATORSIZE システム変数
      • MASSPREC システム変数
      • MASSPROPACCURACY システム変数
      • MASSUNITS システム変数
      • MAXACTVP システム変数
      • MAXHATCH システム変数
      • MAXSORTシステム変数
      • MAXTHREADS system variable
      • MBSTATE システム変数
      • MBUTTONPAN system variable
      • MEASUREINIT システム変数
      • MEASUREMENT system variable
      • MECH2DSAVEFORMAT システム変数
      • MENUBAR (EXCEPT OS X) システム変数
      • MENUCTL system variable
      • MENUECHO system variable
      • MENUNAME システム変数
      • MESHTYPE システム変数
      • MIDDLECLICKCLOSE システム変数
      • MILLISECS system variable
      • MIRRTEXT system variable
      • MLEADERSCALE システム変数
      • MODEMACRO system variable
      • MSLTSCALE system variable
      • MSOLESCALE システム変数
      • MTEXTCOLUMN system variable
      • MTEXTDETECTSPACE システム変数
      • MTEXTED system variable
      • MTEXTFIXED system variable
      • MTEXTTOOLBAR システム変数
      • MTFLAGS システム変数
      • MYDOCUMENTSFOLDER システム変数
      • MYDOCUMENTSPREFIX system variable
      • MECHANICALBROWSERSETTINGS system variable
    • N
      • NAVVCUBEDISPLAY システム変数
      • NAVVCUBELOCATION システム変数
      • NAVVCUBEOPACITY システム変数
      • NAVVCUBEORIENT system variable
      • NAVVCUBESIZE システム変数
      • NEARESTDISTANCE システム変数
      • NOMUTT system variable
      • NORTHDIRECTION システム変数
    • O
      • OBJECTISOLATIONMODE system variable
      • OBSCUREDCOLOR システム変数
      • OBSCUREDLTYPE システム変数
      • OFFSETDIST system variable
      • OFFSETERASE システム変数
      • OFFSETGAPTYPE system variable
      • OLEFRAME システム変数
      • OLEHIDE システム変数
      • OLEQUALITY システム変数
      • OLESTARTUP system variable
      • OPMSTATE system variable
      • ORBITAUTOTARGET system variable
      • ORTHOMODE システム変数
      • OSMODE システム変数
      • OSNAPCOORD system variable
      • OSNAPZ システム変数
      • OSOPTIONS システム変数
      • OVERKILLLAYER システム変数
    • P
      • PANBUFFER system variable
      • PANELBUTTONSIZE system variable
      • PAPERUPDATE システム変数
      • PARAMETERCOPYMODE system variable
      • PARAMETRICBLOCKS2DPATH システム変数
      • PDFCACHE システム変数
      • PDFEMBEDDEDTTF system variable
      • PDFEXPORTHYPERLINKS システム変数
      • PDFEXPORTSOLIDHATCHTYPE システム変数
      • PDFFRAME system variable
      • PDFHATCHTOBMPDPI システム変数
      • PDFIMAGEANTIALIAS system variable
      • PDFIMAGECOMPRESSION システム変数
      • PDFIMAGEDPI system variable
      • PDFIMPORTAPPLYLINEWEIGHT システム変数
      • PDFIMPORTASBLOCK システム変数
      • PDFIMPORTCONVERTSOLIDSTOHATCHES システム変数
      • PDFIMPORTIMAGEPATH システム変数
      • PDFIMPORTJOINLINEANDARCSEGMENTS system variable
      • PDFIMPORTLAYERSUSETYPE system variable
      • PDFIMPORTRASTERIMAGES system variable
      • PDFIMPORTSOLIDFILLS system variable
      • PDFIMPORTTRUETYPETEXT システム変数
      • PDFIMPORTTRUETYPETEXTASGEOMETRY システム変数
      • PDFIMPORTUSEGEOMETRYOPTIMIZATION system variable
      • PDFIMPORTVECTORGEOMETRY システム変数
      • PDFLAYERSSETTING system variable
      • PDFLAYOUTSTOEXPORT system variable
      • PDFMERGECONTROL システム変数
      • PDFNOTIFY system variable
