Bricsys Help Center
Home
Document tabs
BricsCAD
What's new in BricsCAD V21
Overview
User interface
Productivity
Drafting
Modeling
Civil tools
Performance and compatibility
Installation and licensing
Installing BricsCAD
Minimum system requirements and recommendations
Downloading BricsCAD
Overview of install options
Interactive installation
Silent Installation (Windows only)
Trial mode
Activating and licensing BricsCAD
Overview of licensing options
License levels
License types
Additional license options
BricsCAD and AutoCAD feature comparison
Trial: online activation
Trial: offline (manual) activation
Single or volume license: online activation
Single or volume license: offline (manual) activation
Using a network license on a client computer
Setting up a network license server
Network license server
Quick guide on using a network license
Setting up a Windows network license server
Setting up a Linux license server
Network license: online activation
Network license: offline (manual) activation
Network license server administration
Advanced configurations
Managing licenses
Modifying a BricsCAD license
Deactivating or revoking a BricsCAD license
Migrating a single or volume license to another computer
Migrating a network license to another server
License pooling
Network license usage report
Roaming
Roaming a network license on a client computer
Returning a roamed network license to the server
Proxy settings on a client computer
Getting started with BricsCAD
Launching BricsCAD
Exploring the interface
The Start tab
Document tabs
Choosing the workspace
The drawing area
The Command line
メニュー
Toolbars
The ribbon
The Quad basics
Right-click menus
The status bar
Panels
The clean screen mode
Look From widget
Working in BricsCAD
Creating a drawing
Template drawings
Entity creation settings
How to draw accurately
Executing commands
View control
Selecting entities
Using the Manipulator
Working with the Structure panel
User interface
The BricsCAD application window
The Command line
The Status bar
Document tabs
Toolbars
The Quad cursor menu
Rollover tips
Prompt menus
Keyboard shortcuts
Digitizing tablet
Panels
Animation editor panel
Attachments panel
BIM BCF panel
BIM compositions panel
BIM profiles panel
BIM project browser panel
BOM manager panel
Bricsys 24/7 panel
Command line panel
Content browser panel
Details panel
Drawing customizations panel
Layers panel
Library panel
Mechanical browser panel
Parameters and constraints panel
Properties panel
Render materials panel
Report panel
Sheet sets panel
Structure panel
Tips panel
Tool palettes panel
Dialog boxes
About BricsCAD dialog box
Add block to library dialog box
Add button item dialog box
Add menu item dialog box
Add-in manager dialog box
Add plot style table dialog box
Add scale dialog box
Allowed deviations from center axis dialog box
Annotation Object Scale dialog box
Array dialog box
Attach external reference
Attach PDF underlay dialog box
Attach raster image dialog box
Attribute editor dialog box
Auto Match dialog box
Background dialog box
BIM BCF panel - Custom login dialog box
BIM project info dialog box
BIM properties dialog box
Bimify dialog box
Blade - BricsCAD LISP advanced development environment dialog box
Block attribute manager dialog box
Block definition dialog box
Boundary dialog box
Bricsys license manager dialog box
Calculator dialog box
Change dictionaries dialog box
Change Icon dialog box
Choose window style dialog box
Classify As Bim Element dialog box
Column filter dialog box
Combine Duplicate Block Definitions dialog box
Communicator info dialog box
Compare two models dialog box
Component Tool Properties
Compositions dialog box
Configure Settings dialog box
Configure structure tree dialog box
Confirm deleting selected cache items
Create detail dialog box
Create new drawing dialog box
Create new sheet set dialog box
Create or edit block definition dialog box
Create Schedule dialog box
Create section/elevation dialog box
Current Plot Style dialog box
Customization groups dialog box
Customize dialog box
Customize (Tool Palettes) dialog box
Custom paper sizes dialog box
Custom properties dialog box
DataLink edit dialog box
Datalink manager dialog box
Default scale list dialog box
Define attribute dialog box
Delete duplicate entities dialog box
Drawing explorer dialog box
Drawing explorer options dialog box
Drawing properties
Drawing view presets dialog box
Edit attributes dialog box
Edit custom properties dialog box
Edit hyperlink dialog box
Edit scale dialog box
Edit scale list dialog box
Entity grouping dialog box
eTransmit dialog box
Extract attributes dialog box
Field dialog box
Filter Configurator dialog box
Find and replace dialog box
Flatshot dialog box
Format dialog box
Geographic location dialog box
Geometric tolerance dialog box
Hatch and gradient dialog box
Hatch Edit dialog box
Import Civil 3D dialog box
Import page setups dialog box
Import sheet set dialog box
Insert block dialog box
Insert object dialog box
Insert table dialog box
Layer Property Filter dialog box
Layer settings dialog box
Layer translator dialog box
Layout manager dialog box
Links dialog box
Load application files dialog box
Load linetypes dialog box
Load Multiline Styles dialog box
Login dialog box
Manage Customizations dialog box
Manage visibility
Map Connect dialog box
Match Properties dialog box
Motion path animation
Navigate Settings dialog box
New Layer Name dialog box
New Multileader Style dialog box
New Multiline Style dialog box
New Page Setup dialog box
New Sheet(s) dialog box
Optimize 2D lines dialog box
Page setup dialog box
Paste special dialog box
Physical materials dialog box
Plot stamp dialog box
Plot style table editor dialog box
Plotter Configuration Editor dialog box
Pre-process point cloud data file(s) dialog box
Print dialog box
Profiles dialog box
Project setup dialog box
Proxy information dialog box
Publish dialog box
QLeader Settings dialog box
Reassociate entity data dialog box
Reference Edit dialog box
Render dialog box
Run BricsCAD VBA macro dialog box
Save block definition dialog box
Save detail dialog box
Save workspace dialog box
Security dialog box
Security options dialog box
Select color dialog box
Select Custom Arrow Block dialog box
Select items to delete from cache dialog box
Select item to attach to this DWG
Settings dialog box
Set viewpoint dialog box
Sheet Properties dialog box
Sheet selection sets dialog box
Sheetset setup dialog box
Spatial Locations Manager dialog box
Spell checking
Standard open file dialog box
Standard save file dialog box
Tags dialog box
Tool image dialog box
Tool Properties dialog box
Upload to Bricsys 24/7 dialog box