      • PDFOSNAP system variable
      • PDFPAPERHEIGHT システム変数
      • PDFPAPERSIZEOVERRIDE system variable
      • PDFPAPERWIDTH システム変数
      • PDFPRCCOMPRESSION system variable
      • PDFPRCEXPORT system variable
      • PDFPRCEXPORTPRODUCTSTRUCTUREMODE システム変数
      • PDFPRCSINGLEVIEWMODE system variable
      • PDFRENDERDPI system variable
      • PDFSHXTEXTASGEOMETRY システム変数
      • PDFSIMPLEGEOMOPTIMIZATION システム変数
      • PDFTTFTEXTASGEOMETRY system variable
      • PDFUSEPLOTSTYLES system variable
      • PDFVECTORRESOLUTIONDPI system variable
      • PDFZOOMTOEXTENTSMODE system variable
      • PDMODE system variable
      • PDSIZE system variable
      • PEDITACCEPT システム変数
      • PELLIPSE system variable
      • PERIMETER システム変数
      • PERSPECTIVE system variable
      • PFACEVMAX system variable
      • PHANDLE システム変数
      • PICKADD システム変数
      • PICKAUTO システム変数
      • PICKBOX システム変数
      • PICKDRAG システム変数
      • PICKFIRST system variable
      • PICKSTYLE (EXCEPT OS X) system variable
      • PICTUREEXPORTSCALE system variable
      • PLACESBARFOLDER1 システム変数
      • PLACESBARFOLDER2 system variable
      • PLACESBARFOLDER3 システム変数
      • PLACESBARFOLDER4 system variable
      • PLATFORMシステム変数
      • PLINECACHE system variable
      • PLINECONVERTMODE system variable
      • PLINEGENシステム変数
      • PLINETYPE システム変数
      • PLINEWID システム変数
      • PLOTCFGPATH system variable
      • PLOTID システム変数
      • PLOTOUTPUTPATH システム変数
      • PLOTROTMODE system variable
      • PLOTSTYLEPATH システム変数
      • PLOTTER システム変数
      • PLOTTRANSPARENCYOVERRIDE システム変数
      • PLQUIET システム変数
      • POINTCLOUD2DVSDISPLAY system variable
      • POINTCLOUDADAPTIVEDISPLAY システム変数
      • POINTCLOUDBOUNDARY system variable
      • POINTCLOUDCACHEFOLDER system variable
      • POINTCLOUDCACHESIZE システム変数
      • POINTCLOUDPOINTMAX システム変数
      • POINTCLOUDPOINTSIZE システム変数
      • POLARADDANG システム変数
      • POLARANG システム変数
      • POLARDIST システム変数
      • POLARMODE system variable
      • POLYSIDES system variable
      • POPUPS システム変数
      • PREVIEW_HEIGHT system variable
      • PREVIEW_WIDTH system variable
      • PREVIEWDELAY system variable
      • PREVIEWEFFECT システム変数
      • PREVIEWFILTER システム変数
      • PREVIEWTYPE システム変数
      • PREVIEWWNDINOPENDLG システム変数
      • PRINTFILE system variable
      • PRINTPDFPREVIEW system variable
      • PRODUCT システム変数
      • PROGBAR システム変数
      • PROGRAM システム変数
      • PROJECTIONTYPE system variable
      • PROJECTNAME システム変数
      • PROJECTSEARCHPATHS システム変数
      • PROJMODE system variable
      • PROMPTMENU システム変数
      • PROMPTMENUFLAGS システム変数
      • PROMPTOPTIONFORMAT system variable
      • PROMPTOPTIONTRANSLATEKEYWORDS system variable
      • PROPERTYPREVIEW system variable
      • PROPERTYPREVIEWDELAY システム変数
      • PROPERTYPREVIEWOBJLIMIT system variable
      • PROPPREVTIMEOUT システム変数
      • PROPUNITS システム変数
      • PROXYGRAPHICS system variable
      • PROXYNOTICE system variable
      • PROXYSHOW システム変数
      • PROXYWEBSEARCH system variable
      • PSLTSCALE system variable
      • PSOLHEIGHT システム変数
      • PSOLWIDTH システム変数
      • PSPROLOG system variable
      • PSQUALITY システム変数
      • PSTYLEMODE システム変数
      • PSTYLEPOLICY システム変数
      • PSVPSCALE システム変数
      • PUBLISHALLSHEETS システム変数
      • PUCSBASE system variable
    • Q
      • QAFLAGS システム変数
      • QTEXTMODE システム変数
      • QUADCOMMANDLAUNCH system variable
      • QUADDISPLAY システム変数
      • QUADEXPANDDELAY システム変数
      • QUADEXPANDTABDELAY system variable
      • QUADGOTRANSPARENT システム変数
      • QUADHIDEDELAY system variable
      • QUADHIDEMARGIN システム変数
      • QUADICONSIZE system variable
      • QUADICONSPACE システム変数
      • QUADMOSTRECENTITEMS system variable
      • QUADPOPUPCORNER システム変数
      • QUADROLLOVERDELAY system variable
      • QUADSHOWDELAY system variable
      • QUADWIDTH system variable
    • R
      • R12SAVEACCURACY system variable
      • R12SAVEDEVIATION システム変数
      • RASTERPREVIEW system variable
      • RE_INIT システム変数
      • REALTIMESPEEDUP system variable
      • REALWORLDSCALE システム変数
      • RECENTFILES システム変数
      • RECENTPATH system variable
      • REDHILITE_DUCSLOCKED_FACE_ALPHA system variable
      • REDHILITE_DUCSLOCKED_FACE_COLOR system variable
      • REDHILITE_HIDDENEDGE_ALPHA システム変数
      • REDHILITE_HIDDENEDGE_COLOR システム変数
      • REDHILITEFULL_EDGE_ALPHA システム変数
      • REDHILITEFULL_EDGE_COLOR system variable
      • REDHILITEFULL_EDGE_SHOWHIDDEN システム変数
      • REDHILITEFULL_EDGE_SMOOTHING システム変数
      • REDHILITEFULL_EDGE_THICKNESS システム変数
      • REDHILITEFULL_FACE_ALPHA system variable
      • REDHILITEFULL_FACE_COLOR システム変数
      • REDHILITEPARTIAL_SELECTEDEDGE_ALPHA system variable
      • REDHILITEPARTIAL_SELECTEDEDGE_COLOR システム変数
      • REDHILITEPARTIAL_SELECTEDEDGE_SHOWGLOW システム変数
      • REDHILITEPARTIAL_SELECTEDEDGE_SMOOTHING システム変数
      • REDHILITEPARTIAL_SELECTEDEDGE_THICKNESS システム変数
      • REDHILITEPARTIAL_SELECTEDEDGEGLOW_ALPHA システム変数
      • REDHILITEPARTIAL_SELECTEDEDGEGLOW_COLOR システム変数
      • REDHILITEPARTIAL_SELECTEDEDGEGLOW_SMOOTHING システム変数
      • REDHILITEPARTIAL_SELECTEDEDGEGLOW_THICKNESS system variable
      • REDHILITEPARTIAL_SELECTEDFACE_ALPHA system variable
      • REDHILITEPARTIAL_SELECTEDFACE_COLOR システム変数
      • REDHILITEPARTIAL_UNSELECTEDEDGE_SHOWHIDDEN システム変数
      • REDSDKLINESMOOTHING システム変数
      • REFEDITLOCKNOTINWORKSET system variable
      • REFEDITNAME system variable
      • REGENMODE システム変数
      • REGEXPAND system variable
      • REMEMBERFOLDERS system variable
      • RENDERCOMPOSITIONMATERIAL system variable
      • RENDERMATERIALDOWNLOAD system variable
      • RENDERMATERIALSPATH システム変数
      • RENDERUSINGHARDWARE system variable
      • REPORTPANELMODE system variable
      • REPOSITORYFOLDER system variable
      • RESTORELOSTFOCUS システム変数
      • RETINADISPLAY システム変数
      • REVCLOUDARCSTYLE システム変数
      • REVCLOUDCREATEMODE システム変数
      • REVCLOUDGRIPS system variable
      • REVCLOUDMAXARCLENGTH システム変数
      • REVCLOUDMINARCLENGTH システム変数