User coordinate system dialog box
User profile manger dialog box
VBA manager dialog box
View Options dialog box
Visual settings dialog box
Wall detection options dialog box
Wizard page dialog box
Working sets dialog box
Write block to file dialog box
Managing drawings
Creating a drawing
Working in the Drawing Explorer dialog box
Drawing properties
Drawing security options
Opening and saving drawings
Getting drawing information
Comparing drawings
Repairing a drawing
Projects
Drawing accurately
Orthogonal mode
Unit settings
Coordinate reference system
2D constraints
Using dimensional constraints
Using geometric constraints
Dynamic dimensions
Nearest distance
Coordinate input
Snap and grid
Adaptive grid snap
Nudge
2D entity snaps
3D entity snaps
Polar tracking
Entity snap tracking
User coordinate systems
Dynamic UCS
Measuring
Entity snaps overview
Apparent intersection entity snap
Center entity snap
Center of a Face 3D entity snap
Endpoint entity snap
Extension entity snap
Geometric center entity snap
Insertion entity snap
Intersection entity snap
Intersection 3D entity snap
Knot 3D entity snap
Midpoint entity snap
Midpoint 3D entity snap
Nearest entity snap
Nearest 3D entity snap
Node entity snap
Parallel entity snap
Perpendicular entity snap
Perpendicular on a face 3D entity snap
Quadrant entity snap
Tangent entity snap
Vertex 3D entity snap
Viewing your drawing
View commands overview
Layer utilities
Hide and isolate entities
Redrawing and regenerating a drawing
Panning
Zooming
View manipulation using the mouse and keyboard
View rotation
The LookFrom control
Layer states
Named views
Visual styles
Model space and paper space
Model space viewports
Paper space viewports
Creating paper space viewports
Editing paper space viewports
Layouts
Generated drawing views
2D作図
Creating entities
Working with layers
Entity linetype
Entity color
Lineweight
Fill mode
Transparency
Editing entity properties
Drawing linear entities
Drawing lines
Drawing rays
Drawing infinite lines
Drawing polylines
Drawing multilines
Drawing splines
Drawing freehand sketches
Drawing circles
Drawing arcs
Drawing ellipses
Drawing rectangles
Drawing polygons
Drawing traces
Drawing donuts
Drawing solids
Drawing revision clouds
Drawing points
Drawing wipeouts
Drawing helixes
Drawing 3D polylines
Creating regions
Creating hatches and gradient fills
Editing hatches and gradient fills
3D Modeling
Direct modeling overview
Navigate in 3D
Direct modeling commands
Direct modeling operations
Design intent recognition
Working with sections
Create a TIN Surface
TIN Surface Edit
TIN Surface Direct Modeling
Analyzing TIN Surfaces
Working with Gradings
Create and edit alignments
Modeling a Corridor
Parametric modeling
Parametric modeling overview
Operations and functions in expressions
3D constraints
Suppression feature
Working with design tables
Point cloud
Working with Point cloud
ブロック、属性、外部参照およびコンポーネント
Creating blocks
Using Blockify
Editing blocks
Inserting blocks
Exploding blocks
2D parametric blocks
Dynamic blocks
Defining attributes
Working with attributes
Editing attribute definitions
Editing block attributes
Inserting blocks with attributes
Extracting attribute information
Managing Xrefs
Attaching an external reference
Working with external references
Editing blocks and external references
Working with groups
Working with underlays
Components and component inserts
Managing images
Managing images
Image utilities
注釈
Dimensions
Dimensioning tools overview
Associative dimensions
Dimension settings
Working with dimension styles
Using the dimension style tools
Creating linear dimensions
Creating angular dimensions
Creating diametrical and radial dimensions
Centerlines and center marks
Creating ordinate dimensions
Editing dimensions
Creating leaders and annotations
Creating multileaders
Adding geometric tolerances
Texts
Text system variables
Working with text styles
Creating text
Editing text
Exploding text
Finding and replacing text
Checking spelling
Working with fields
Working with tables
Annotative Entities
Annotative entities
Annotation scales
Annotative texts
Annotative hatches and gradient fills
Annotative blocks
Annotative dimensions
Annotative leaders
Customization
Startup options
BricsCAD user files
Loading and unloading CUI files
Creating a partial CUI file
Managing toolboxes
Creating toolbars
Creating menus
Creating context menus
Creating keyboard shortcuts
Customizing the Quad
Adding tools to user interface controls
Customizing the ribbon
Tool palettes
Command aliases
User profiles
Workspaces
Express tools
Lisp
Modifying Entities
Modifying commands overview
Entity modification settings
Match properties
Grips editing
Selection methods
Quick select
Draw order
The manipulator
Moving entities
Rotating entities
Mirroring entities
Aligning entities
Changing entities
Copying entities
Making parallel copies
Arraying entities
Extending entities
Trimming entities
Lengthening entities
Selection and grip settings
Stretching entities
Scaling entities
Breaking entities
Joining entities
Chamfering entities
Filetting entities
Editing polylines
Exploding entities
Measuring entities
Dividing entities
Printing and plotting
General procedure for printing
Plotter configuration
Plot style tables
The plot styles manager
Batch plot
Rendering
Using TwinMotion
Rendering overview
Rendering preferences
Rendering tools
Render materials
Lights
Creating a rendered image
User feedback
Diagnostics and usage data collection
BricsCAD BIM
What's new in BricsCAD V21 BIM
Overview
Modeling techniques
Building data
Project collaboration
Design documentation
Point clouds
Getting started
Creating a BIM model
Quad cursor
Viewing entities
Selecting entities
Level of detail
Modeling techniques
BIM linear solid
BIM window create
The library panel
Connecting solids
Creating a custom window
Creating roofs
Creating slabs
Creating walls
Curtain wall
DmExtrude
DmPushPull
Editing grids
Inserting and editing windows and doors
Mass modeling with quickbuilding
MEP modeling
MEP flow connection points
Offset
Splitting solids
Stair tool
Structural steel
Using BIM quickdraw
Using drag
Using parametrize
Working with parameters and constraints
Building data
Analytical model
AutoComplete BIM data
Attaching compositions
BIM classify
BIM compositions
BIM data structure
BIM ply editing
BIM project info
Using Python scripts (beta)
Classification codes
Creating and editing BIM spaces
Custom properties
Customizing BIM quantities
Load bearing direction for slabs
Physical materials
Project browser
Spatial locations
Structure browser
Design assistance
Using bimify
Using propagate
Propagate planar