      • RHINOVERSION システム変数
      • RIBBONDOCKEDHEIGHT system variable
      • RIBBONPANELMARGIN system variable
      • RIBBONSTATE system variable
      • RIBBONTOOLSIZE system variable
      • ROAMABLEROOTFOLDER システム変数
      • ROAMABLEROOTPREFIX システム変数
      • ROLLOVEROPACITY システム変数
      • ROLLOVERSELECTIONSET system variable
      • ROLLOVERTIPS システム変数
      • RTDISPLAY system variable
      • RTROTATIONSPEEDFACTOR system variable
      • RUBBERBANDCOLOR system variable
      • RUBBERBANDSTYLE system variable
      • RUBBERSHEET (for OS X) system variable
      • RUBBERSHEETSENSIBILITY (FOR OS X) システム変数
      • RUNASLEVEL system variable
    • S
      • SAFEMODE system variable
      • SAVECHANGETOLAYOUT system variable
      • SAVEFIDELITY システム変数
      • SAVEFILE システム変数
      • SAVEFILEPATH system variable
      • SAVEFORMAT システム変数
      • SAVELAYERSNAPSHOT システム変数
      • SAVENAME システム変数
      • SAVEONDOCSWITCH system variable
      • SAVEROUNDTRIP system variable
      • SAVETIME システム変数
      • SCREENBOXES system variable
      • SCREENMODE システム変数
      • SCREENSIZE システム変数
      • SCRLHIST システム変数
      • SDI system variable
      • SECURELOAD system variable
      • SECTIONSETTINGSSEARCHPATH system variable
      • SELECTIONANNODISPLAY system variable
      • SELECTIONAREA システム変数
      • SELECTIONAREAOPACITY system variable
      • SELECTIONMODES system variable
      • SELECTIONPREVIEW system variable
      • SELECTSIMILARMODE システム変数
      • SETBYLAYERMODE system variable
      • SHADEDGE system variable
      • SHADEDIF system variable
      • SHEETNUMBERLEADINGZEROES system variable
      • SHEETSETAUTOBACKUP システム変数
      • SHEETSETTEMPLATEPATH システム変数
      • SHORTCUTMENU システム変数
      • SHORTCUTMENUDURATION system variable
      • SHOWDOCTABS system variable
      • SHOWFULLPATHINTITLE システム変数
      • SHOWLAYERUSAGE システム変数
      • SHOWSCROLLBUTTONS system variable
      • SHOWTABCLOSEBUTTON システム変数
      • SHOWTABCLOSEBUTTONACTIVE system variable
      • SHOWTABCLOSEBUTTONALL システム変数
      • SHOWWINDOWLISTBUTTON システム変数
      • SHPNAME system variable
      • SINGLETONMODE システム変数
      • SKETCHINC system variable
      • SKPOLY システム変数
      • SKYSTATUS system variable
      • SLABTHICKNESS system variable
      • SMASSEMBLYEXPORTMODE システム変数
      • SMASSEMBLYEXPORTREPORTPATHTYPE system variable
      • SMASSEMBLYEXPORTSOLIDTYPESINREPORTS system variable
      • SMATTRIBUTESLAYERCOLOR system variable
      • SMATTRIBUTESLAYERTEXTHEIGHT system variable
      • SMATTRIBUTESLAYERTEXTHEIGHTTYPE system variable
      • SMBENDANNOTATIONSLAYERCOLOR system variable
      • SMBENDANNOTATIONSLAYERTEXTHEIGHT system variable
      • SMBENDANNOTATIONSLAYERTEXTHEIGHTTYPE system variable
      • SMBENDLINESUPLAYERCOLOR system variable
      • SMBENDLINESUPLAYERLINETYPE system variable
      • SMBENDLINESUPLAYERLINEWEIGHT system variable
      • SMBENDLINESDOWNLAYERCOLOR system variable
      • SMBENDLINESDOWNLAYERLINETYPE system variable
      • SMBENDLINESDOWNLAYERLINEWEIGHT system variable
      • SMCOLORBEND system variable
      • SMCOLORBENDRELIEF system variable
      • SMCOLORBEVEL system variable
      • SMCOLORCORNERRELIEF system variable
      • SMCONTOURSLAYERLINETYPE system variable
      • SMCONTOURSLAYERLINEWEIGHT system variable
      • SMCONTOURSLAYERCOLOR system variable
      • SMCONVERTMAXIMALBEVELANGLE system variable
      • SMCONVERTMINIMALBEVELANGLE system variable
      • SMCONVERTPREFERFORMFEATURES system variable
      • SMCONVERTPREFERHEMFEATURES system variable
      • SMCONVERTPREFERZEROBENDFEATURES system variable
      • SMCONVERTRECOGNIZEHOLES system variable
      • SMCONVERTRECOGNIZERIBCONTROLCURVES system variable
      • SMCONVERTWRONGFEATURETHICKNESSDEVIATIONTYPE system variable
      • SMCONVERTWRONGFEATURETHICKNESSDEVIATIONVALUE system variable
      • SMDEFAULTKFACTOR system variable
      • SMDEFAULTHEMRELATIVEBENDDEDUCTION system variable
      • SMDEFAULTFORMFEATUREUNFOLDMODE system variable
      • SMDEFAULTBENDLINEEXTENTTYPE system variable
      • SMDEFAULTBENDLINEEXTENTVALUE system variable
      • SMDEFAULTBEVELFEATUREUNFOLDMODE system variable
      • SMEXPORTOSMAPPROXIMATIONACCURACY system variable
      • SMEXPORTOSMMINIMALEDGELENGTH system variable
      • SMFORMFEATURESUPCOLOR system variable
      • SMFORMFEATURESUPLAYERLINETYPE system variable
      • SMFORMFEATURESDOWNCOLOR system variable
      • SMFORMFEATURESUPLAYERLINEWEIGHT system variable
      • SMFORMFEATURESDOWNLAYERLINETYPE system variable
      • SMFORMFEATURESDOWNLAYERLINEWEIGHT system variable
      • SMJUNCTIONCREATEHEALCOINCIDENT system variable
      • SMOOTHMESHCONVERT システム変数
      • SMPARAMETRIZEHOLESPARAMETRIZATION system variable
      • SMREPAIRLOFTEDBENDMERGE system variable
      • SMSMARTFEATURES システム変数
      • SMSPLITAMBIGUOUSINPUT system variable
      • SMSPLITCONVERTBENDTOJUNCTION system variable
      • SMSPLITHEALCOINCIDENT system variable
      • SMSPLITORTHOGONALBENDSPLIT system variable
      • SMTARGETCAM system variable
      • SMOVERALLANNOTATIONSLAYERCOLOR system variable
      • SMOVERALLANNOTATIONSLAYERLINETYPE system variable
      • SMOVERALLANNOTATIONSLAYERLINEWEIGHT system variable
      • SMBEVELFEATURECOLOR system variable
      • SNAPANG system variable
      • SNAPBASE システム変数
      • SNAPCOLOR システム変数
      • SNAPISOPAIR system variable
      • SNAPMARKERCOLOR system variable
      • SNAPMARKERSIZE システム変数
      • SNAPMARKERTHICKNESS システム変数
      • SNAPMODE システム変数
      • SNAPSIZE システム変数
      • SNAPSTYL system variable
      • SNAPTHICKNESS システム変数
      • SNAPTYPE システム変数
      • SNAPUNIT system variable
      • SOLIDCHECK システム変数
      • SORTENTS システム変数
      • SPAADJUSTMODE システム変数
      • SPACHECKLEVEL システム変数
      • SPAGRIDASPECTRATIO システム変数
      • SPAGRIDMODE system variable
      • SPAMAXFACETEDGELENGTH system variable
      • SPAMAXNUMGRIDLINES system variable
      • SPAMINUGRIDLINES システム変数
      • SPAMINVGRIDLINES システム変数
      • SPANORMALTOL system variable