Propagate linear
Propagate pattern
Propagate edges
Propagate corner
Parametrize details
Details panel
Rhino/Grasshopper integration
BIM collaboration format (BCF) panel
Bricsys 24/7 panel
IFC import and export in BricsCAD
Import and underlay Autodesk® Revit® files in BricsCAD
Importing Autodesk® Revit® families in BricsCAD
Interference checking
Using Xrefs
Annotations in 3D
BIM sections
BIM tags
Create drawing types with drawing customization
Define detailed section
Define reflected ceiling plan
Detailing with BimPatch
Editing data extraction definition (.dxd) files
Editing generated drawings
Elevation hatch
Enscape integration
Generating Drawings
Working with Point Clouds in BIM
Interior elevations
Schedules
Spot elevation level
Templates for generated drawings
BricsCAD Mechanical
BricsCAD V21 Mechanicalの新機能
Overview
BOM manager
Parts libraries
標準部品
Sheet metal
Getting started
Mechanical workspace
3D comparison
部品設計
Thread feature
Part Design Methods
Sketching
Solid Modeling
Surface Modeling
Freeform Surface Modeling
アセンブリ設計
Bottom-up and Top-down Assembly Design
Assembly Design Commands and Tools
Component Properties
Assembly mass properties
Standard Mechanical Components
Piping in Assembly Design
Arrays of Components
Array Properties
Exploded Representations
Bill of Materials Manager
Bill of Materials
Multi-parametric 3D animations
Sheet Metal
Sheet Metal Design Methods
Sheet Metal Commands and Toolbars
Sheet Metal Features
フィーチャーに色付け
Mechanical Browser for Sheet Metal
Sheet Metal Global and Feature Properties
K-factor
Bend Table
Sheet Metal Settings
Creating Flanges
Modifying Flanges
Working with Bends and Junctions
Working with Hems
Working with Tabs
Working with T-tabs and T-junctions
Working with Bevels
Creating and Splitting Lofted Bends
Bend Relief and Corner Relief Feature Operations
Working with Form and Rib Features
Working with Hole Features
Converting to Sheet Metal and Repairing
Unfolding Sheet Metal Parts and Exporting to CAM
Associative Unfolded Representations of 3D Solids
Smart Features
生成された図面
Drawing Views
注釈の作図
Communicator for BricsCAD
BricsCAD Communicator
BricsCAD Communicator settings
BricsCAD Shape
Introduction to BricsCAD Shape
BricsCAD Shape user interface
Basic concepts of modeling in BricsCAD Shape
Navigation in BricsCAD Shape
Components in BricsCAD Shape
Materials in BricsCAD Shape
Layers in BricsCAD Shape
Working with steel profiles
Visualization in BricsCAD Shape
Solids in BricsCAD Shape
Creating walls in BricsCAD Shape
Quickdraw in BricsCAD Shape
Creating windows and doors in BricsCAD Shape
Creating roofs in BricsCAD Shape
Command reference
+STRUCTUREPANELコマンド
? command
2
2DINTERSECTION command
3
3D command
3DARRAY command
3DCOMPARE command
3DCONVERT command
3DDWF command
3DFACE command
3DINTERSECTION command
3DMESH command
3DOSNAP command
-3DOSNAP command
3DPOLY command
A
ABOUT command
ACISIN command
ACISOUT command
ACTIVATESECTIONVIEW command
ADDINMAN command
ADDSELECTED command
AI_BOX command
AI_CONE command
AI_CIRCTAN command
AI_CYLINDER command
AI_DESELECT command
AI_DIM_TEXTABOVE command
AI_DIM_TEXTCENTER command
AI_DIM_TEXTHOME command
AI_DISH command
AI_DOME command
AI_EDGESURF command
AI_FMS command
AI_PSPACE command
AI_PYRAMID command
AI_REVSURF command
AI_RULESURF command
AI_SELALL command
AI_SPHERE command
AI_TABSURF command
AI_TORUS command
AI_WEDGE command
AIMLEADEREDITADD command
AIMLEADEREDITREMOVE command
AIDIMFLIPARROW command
AIDIMPREC command
AIDIMSTYLE command
ALIGN command
ALIGNMENT command
ALIGNMENTEDIT command
ALIGNMENTVIEW command
ALIGNMENTVINITIAL command
ALIGNSPACE command
ANIMATIONEDITORCLOSE command
ANIMATIONEDITOROPEN command
ANIPATH command
ANNORESET command
ANNOUPDATE command
APERTURE command
APPARENT command
APPLOAD command
ARC command
AREA command
ARRAY command
-ARRAY command
ARRAYCLASSIC command
ARRAYCLOSE command
-ARRAYCLOSE command
ARRAYEDIT command
ARRAYEDITEXT command
ARRAYPATH command
ARRAYPOLAR command
ARRAYRECT command
ATTACHMENTSPANELCLOSE command
ATTACHMENTSPANELOPEN command
ATTDEF コマンド
-ATTDEF command
ATTDISP command
ATTEDIT command
ATTEXT command
-ATTEXT command
ATTREDEF command
ATTSYNC command
AUDIT command
AUTOCOMPLETE command
AUTOCONSTRAIN command
B
BACKGROUND command
BASE command
BATTMAN command
BCLOSE command
BEDIT command
-BEDIT command
BHATCH command
-BHATCH command
BIMACTIVATEPYTHON command
BIMADDECCENTRICITY command
BIMANALYTICALMODEL command
BIMAPPLYPROFILE command
BIMATTACHCOMPOSITION command
BIMATTACHSPATIALLOCATION command
BIMAUTOMATCH command
BIMCLASSIFY command
BIMCOPY command
BIMCREATEDETAIL command
BIMCURTAINWALL command
BIMDECOMPOSE command
BIMFLIP command
BIMFLOWCONNECT command
BIMGRID command
BIMIFY command
-BIMINSERT command
BIMINSERT command
BIMLINEARSOLID command
BIMLIST command
BIMMULTISELECT command
BIMPARAMETRIZEDETAIL command
BIMPATCH command
BIMPROFILES command
BIMPROJECTINFO command
BIMPROPAGATE command
BIMPROPAGATECORNER command
BIMPROPAGATEEDGES command
BIMPROPAGATEFROMFILE command
-BIMPROPAGATEFROMFILE command
BIMPROPAGATELINEAR command
BIMPROPAGATEPATTERN command
BIMPROPAGATEPLANAR command
BIMPROPERTIES command
BIMPYTHON command
BIMROOM command
BIMQUICKBUILDING command
BIMQUICKDRAW command
BIMRECALCULATEAXIS command
BIMREGENERATETAGS command
BIMSECTION command
BIMSECTIONOPEN command
BIMSECTIONUPDATE command
BIMSETLOADBEARINGDIRECTION command
BIMSETREFERENCEFACE command
BIMSPACE command
BIMSPATIALLOCATIONS command
BIMSPLIT command
BIMSTAIR command
BIMSTRETCH command
BIMSTRUCTURALCONNECT command
BIMTAG command
BIMUPDATESPACE command
BIMUPDATETHICKNESS command
BIMWINDOWCREATE command
-BIMWINDOWCREATE command
BIMWINDOWPRINT command
BIMWINDOWUPDATE command
BLADE command
BLCOMPOSITIONS command
BLIPMODE command
BLMATERIALS command
BLOCK command
-BLOCK command
BLOCKICON command
BLOCKIFY command
BMBALLOON command
BMBOM command
BMBOMEDIT command
BMBOMPANELCLOSE コマンド
BMBOMPANELOPEN command
BMCONNECT command
BMCREATECOMPONENT command
-BMCREATECOMPONENT command
BMDEPENDENCIES command
BMDISSOLVE command
BMEXPLODE command
BMEXPLODEMOVE command
BMEXPLODESTEPEDIT command
BMEXTERNALIZE command
BMFORM command
BMHARDWARE command
-BMHARDWARE command
BMHIDE command
BMINSERT command
-BMINSERT command
BMLINK command
BMLOCALIZE command
BMMASSPROP command
BMMECH command
BMNEW command
BMOPEN command
BMOPENCOPY command
-BMPARAMETERS command
BMPOUT command
BMRECOVER command
BMREPLACE command
BMSHOW コマンド
BMTRAILINGLINES command
BMUNLINK command
BMUNMECH command
BMUPDATE command
BMVSTYLE command
BMXCONVERT command
BOUNDARY command
-BOUNDARY command
BOX command
BREAK command
BROWSER command
BSAVEAS コマンド
C
CALコマンド
CALLOUT command