      • SPASURFACETOL system variable
      • SPATRIANGMODE system variable
      • SPAUSEFACETRES system variable
      • SPLFRAME system variable
      • SPLINESEGS system variable
      • SPLINETYPE system variable
      • SRCHPATH システム変数
      • SSFOUND システム変数
      • SSLOCATE システム変数
      • SSMAUTOOPEN system variable
      • SSMPOLLTIME システム変数
      • SSMSHEETSTATUS システム変数
      • SSMSTATE システム変数
      • STACKPANELTYPE システム変数
      • STAMPFONTSIZE system variable
      • STAMPFONTSTYLE system variable
      • STAMPFOOTER システム変数
      • STAMPFOOTEROFFSETX system variable
      • STAMPFOOTEROFFSETY システム変数
      • STAMPHEADER system variable
      • STAMPHEADEROFFSETX システム変数
      • STAMPHEADEROFFSETY system variable
      • STAMPUNITS システム変数
      • STARTUP システム変数
      • STARTUPTODAY システム変数
      • STATUSBAR システム変数
      • STEPSIZEシステム変数
      • STEPSPERSECシステム変数
      • STLPOSITIVEQUADRANT システム変数
      • STRUCTUREDISPLAYMODE システム変数
      • STRUCTURETREECONFIG system variable
      • SURFTAB1 system variable
      • SURFTAB2 システム変数
      • SURFTYPE システム変数
      • SURFU システム変数
      • SURFV system variable
      • SVGBLENDEDGRADIENTS システム変数
      • SVGDEFAULTIMAGEEXTENSION システム変数
      • SVGGENERICFONTFAMILY system variable
      • SVGIMAGEBASE system variable
      • SVGIMAGEURL system variable
      • SVGLINEWEIGHTSCALE system variable
      • SVGOUTPUTHEIGHT system variable
      • SVGOUTPUTWIDTH システム変数
      • SVGPRECISION system variable
      • SVGSCALEFACTOR system variable
      • SYSCODEPAGE システム変数
    • T
      • TABCONTROLHEIGHT system variable
      • TABMODE システム変数
      • TABSFIXEDWIDTH system variable
      • TARGET システム変数
      • TDCREATE system variable
      • TDINDWG システム変数
      • TDUCREATE system variable
      • TDUPDATE システム変数
      • TDUSRTIMER system variable
      • TDUUPDATE システム変数
      • TEMPLATEPATH システム変数
      • TEMPPREFIX system variable
      • TEXTANGLE システム変数
      • TEXTED システム変数
      • TEXTEDITMODE システム変数
      • TEXTEVAL system variable
      • TEXTFILL システム変数
      • TEXTQLTY システム変数
      • TEXTSIZE system variable
      • TEXTSTYLE system variable
      • TEXTUREMAPPATH システム変数
      • THICKNESS システム変数
      • THUMBSIZE system variable
      • TILEMODE system variable
      • TILEMODELIGHTSYNCH system variable
      • TIMEZONE system variable
      • TOOLBARMARGIN システム変数
      • TOOLBUTTONSIZE システム変数
      • TOOLICONPADDING システム変数
      • TOOLPALETTEPATH system variable
      • TOOLTIPDELAY システム変数
      • TOOLTIPS システム変数
      • TPSTATE システム変数
      • TRACEWID システム変数
      • TRACKPATH system variable
      • TRANSPARENCYDISPLAY system variable
      • TRAYICONS システム変数
      • TRAYNOTIFY システム変数
      • TRAYTIMEOUT システム変数
      • TREEDEPTH system variable
      • TREEMAX システム変数
      • TRIMMODE system variable
      • TRUSTEDPATHS system variable
      • TSPACEFAC system variable
      • TSPACETYPE システム変数
      • TSTACKALIGN システム変数
      • TSTACKSIZE システム変数
      • TTFASTEXT システム変数
    • U
      • UCSAXISANG system variable
      • UCSBASE system variable
      • UCSDETECT システム変数
      • UCSFOLLOW system variable
      • UCSICON system variable
      • UCSICONPOS システム変数
      • UCSNAME システム変数
      • UCSORG system variable
      • UCSORTHO システム変数
      • UCSVIEW システム変数
      • UCSVP system variable
      • UCSXDIR system variable
      • UCSYDIR システム変数
      • UNDOCTL system variable
      • UNDOMARKS システム変数
      • UNITMODE system variable
      • USECOMMUNICATOR システム変数
      • USERI1 システム変数
      • USERI2 システム変数
      • USERI3 システム変数
      • USERI4 system variable
      • USERI5 system variable
      • USERR1 system variable
      • USERR2 system variable
      • USERR3 システム変数
      • USERR4 システム変数
      • USERR5 システム変数
      • USERS1 system variable
      • USERS2 システム変数
      • USERS3 システム変数
      • USERS4 システム変数
      • USERS5 system variable
      • USESTANDARDOPENFILEDIALOG system variable
      • USRTIMER system variable
    • V
      • VBAMACROS system variable
      • VENDORNAME システム変数
      • VERSIONCONTROLPATH system variable
      • VERSIONCUSTOMIZABLEFILES システム変数
      • VIEWCTR システム変数
      • VIEWDIR システム変数
      • VIEWMODE system variable
      • VIEWSIZE system variable
      • VIEWTWIST システム変数
      • VIEWUPDATEAUTO system variable
      • VISRETAIN システム変数
      • VOLUMEPREC システム変数
      • VOLUMEUNITS システム変数
      • VPMAXIMIZEDSTATE システム変数
      • VPROTATEASSOC system variable
      • VSMAX system variable
      • VSMIN system variable
      • VTDURATION システム変数
      • VTENABLE システム変数
      • VTFPS システム変数
    • W
      • WALLWIDTH system variable
      • WARNINGMESSAGES system variable
      • WHIPARC system variable
      • WHIPTHREAD system variable
      • WINDOWAREACOLOR システム変数
      • WIPEOUTFRAME システム変数
      • WMFBKGND システム変数
      • WMFFOREGND system variable
      • WNDLMAIN システム変数
      • WNDLSCRL system variable
      • WNDLTEXT システム変数
      • WNDPMAIN system variable
      • WNDPTEXT システム変数
      • WNDSMAIN システム変数
      • WNDSTEXT システム変数
      • WORLDUCS システム変数
      • WORLDVIEW システム変数
      • WRITESTAT システム変数
      • WSAUTOSAVE システム変数
      • WSCURRENT システム変数
    • X
      • XCLIPFRAME system variable
      • XDWGFADECTL システム変数
      • XEDIT system variable
      • XFADECTL システム変数
      • XLOADCTL システム変数
      • XLOADPATH system variable
      • XNOTIFYTIME システム変数
      • XREFCTL システム変数
      • XREFNOTIFY システム変数
      • XREFOVERRIDE system variable
    • Y
    • Z
      • ZOOMFACTOR システム変数
      • ZOOMWHEEL システム変数
New Multileader Style dialog box
The New Multileader Style dialog box allows you to create a new multileader style.
  1. Name
  2. Base new Multileader Style on
Name
Sets the name of the new multileader style.
Selects an existing style to create the new one as a copy of it. To start from scratch, select <None>.
Parent topic: Dialog boxes
Related commands
  • MLEADER command
  • EXPLORER command
  • BMBALLOON command
  • DIMLEADER command
  • LEADER command
  • QLEADER command
© 2025 Bricsys NV. All rights reserved.Privacy statement -Terms of use -Cookie statement