CAMERA command
CENTER command
CENTERDISASSOCIATE command
CENTERLINE command
CENTERMARK command
CENTERREASSOCIATE command
CENTERRESET command
CHAMFER command
CHANGE command
CHPROP command
CHSPACE command
CIRCLE command
CIVIL3DIMPORT command
CIVILDWGEXPORT command
CLEANSCREENOFF command
CLEANSCREENON command
CLEANUNUSEDVARIABLES command
CLIPDISPLAY command
CLOSE command
COLOR command
-COLOR command
COMMANDLINE command
COMMANDLINEHIDE command
COMMANDS command
COMMUNICATORINFO command
COMPONENTSPANELCLOSE command
COMPONENTSPANELOPEN command
CONE command
CONSTRAINTBAR command
CONTENTBROWSERCLOSE command
CONTENTBROWSEROPEN command
CONVERTCTB command
CONVERTOLDLIGHTS command
CONVERTOLDMATERIALS command
CONVERTPOLY command
CONVERTPSTYLES command
CONVTOMESH command
CONVTOSOLID command
CONVTOSURFACE command
COPY command
COPYBASE command
COPYCLIP command
COPYEDATA command
COPYGUIDED command
COPYHIST command
COPYTOLAYER command
CORRIDOR command
CORRIDOREDIT command
CORRIDOREXTRACT command
CORRIDORTEMPLATE command
CORRIDORTEMPLATEELEMENT command
CPAGESETUP コマンド
CREATELIBRARYBLOCK command
-CREATELIBRARYBLOCK command
CREATETHUMBNAIL command
CUILOAD command
CUIUNLOAD command
CUSTOMIZE command
CUTCLIP command
CYLINDER command
D
DATAEXTRACTION command
-DATAEXTRACTION command
DATALINK command
DATALINKUPDATE command
DATASMITHEXPORT command
DBLIST command
DCALIGNED command
DCANGULAR command
DCCONVERT command
DCDIAMETER command
DCDISPLAY command
DCHORIZONTAL command
DCLINEAR command
DCRADIUS command
DCVERTICAL command
DDATTE command
DDEDIT command
DDEMODES command
DDFILTER command
DDGRIPS command
DDPTYPE コマンド
DDSELECT コマンド
DDSETVAR command
DDSTRACK command
DDVPOINT command
DEFAULTSCALELIST command
DELAY command
DELCONSTRAINT command
DELEDATA command
DESIGNTABLE command
-DESIGNTABLEEDIT command
DETAILSPANELCLOSE command
DETAILSPANELOPEN command
DGNEXPORT command
-DGNEXPORT command
DGNIMPORT command
DGNIMPORTOPTIONS コマンド
DIM command
DIM1 Command
DIMALIGNED command
DIMANGULAR command
DIMARC command
DIMBASELINE command
DIMBREAK command
DIMCENTER コマンド
DIMCONSTRAINT command
DIMCONTINUE command
DIMDIAMETER command
DIMDISASSOCIATE command
DIMEDIT command
DIMLEADER command
DIMLINEAR command
DIMORDINATE command
DIMOVERRIDE command
DIMRADIUS command
DIMREASSOCIATE command
DIMREGEN command
DIMSTYLE command
-DIMSTYLE command
DIMSTYLESET command
DIMTEDIT command
DISH command
DIST command
DISTANTLIGHT command
DIVIDE command
DMANGLE3D command
DMAUDIT command
DMAUDITALL command
DMCHAMFER command
DMCOINCIDENT3D command
DMCONCENTRIC3D command
DMCONSTRAINT3D command
DMCOPYFACES command
DMDEFORMCURVE command
DMDEFORMMOVE command
DMDEFORMPOINT command
DMDELETE コマンド
DMDISTANCE3D command
DMEXTRUDE command
DMFILLET command
DMFIX3D command
DMGROUP command
DMMOVE command
DMPARALLEL3D command
DMPATH3D command
DMPERPENDICULAR3D command
DMPUSHPULL command
DMRADIUS3D command
DMREPAIR command
DMREVOLVE command
DMRIGIDSET3D command
DMROTATE command
DMSELECT command
DMSELECTEDGES command
DMSIMPLIFY command
DMSIMPLIFYALL command
DMSTITCH command
DMTANGENT3D command
DMTHICKEN command
DMTHREAD command
DMTWIST command
DMUPDATE command
DOME command
DONUT command
DRAG command
DRAGMODE command
DRAWORDER command
DRAWORDERBYLAYER command
DSETTINGS command
DTEXT command
DUMPSTATE command
DVIEW command
DWFOUT command
DWGCODEPAGE command
DWGCOMPARE command
DWGPROPS command
DXFIN command
DXFOUT command
E
EATTEDIT command
EDGESURF command
EDITEDATA command
ELEV command
ELLIPSE command
ENABLEASSOCVIEWS command
ENDCOMPARE command
ENDPOINT command
ERASE command
ETRANSMIT command
-ETRANSMIT command
EXECUTETOOL command
EXPBLOCKS command
EXPFOLDERS command
EXPIMAGES command
EXPLAYERS command
EXPLODE command
EXPLORER command
EXPORT command
EXPORTLAYOUT command
EXPORTPDF command
EXPPDFS command
EXPUCS command
EXPXREF command
EXTEND command
EXTENSION コマンド
EXTRUDE command
F
FBXEXPORT command
-FBXEXPORT command
FIELD command
FILEOPEN command
FILES command
FILL command
FILLET command
FIND command
FITARC command
FITLINE command
FLATSHOT command
FLATTEN command
FROM command
G
GCCOINCIDENT command
GCCOLINEAR command
GCCONCENTRIC command
GCENTER command
GCEQUAL command
GCFIX command
GCHORIZONTAL command
GCPARALLEL command
GCPERPENDICULAR command
GCSMOOTH command
GCSYMMETRIC command
GCTANGENT command
GCVERTICAL command
GENERATEBOUNDARY command
GEOGRAPHICLOCATION command
GEOIMPORT command
GEOMCONSTRAINT command
GOTOSTART command
GRADIENT command
-GRADIENT command
GRADIENTBKGOFF command
GRADIENTBKGON command
GRADING command
GRADINGBALANCE command
GRAPHSCR command
GRID command
GROUP command
-GROUP command
H
HATCH コマンド
-HATCH command
HATCHEDIT Command
-HATCHEDIT command
HATCHEDITEXT command
HATCHGENERATEBOUNDARY command
HATCHTOBACK command
HELIX command
HELP command
HELPSEARCH command
HIDE command
HIDEOBJECTS command
HYPERLINK command
-HYPERLINK command
HYPERLINKOPTIONS command
I
ID command
IEMBED command
IFCEXPORT command
IMAGE command
IMAGEADJUST command
-IMAGEATTACH
IMAGEATTACH command
IMAGECLIP command
IMAGEFRAME command
IMAGEQUALITY コマンド
-IMPORT command
IMPORT command
IMPRINT command
INSERT command
-INSERT command
INSERTALIGNED command
INSERTION command
INSERTOBJ command
INTERFERE command
-INTERFERE command
INTERSECT command
INTERSECTION コマンド
INVOKETESTAPP command
ISAVEAS command
ISOLATEOBJECTS command
ISOPLANE command
IUNEMBED command
J
JOIN command
K
KEEPME command
L
LANDXMLEXPORT command
LANDXMLIMPORT command
LAYCUR command
-LAYER command
LAYER command
LAYERP コマンド
LAYERSPANELCLOSE command
LAYERSPANELOPEN command
LAYERSTATE command
LAYFRZ command
LAYISO command
LAYLCK command
LAYMCUR command
LAYOFF command
LAYON command
LAYOUT command
LAYOUTMANAGER command
LAYTHW command
LAYTRANS command
LAYULK command
LAYUNISO command
LCONNECT command
LEADER command
LENGTHEN command
LIBRARYPANELCLOSE command
LIBRARYPANELOPEN command
LICENSEMANAGER command
LIGHT command
LIGHTLIST command
LIMITS command
LINE command
-LINETYPE command
LINETYPE command
LIST command
LIVESECTION command
LOAD command
LOFT command
LOGFILEOFF command
LOGFILEON command
-LOGIN command
-LOGOUT command
LOOKFROM command
LWEIGHT command
M
MAIL command
MANIPULATE command
MAPCONNECT command
MASSPROP command
MATBROWSERCLOSE command
MATBROWSEROPEN command
MATCHPERSPECTIVE command
MATCHPROP command
MATERIALASSIGN command
MATERIALMAP command
MATERIALS command
MATLIB command
MEASURE command
MECHANICALBROWSERCLOSE command
MECHANICALBROWSEROPEN command
MENU command
MENULOAD command
MENUUNLOAD command
MIDPOINT command
MINSERT command
MIRROR command
MIRROR3D command
MLEADER command
MLEADERALIGN command
MLEADERCOLLECT command
MLEADEREDIT command
MLEADEREDITEXT command
MLEADERSTYLE command
MLINE command
MLSTYLE command
MODELERPROPERTIES コマンド
-MODELERPROPERTIES command
MOVE command
MOVEEDATA command
MOVEGUIDED command
MSLIDE command
MSPACE command
MTEXT command
-MTEXT command
MTP command
MULTIPLE command
MVIEW command
MVSETUP command
N
NAVIGATE command
NEARESTコマンド
NETLOAD command
NEW command
NEWSHEETSET command
NEWWIZ command
NODE command
NONE command
NUMBER command
O
OBJECTSCALE command
-OBJECTSCALE command
OFFSET command
OLELINKS command
OLEOPEN command
ONWEB command
OOPS コマンド
OPEN command
OPENSHEETSET command
-OPENSHEETSET command
OPTIMIZE コマンド
-OPTIMIZE command
OPTIONS command
ORTHOGONAL command
OSNAP command
-OSNAP command
OVERKILL command
-OVERKILL command
P
PACKAGE command
PAGESETUP command
PAN command
-PAN command
PANELIZE command
PARALLEL command
PARAMETERCOPYMODE command
-PARAMETERS command
PARAMETERSPANELCLOSE command
PARAMETERSPANELOPEN command
PARAMETRICBLOCKIFY command
PARAMETRIZE command
PARAMETRIZE2D command
PASTEBLOCK command
PASTECLIP command
PASTEORIG command
PASTESPEC command
PDF command
PDFADJUST command
PDFATTACH command
-PDFATTACH command
PDFCLIP command
PDFIMPORT command
-PDFIMPORT command
PDFLAYERS command
PDFOPTIONS command
PEDIT command
PEDITEXT command
PFACE command
PLACEVIEW command
PLAN command
PLINE command
PLOT command
-PLOT command
PLOTSTAMP command
PLOTSTYLE command
PLOTTERMANAGER command
PNGOUT command
POINT コマンド
POINTCLOUD command
POINTCLOUDALIGN command
POINTCLOUDATTACH command
-POINTCLOUDATTACH command
POINTCLOUDCOLORMAP command
POINTCLOUDCROP command
POINTCLOUDCROPSOLID command
POINTCLOUDDELETEITEM command
POINTCLOUDDETECTFLOORS command
POINTCLOUDEXPORT command
POINTCLOUDFITPLANAR command
POINTCLOUDIMPORT command
POINTCLOUDPOINTSIZE_MINUS command
POINTCLOUDPOINTSIZE_PLUS command
POINTCLOUDPREPROCESS command
-POINTCLOUDPREPROCESS command
POINTCLOUDPROJECTSECTION command
POINTCLOUDREFERENCE command
POINTCLOUDSHOWBUBBLES command
POINTCLOUDUNCROP command
POINTLIGHT command
POLYGON command
POLYSOLID command
PREVIEW command
PRINT command
PROFILEMANAGER command
PROJECTGEOMETRY command
PROPERTIES command
PROPERTIESCLOSE command
PROXYINFO command
PSETUPIN command
-PSETUPIN command
PSPACE command
PUBLISH command
-PUBLISH command
PURGE command
-PURGE command
PYRAMID command
Q
QLEADER command
QNEW command
QPRINT command
QSAVE command
QSELECT command
QTEXT command
QUADRANT command
QUIT command
R
RAY command
REASSOCAPP command
RECOVER command
RECOVERALL command
RECSCRIPT command
RECTANG command
REDEFINE command
REDO command
REDRAW command
REDRAWALL command
REDSDKINFO command
REFCLOSE command
REFEDIT command
-REFEDIT command
REFERENCECURVES command
REFSET command
REGEN command
REGENALL command
REGENAUTO command
REGION command
REINIT command
RENAME command
-RENAME command
RENDER command
-RENDER command
RENDERCOMPOSITIONSMATERIAL command
RENDERPRESETS command
RENDERWINCLOSE command
REPORTPANELCLOSE command
REPORTPANELOPEN command
RESETASSOCVIEWS command
RESETBLOCK command
RESUME command
REVCLOUD command
REVOLVE command
REVSURF command
RIBBON command
RIBBONCLOSE command
ROTATE command
ROTATE3D command
RSCRIPT command
RTLOOK command
RTPAN command
RTROT command
RTROTCTR command
RTROTF command
RTROTX command
RTROTY command
RTROTZ command
RTUPDOWN command
RTWALK command
RTZOOM command
RULESURF command
RUNASLEVEL command
S
SAVE command
SAVEALL command
SAVEAS command
SAVEASR12 Command
SAVEFILEFOLDER command
SCALE command
SCALELISTEDIT command
-SCALELISTEDIT command
SCREENSHOT command
SCRIPT command
SCROLLBAR command
SECTION command
SECTIONPLANE command
SECTIONPLANESETTINGS command
SECTIONPLANETOBLOCK command
SECURITY コマンド
SECURITYOPTIONS command
SELECT command
SELECTALIGNEDFACES command
SELECTALIGNEDSOLIDS command
SELECTCONNECTEDFACES command
SELECTCONNECTEDSOLIDS command
SELECTSIMILAR command
SELGRIPS command
SETBYLAYER command
-SETBYLAYER command
SETLICENSELEVEL command
SETTINGS command
SETTINGSSEARCH command
SETUCS command
SETVAR command
SH command
SHADE command
SHADEMODE command
-SHADEMODE command
SHAPE command
SHEETSET command
SHEETSETHIDE command
SHELL command
SIMPLIFY command
SINGLETON command
SKETCH command
SLICE command
SMASSEMBLYEXPORT command
SMBENDCREATE command
SMBENDSWITCH command
SMCONVERT command
SMDELETE command
SMDISSOLVE command
SMEXPLODE command
SMEXPORT2D command
SMEXPORTOSM command
SMEXTRUDE command
SMFLANGEBASE command
SMFLANGEBEND command
SMFLANGECONNECT command
SMFLANGECONTOUR command
SMFLANGEEDGE command
SMFLANGEROTATE command
SMFLIP command
SMFORM command
SMHEMCREATE command
SMIMPRINT command
SMJUNCTIONCREATE command
SMJUNCTIONSWITCH command
SMLISPGET command
SMLISPSET command
SMLOFT command
SMPARAMETRIZE command
SMRELIEFCREATE command
SMRELIEFSWITCH command
SMREPAIR command
SMREPLACE command
SMRIBCREATE command
SMSELECT command
SMSPLIT command
SMTABCREATE command
SMUNFOLD command
SNAP command
SOLID command
SOLIDEDIT command
SOLPROF command
SPELL command
SPHERE コマンド
SPLINE command
SPLINEDIT command
SPOTLIGHT command
STANDARDPARTSPANELCLOSE command
STANDARDPARTSPANELOPEN command
START command
STATBAR command
STATUS command
STLOUT command
STOPSCRIPT command
STRETCH command
STRUCTUREPANEL command
STRUCTUREPANELCLOSE command
STYLE command
-STYLE command
STYLESMANAGER command
SUBTRACT command
SUNPROPERTIES command
SUPPORTFOLDER command
SUPPRESS command
SVGOPTIONS command
SWEEP command
SYSWINDOWS command
T
TABLE command
-TABLE command
TABLEDIT command
TABLEEXPORT command
TABLEMOD command
TABLESTYLE command
TABLET command
TABSURF command
TANGENT command
TCONNECT command
TEMPLATEFOLDER command
TESTDBUSERIO command
TESTDLG command
TESTFATAL command
TESTINTERNAL command
TESTSELECTION command
TEXT command
-TEXT command
TEXTSCR command
TEXTTOFRONT command
TFLOAD command
TFSAVE command
TIME command
TIN command
TINASSIGNIMAGE command
TINEDIT
TINEXTRACT command
TINMERGE command
TINMODIFY command
TINPROJECT command
TINSERT command
TINVOLUME command
TINWATERDROP command
TIPS command
TOLERANCE command
TOOLBAR command
-TOOLBAR command
TOOLPALETTES command
TOOLPALETTESCLOSE command
-TOOLPANEL command
TORUS command
TPNAVIGATE command
TRACE command
TRANSPARENCY command
TRIM command
TXT2MTXT command
TXTEXP command
U
U command
UCS command
UCSICON command
UNDEFINE command
UNDO command
UNDOENT command
UNGROUP command
UNION command
UNISOLATEOBJECTS command
UNITS command
-UNITS command
UPDATEFIELD command
URL command
V
VBAIDE command
VBALOAD command
-VBALOAD command
VBAMAN command
VBANEW command
VBARUN command
-VBARUN command
VBASECURITY command
VBAUNLOAD command
VERSIONCONTROL command
VIEW command
-VIEW command
VIEWBASE command
VIEWBREAK command
VIEWDETAIL command
VIEWDETAILSTYLE command
VIEWEDIT command
VIEWEXPORT command
VIEWHORIZONTAL command
VIEWLABEL command
VIEWPOINT command
VIEWPROJ command
VIEWRES command
VIEWSECTION command
VIEWSECTIONSTYLE command
VIEWUPDATE command
VISIBILITYSTATES command
VISIBLE command
VISUALSTYLES command
-VISUALSTYLES command
VLIDE command
VMLOUT command
VPCLIP command
VPLAYER command
VPMAX command
VPMIN command
VPOINT command
VPORTS command
-VPORTS command
VSCURRENT command
VSLIDE command
VTOPTIONS command
W
WBLOCK command
-WBLOCK command
WCASCADE command
WCLOSE command
WCLOSEALL command
WEBLIGHT command
WEDGE command
WHOHAS command
WHTILE command
WIARRANGE command
WIPEOUT command
WMFOUT command
WNEXT command
WORKSETS command
WORKSPACE command
WPREV command
WSSAVE command
WSSETTINGS command
WVTILE command
X
XATTACH command
XCLIP command
XEDGES command
XFACES command
XLINE command
XMLSAVE command
XOPEN command
XPLODE command
XREF command
-XREF command
Y
Z
ZCENTER command
ZINTERSECTION command
ZKNOT command
ZMIDPOINT command
ZNEAREST command
ZNONE command
ZOOM command
ZPERPENDICULAR command
ZVERTEX command
System variable reference
_
_PKSER system variable
_QUADTABFLAGS システム変数
_VERNUM システム変数
3
3DCOMPAREMODE system variable
3DOSMODE システム変数
3DSNAPMARKERCOLOR システム変数
A
ACADLSPASDOC system variable
ACADPREFIX システム変数
ACADVER system variable
ACISHLRRESOLUTION system variable
ACISOUTVER system variable
ADAPTIVEGRIDSTEPSIZE システム変数
AFLAGS system variable
ALLOWTABEXTERNALMOVE system variable
ALLOWTABMOVE システム変数
ALLOWTABSPLIT system variable
ANGBASE システム変数
ANGDIR システム変数
ANNOALLVISIBLE system variable
ANNOAUTOSCALE system variable
ANNOSELECTED system variable
ANNOTATIVEDWG システム変数
ANTIALIASRENDER システム変数
ANTIALIASSCREEN system variable
APBOX system variable
APERTURE システム変数
AREA system variable
AREAPREC システム変数
AREAUNITS システム変数
ARRAYASSOCIATIVITY system variable
ARRAYEDITSTATE system variable
ARRAYTYPE system variable
ATTDIA システム変数
ATTMODE system variable
ATTRACTIONDISTANCE system variable
ATTREQ システム変数
AUDITCTL システム変数
AUDITERRORCOUNT システム変数
AUNITS システム変数
AUPREC system variable
AUTOADOPTSIZES system variable
AUTOCOMPLETEDELAY システム変数
AUTOCOMPLETEMODE system variable
AUTOMENULOAD システム変数
AUTORESETSCALES システム変数
AUTOSAVECHECKSONLYFIRSTBITDBMOD システム変数
AUTOSNAP システム変数
AUTOTRACKINGVECCOLOR system variable
AUTOVPFITTING システム変数
AXISMODE system variable
AXISUNIT システム変数
B
BACKGROUNDPLOT system variable
BACKZ system variable
BASEFILE システム変数
BCFSOURCEURL system variable
BIMACTIVATEPYTHON system variable
BIMOSMODE システム変数
BIMPROFILESTANDARDS system variable
BINDTYPE system variable
BKGCOLOR system variable
BKGCOLORPS system variable
BLIPMODE システム変数
BLOCKEDITLOCK システム変数
BLOCKEDITOR system variable
BLOCKIFYMODE システム変数
BLOCKIFYTOLERANCE システム変数
BLOCKSPATH システム変数
BMAUTOUPDATE system variable
BMFORMTEMPLATEPATH システム変数
BMUPDATEMODE システム変数
BOUNDARYCOLOR system variable
BSYSLIBCOPYOVERWRITE システム変数
BVMODE system variable
C
CACHELAYOUT system variable
CAMERADISPLAY システム変数
CAMERAHEIGHT system variable
CANNOSCALE system variable
CANNOSCALEVALUE システム変数
CDATE system variable
CECOLOR system variable
CELTSCALE システム変数
CELTYPE system variable
CELWEIGHT system variable
CENTERCROSSGAP system variable
CENTERCROSSSIZE システム変数
CENTEREXE システム変数
CENTERLAYER system variable
CENTERLTSCALE システム変数
CENTERLTYPE system variable
CENTERLTYPEFILE システム変数
CENTERMARKEXE システム変数
CETRANSPARENCY システム変数
CHAMFERA system variable
CHAMFERB system variable
CHAMFERC system variable
CHAMFERD システム変数
CHAMMODE system variable
CHECKDWLPRESENCE system variable
CIRCLERAD system variable
CLAYER システム変数
CLEANSCREENOPTIONS system variable
CLEANSCREENSTATE システム変数
CLIPBOARDFORMAT システム変数
CLIPBOARDFORMATS システム変数
CLIPROMPTLINES システム変数
CLISTATE system variable
CLOSECHECKSONLYFIRSTBITDBMOD システム変数
CLOUDDOWNLOADPATH system variable
CLOUDLOG システム変数
CLOUDLOGVERBOSE system variable
CLOUDONMODIFIED system variable
CLOUDSERVER system variable
CLOUDTEMPFOLDER システム変数
CLOUDUPLOADDEPENDENCIES システム変数
CMATERIAL システム変数
CMDACTIVE システム変数
CMDDIA システム変数
CMDECHO system variable
CMDLINEEDITBGCOLOR システム変数
CMDLINEEDITFGCOLOR システム変数
CMDLINEFADINGLOGBGCOLOR システム変数
CMDLINEFADINGLOGFADEDELAY system variable
CMDLINEFADINGLOGFGCOLOR システム変数
CMDLINEFADINGLOGTRANSPARENCY システム変数
CMDLINEFONTNAME system variable
CMDLINEFONTSIZE system variable
CMDLINEFRAMEACTIVETRANSPARENCY system variable
CMDLINEFRAMEINACTIVETRANSPARENCY system variable
CMDLINELISTBGCOLOR システム変数
CMDLINELISTFGCOLOR システム変数
CMDLINEOPTIONBGCOLOR system variable
CMDLINEOPTIONSHORTCUTCOLOR システム変数
CMDLINEUSENEWFRAME システム変数
CMDLNTEXT システム変数
CMDNAMES システム変数
CMLEADERSTYLE システム変数
CMLJUST システム変数
CMLSCALE system variable
CMLSTYLE システム変数
CMPCLRMISS システム変数
CMPCLRMOD1 システム変数
CMPCLRMOD2 システム変数
CMPCLRNEW システム変数
CMPDIFFLIMIT system variable
CMPFADECTL システム変数
CMPLOG system variable
COLORBOOKPATH system variable
COLORTHEME system variable
COLORX システム変数
COLORY システム変数
COLORZ system variable
COMACADCOMPATIBILITY システム変数
COMBINETEXTMODE system variable
COMMUNICATORPATH システム変数
COMPASS system variable
COMPONENTSCONFIG システム変数
COMPONENTSPATH システム変数
CONSTRAINTBARDISPLAY システム変数
CONTINUOUSMOTION system variable
COORDS system variable
COPYMODE system variable
CPLOTSTYLE system variable
CPROFILE system variable
CREATETHUMBNAILONTHEFLY システム変数
CREATEVIEWPORTS system variable
CROSSHAIRDRAWMODE システム変数
CROSSINGAREACOLOR システム変数
CTAB システム変数
CTABLESTYLE system variable
CTRL3DMOUSE システム変数
CTRLMOUSE system variable
CURSORSIZE システム変数
CVPORT システム変数
D
DATACOLLECTION システム変数
DATALINKNOTIFY system variable
DBCSTATE system variable
DBLCLKEDIT system variable
DBMOD system variable
DCTCUST システム変数
DCTMAIN system variable
DEFAULTBSYSLIBIMPERIAL system variable
DEFAULTBSYSLIBMETRIC system variable
DEFAULTLIGHTING システム変数
DEFAULTCURVETYPEHA system variable
DEFAULTCURVETYPEVA system variable
DEFAULTLIGHTSHADOWBLUR システム変数
DEFAULTNEWSHEETTEMPLATE system variable
DEFLPLSTYLE system variable
DEFPLSTYLE システム変数
DELETEINTERFERENCE システム変数
DELETETOOL システム変数
DELOBJ システム変数
DEMANDLOAD システム変数
DETAILSPATH system variable
DGNEXPXREFMODE システム変数
DGNFRAME system variable
DGNIMP2DCLOSEDBSPLINECURVEIMPORTMODE system variable
DGNIMP2DELLIPSEIMPORTMODE システム変数
DGNIMP2DSHAPEIMPORTMODE system variable
DGNIMP3DCLOSEDBSPLINECURVEIMPORTMODE system variable
DGNIMP3DELLIPSEIMPORTMODE システム変数
DGNIMP3DOBJECTIMPORTMODE システム変数
DGNIMP3DSHAPEIMPORTMODE system variable
DGNIMPBREAKDIMENSIONASSOCIATION システム変数
DGNIMPCONVERTDGNCOLORINDICESTOTRUECOLORS system variable
DGNIMPCONVERTEMPTYDATAFIELDSTOSPACES system variable
DGNIMPERASEUNUSEDRESOURCES system variable
DGNIMPEXPLODETEXTNODES システム変数
DGNIMPIMPORTACTIVEMODELTOMODELSPACE system variable
DGNIMPIMPORTINVISIBLEELEMENTS システム変数
DGNIMPIMPORTPAPERSPACEMODELS システム変数
DGNIMPIMPORTVIEWINDEX system variable
DGNIMPRECOMPUTEDIMENSIONSAFTERIMPORT システム変数
DGNIMPSYMBOLRESOURCEFILES system variable
DGNIMPXREFIMPORTMODE system variable
DGNOSNAP システム変数
DIASTAT システム変数
DIMADEC system variable
DIMALT システム変数
DIMALTD システム変数
DIMALTF システム変数
DIMALTRND システム変数
DIMALTTD システム変数
DIMALTTZ system variable
DIMALTU システム変数
DIMALTZ システム変数
DIMANNO システム変数
DIMAPOST システム変数
DIMARCSYM システム変数
DIMASO system variable
DIMASSOC システム変数
DIMASZ システム変数
DIMATFIT system variable
DIMAUNIT システム変数
DIMAZIN システム変数
DIMBLK system variable
DIMBLK1 システム変数
DIMBLK2 system variable
DIMCEN system variable
DIMCLRD システム変数
DIMCLRE システム変数
DIMCLRT システム変数
DIMDEC system variable
DIMDLE system variable
DIMDLI system variable
DIMDSEP system variable
DIMEXE システム変数
DIMEXO system variable
DIMFIT システム変数
DIMFRAC システム変数
DIMFXL system variable
DIMFXLON システム変数
DIMGAP system variable
DIMJOGANG system variable
DIMJUST system variable
DIMLAYER システム変数
DIMLDRBLK system variable
DIMLFAC システム変数
DIMLIM システム変数
DIMLTEX1 system variable
DIMLTEX2 system variable
DIMLTYPE system variable
DIMLUNIT system variable
DIMLWD system variable
DIMLWE system variable
DIMPOST システム変数
DIMRND システム変数
DIMSAH システム変数
DIMSCALE system variable
DIMSD1 system variable
DIMSD2 システム変数
DIMSE1 システム変数
DIMSE2 システム変数
DIMSHO システム変数
DIMSOXD システム変数
DIMSTYLE system variable
DIMTAD システム変数
DIMTDEC システム変数
DIMTFAC システム変数
DIMTFILL システム変数
DIMTFILLCLR システム変数
DIMTIH システム変数
DIMTIX システム変数
DIMTM システム変数
DIMTMOVE システム変数
DIMTOFL システム変数
DIMTOH システム変数
DIMTOL system variable
DIMTOLJ システム変数
DIMTP システム変数
DIMTSZ システム変数
DIMTVP system variable
DIMTXSTY system variable
DIMTXT system variable
DIMTXTDIRECTION システム変数
DIMTZIN システム変数
DIMUNIT システム変数
DIMUPT システム変数
DIMZIN system variable
DISPLAYAXES system variable
DISPLAYSCALING system variable
DISPLAYSIDESANDENDS system variable
DISPLAYSNAPMARKERINALLVIEWS system variable
DISPLAYTOOLTIPS system variable
DISPPAPERBKG システム変数
DISPPAPERMARGINS system variable
DISPSILH システム変数
DISTANCE システム変数
DMAUDITLEVEL システム変数
DMAUTOUPDATE system variable
DMCONNECTIONCUTTYPE システム変数
DMEXTRUDEMODE system variable
DMPUSHPULLSUBTRACT システム変数
DMRECOGNIZE system variable
DOCKPRIORITY システム変数
DOCTABPOSITION システム変数
DONUTID system variable
DONUTOD システム変数
DRAGMODE system variable
DRAGMODEHIDE システム変数
DRAGMODEINTERRUPT system variable
DRAGOPEN system variable
DRAGP1 システム変数
DRAGP2 システム変数
DRAGSNAP system variable
DRAWINGPATH システム変数
DRAWINGVIEWPRESET system variable
DRAWINGVIEWPRESETHIDDEN system variable
DRAWINGVIEWPRESETSCALE システム変数
DRAWINGVIEWPRESETTANGENT システム変数
DRAWINGVIEWPRESETTRAILING システム変数
DRAWING VIEWQUALITY システム変数
DRAWORDERCTL システム変数
DWFFORMAT system variable
DWFFRAME システム変数
DWFOSNAP システム変数
DWFVERSION システム変数
DWGCHECK system variable
DWGCODEPAGE system variable
DWGNAME system variable
DWGPREFIX system variable
DWGTITLED system variable
DXEVAL システム変数
DXFTEXTADJUSTALIGNMENT system variable
DYNCONSTRAINTMODE system variable
DYNDIGRIP system variable
DYNDIMAPERTURE システム変数
DYNDIMCOLORHOT システム変数
DYNDIMCOLORHOVER システム変数
DYNDIMDISTANCE システム変数
DYNDIMLINETYPE システム変数
DYNDIVIS system variable
DYNINPUTTRANSPARENCY システム変数
DYNMODE system variable
DYNPICOORDS システム変数
E
EDGEMODE system variable
ELEVATION system variable
ENABLEATTRACTION system variable
ENABLEHYPERLINKMENU システム変数
ENABLEHYPERLINKTOOLTIP システム変数
ERRNO system variable
EXPERT システム変数
EXPINSALIGN system variable
EXPINSANGLE システム変数
EXPINSFIXANGLE システム変数
EXPINSFIXSCALE system variable
EXPINSSCALE システム変数
EXPLMODE システム変数
EXPORTACISFORMATVERSION system variable
EXPORTMODELSPACE system variable
EXPORTPAGESETUP システム変数
EXPORTPAPERSPACE システム変数
EXTMAX system variable
EXTMIN システム変数
EXTNAMES system variable
F
FACETRATIO system variable
FACETRES system variable
FBXEXPORTCAMERAS system variable
FBXEXPORTENTITIES システム変数
FBXEXPORTENTITIESSELTYPE system variable
FBXEXPORTLIGHTS システム変数
FBXEXPORTMATERIALS システム変数
FBXEXPORTTEXTURES システム変数
FBXEXPORTTEXTURESPATH system variable
FEATURECOLORS system variable
FIELDDISPLAY system variable
FIELDEVAL システム変数
FILEDIA system variable
FILLETRAD システム変数
FILLMODE システム変数
FLOORTOFLOORDISTANCE system variable
FONTALT システム変数
FONTMAP system variable
FRAMESELECTION システム変数
FRONTZ system variable
FULLOPEN system variable
G
GENERATEASSOCATTRS システム変数
GENERATEASSOCVIEWS システム変数
GEOLATLONGFORMAT システム変数
GEOMARKERVISIBILITY system variable
GEOMRELATIONS システム変数
GETSTARTED system variable
GFANG system variable
GFCLR1 システム変数
GFCLR2 システム変数
GFCLRLUM システム変数
GFCLRSTATE system variable
GFNAME system variable
GFSHIFT システム変数
GLSWAPMODE システム変数
GRADIENTCOLORBOTTOM システム変数
GRADIENTCOLORMIDDLE system variable
GRADIENTCOLORTOP システム変数
GRADIENTMODE システム変数
GRIDAXISCOLOR システム変数
GRIDDISPLAY システム変数
GRIDMAJOR system variable
GRIDMAJORCOLOR system variable
GRIDMINORCOLOR システム変数
GRIDMODE システム変数
GRIDSTYLE システム変数
GRIDUNIT システム変数
GRIDXYZTINT system variable
GRIPBLOCK システム変数
GRIPCOLOR システム変数
GRIPDYNCOLOR system variable
GRIPHOT システム変数
GRIPHOVER システム変数
GRIPOBJLIMIT system variable
GRIPS システム変数
GRIPSIZE システム変数
GRIPTIPS system variable
GSDEVICETYPE2D system variable
GSDEVICETYPE3D system variable
H
HALOGAP システム変数
HANDLES システム変数
HANDSEED system variable
HIDEPRECISION system variable
HIDESYSTEMPRINTERS システム変数
HIDETEXT システム変数
HIDEXREFSCALES system variable
HIGHLIGHT system variable
HIGHLIGHTCOLOR システム変数
HIGHLIGHTEFFECT system variable
HORIZONBKG_ENABLE システム変数
HORIZONBKG_GROUNDHORIZON system variable
HORIZONBKG_GROUNDORIGIN システム変数
HORIZONBKG_SKYHIGH system variable
HORIZONBKG_SKYHORIZON システム変数
HORIZONBKG_SKYLOW システム変数
HOTKEYASSISTANT システム変数
HPANG system variable
HPANNOTATIVE system variable
HPASSOC システム変数
HPBACKGROUNDCOLOR システム変数
HPBOUND システム変数
HPBOUNDRETAIN システム変数
HPCOLOR system variable
HPDOUBLE システム変数
HPDRAWORDER システム変数
HPGAPTOL システム変数
HPISLANDDETECTION システム変数
HPLAYER システム変数
HPLINETYPE システム変数
HPMAXAREAS system variable
HPNAME システム変数
HPOBJWARNING system variable
HPORIGIN システム変数
HPSCALE system variable
HPSEPARATE システム変数
HPSPACE system variable
HPTRANSPARENCY system variable
HYPERLINKBASE システム変数
I
IMAGECACHEFOLDER システム変数
IMAGECACHEMAXMEMORY system variable
IMAGEDISKCACHE システム変数
IMAGEFRAME system variable
IMAGEHLT システム変数
IMAGENOTIFY system variable
IMPORTCUIFILEEXISTS system variable
IMPORTPRODUCTSTRUCTURE system variable
IMPORTREPAIR system variable
INCLUDEPLOTSTAMP システム変数
INDEXCTLシステム変数
INETLOCATION システム変数
INSBASE システム変数
INSNAME system variable
INSUNITS system variable
INSUNITSDEFSOURCE システム変数
INSUNITSDEFTARGET システム変数
INSUNITSSCALING システム変数
INTERFERECOLOR システム変数
INTERFERELAYER system variable
INTERFEREOBJVS システム変数
INTERFEREVPVS system variable
INTERSECTIONCOLOR system variable
INTERSECTIONDISPLAY system variable
ISAVEBAK system variable
ISAVEPERCENT system variable
ISOLINESシステム変数
J
K
L
LASTANGLE system variable
LASTPOINT system variable
LASTPROMPT システム変数
LATITUDE システム変数
LAYERFILTEREXCESS system variable
LAYERPMODE システム変数
LAYLOCKFADECTL システム変数
LAYOUTREGENCTL system variable
LAYOUTTAB system variable
LEGACYCODESEARCH システム変数
LENGTHUNITS システム変数
LENSLENGTH system variable
LEVELOFDETAIL system variable
LICFLAGS システム変数
LIGHTGLYPHCOLOR システム変数
LIGHTGLYPHDISPLAY システム変数
LIGHTINGUNITS システム変数
LIGHTWEBGLYPHCOLOR system variable
LIMCHECK システム変数
LIMMAX system variable
LIMMIN system variable
LINEARBRIGHTNESS システム変数
LINEARCONTRAST system variable
LISPINIT system variable
LOADMECHANICAL2D システム変数
LOCALE system variable
LOCALROOTPREFIX システム変数
LOCKUI system variable
LOFTANG1 system variable
LOFTANG2 システム変数
LOFTMAG1 システム変数
LOFTMAG2 システム変数
LOFTNORMALS システム変数
LOFTPARAM システム変数
LOGFILEMODE システム変数
LOGFILENAME system variable
LOGFILEPATH システム変数
LOGGEDIN システム変数
LOGINNAME system variable
LONGITUDE システム変数
LOOKFROMDIRECTIONMODE システム変数
LOOKFROMFEEDBACK system variable
LOOKFROMZOOMXTENTS システム変数
LTGAPSELECTION system variable
LTSCALE システム変数
LUNITS system variable
LUPREC システム変数
LWDEFAULT system variable
LWDISPLAY システム変数
LWDISPSCALE system variable
LWUNITS system variable
M
MACROREC system variable
MACROTRACE システム変数
MAKEBAK システム変数
MANIPULATOR システム変数
MANIPULATORCOLORTHEME system variable
MANIPULATORDURATION システム変数
MANIPULATORHANDLE system variable
MANIPULATORSIZE システム変数
MASSPREC システム変数
MASSPROPACCURACY システム変数
MASSUNITS システム変数
MAXACTVP システム変数
MAXHATCH システム変数
MAXSORTシステム変数
MAXTHREADS system variable
MBSTATE システム変数
MBUTTONPAN system variable
MEASUREINIT システム変数
MEASUREMENT system variable
MECH2DSAVEFORMAT システム変数
MENUBAR (EXCEPT OS X) システム変数
MENUCTL system variable
MENUECHO system variable
MENUNAME システム変数
MESHTYPE システム変数
MIDDLECLICKCLOSE システム変数
MILLISECS system variable
MIRRTEXT system variable
MLEADERSCALE システム変数
MODEMACRO system variable
MSLTSCALE system variable
MSOLESCALE システム変数
MTEXTCOLUMN system variable
MTEXTDETECTSPACE システム変数
MTEXTED system variable
MTEXTFIXED system variable
MTEXTTOOLBAR システム変数
MTFLAGS システム変数
MYDOCUMENTSFOLDER システム変数
MYDOCUMENTSPREFIX system variable
MECHANICALBROWSERSETTINGS system variable
N
NAVVCUBEDISPLAY システム変数
NAVVCUBELOCATION システム変数
NAVVCUBEOPACITY システム変数
NAVVCUBEORIENT system variable
NAVVCUBESIZE システム変数
NEARESTDISTANCE システム変数
NOMUTT system variable
NORTHDIRECTION システム変数
O
OBJECTISOLATIONMODE system variable
OBSCUREDCOLOR システム変数
OBSCUREDLTYPE システム変数
OFFSETDIST system variable
OFFSETERASE システム変数
OFFSETGAPTYPE system variable
OLEFRAME システム変数
OLEHIDE システム変数
OLEQUALITY システム変数
OLESTARTUP system variable
OPMSTATE system variable
ORBITAUTOTARGET system variable
ORTHOMODE システム変数
OSMODE システム変数
OSNAPCOORD system variable
OSNAPZ システム変数
OSOPTIONS システム変数
OVERKILLLAYER システム変数
P
PANBUFFER system variable
PANELBUTTONSIZE system variable
PAPERUPDATE システム変数
PARAMETERCOPYMODE system variable
PARAMETRICBLOCKS2DPATH システム変数
PDFCACHE システム変数
PDFEMBEDDEDTTF system variable
PDFEXPORTHYPERLINKS システム変数
PDFEXPORTSOLIDHATCHTYPE システム変数
PDFFRAME system variable
PDFHATCHTOBMPDPI システム変数
PDFIMAGEANTIALIAS system variable
PDFIMAGECOMPRESSION システム変数
PDFIMAGEDPI system variable
PDFIMPORTAPPLYLINEWEIGHT システム変数
PDFIMPORTASBLOCK システム変数
PDFIMPORTCONVERTSOLIDSTOHATCHES システム変数
PDFIMPORTIMAGEPATH システム変数
PDFIMPORTJOINLINEANDARCSEGMENTS system variable
PDFIMPORTLAYERSUSETYPE system variable
PDFIMPORTRASTERIMAGES system variable
PDFIMPORTSOLIDFILLS system variable
PDFIMPORTTRUETYPETEXT システム変数
PDFIMPORTTRUETYPETEXTASGEOMETRY システム変数
PDFIMPORTUSEGEOMETRYOPTIMIZATION system variable
PDFIMPORTVECTORGEOMETRY システム変数
PDFLAYERSSETTING system variable
PDFLAYOUTSTOEXPORT system variable
PDFMERGECONTROL システム変数
PDFNOTIFY system variable
PDFOSNAP system variable
PDFPAPERHEIGHT システム変数
PDFPAPERSIZEOVERRIDE system variable
PDFPAPERWIDTH システム変数
PDFPRCCOMPRESSION system variable
PDFPRCEXPORT system variable
PDFPRCEXPORTPRODUCTSTRUCTUREMODE システム変数
PDFPRCSINGLEVIEWMODE system variable
PDFRENDERDPI system variable
PDFSHXTEXTASGEOMETRY システム変数
PDFSIMPLEGEOMOPTIMIZATION システム変数
PDFTTFTEXTASGEOMETRY system variable
PDFUSEPLOTSTYLES system variable
PDFVECTORRESOLUTIONDPI system variable
PDFZOOMTOEXTENTSMODE system variable
PDMODE system variable
PDSIZE system variable
PEDITACCEPT システム変数
PELLIPSE system variable
PERIMETER システム変数
PERSPECTIVE system variable
PFACEVMAX system variable
PHANDLE システム変数
PICKADD システム変数
PICKAUTO システム変数
PICKBOX システム変数
PICKDRAG システム変数
PICKFIRST system variable
PICKSTYLE (EXCEPT OS X) system variable
PICTUREEXPORTSCALE system variable
PLACESBARFOLDER1 システム変数
PLACESBARFOLDER2 system variable
PLACESBARFOLDER3 システム変数
PLACESBARFOLDER4 system variable
PLATFORMシステム変数
PLINECACHE system variable
PLINECONVERTMODE system variable
PLINEGENシステム変数
PLINETYPE システム変数
PLINEWID システム変数
PLOTCFGPATH system variable
PLOTID システム変数
PLOTOUTPUTPATH システム変数
PLOTROTMODE system variable
PLOTSTYLEPATH システム変数
PLOTTER システム変数
PLOTTRANSPARENCYOVERRIDE システム変数
PLQUIET システム変数
POINTCLOUD2DVSDISPLAY system variable
POINTCLOUDADAPTIVEDISPLAY システム変数
POINTCLOUDBOUNDARY system variable
POINTCLOUDCACHEFOLDER system variable
POINTCLOUDCACHESIZE システム変数
POINTCLOUDPOINTMAX システム変数
POINTCLOUDPOINTSIZE システム変数
POLARADDANG システム変数
POLARANG システム変数
POLARDIST システム変数
POLARMODE system variable
POLYSIDES system variable
POPUPS システム変数
PREVIEW_HEIGHT system variable
PREVIEW_WIDTH system variable
PREVIEWDELAY system variable
PREVIEWEFFECT システム変数
PREVIEWFILTER システム変数
PREVIEWTYPE システム変数
PREVIEWWNDINOPENDLG システム変数
PRINTFILE system variable
PRINTPDFPREVIEW system variable
PRODUCT システム変数
PROGBAR システム変数
PROGRAM システム変数
PROJECTIONTYPE system variable
PROJECTNAME システム変数
PROJECTSEARCHPATHS システム変数
PROJMODE system variable
PROMPTMENU システム変数
PROMPTMENUFLAGS システム変数
PROMPTOPTIONFORMAT system variable
PROMPTOPTIONTRANSLATEKEYWORDS system variable
PROPERTYPREVIEW system variable
PROPERTYPREVIEWDELAY システム変数
PROPERTYPREVIEWOBJLIMIT system variable
PROPPREVTIMEOUT システム変数
PROPUNITS システム変数
PROXYGRAPHICS system variable
PROXYNOTICE system variable
PROXYSHOW システム変数
PROXYWEBSEARCH system variable
PSLTSCALE system variable
PSOLHEIGHT システム変数
PSOLWIDTH システム変数
PSPROLOG system variable
PSQUALITY システム変数
PSTYLEMODE システム変数
PSTYLEPOLICY システム変数
PSVPSCALE システム変数
PUBLISHALLSHEETS システム変数
PUCSBASE system variable
Q
QAFLAGS システム変数
QTEXTMODE システム変数
QUADCOMMANDLAUNCH system variable
QUADDISPLAY システム変数
QUADEXPANDDELAY システム変数
QUADEXPANDTABDELAY system variable
QUADGOTRANSPARENT システム変数
QUADHIDEDELAY system variable
QUADHIDEMARGIN システム変数
QUADICONSIZE system variable
QUADICONSPACE システム変数
QUADMOSTRECENTITEMS system variable
QUADPOPUPCORNER システム変数
QUADROLLOVERDELAY system variable
QUADSHOWDELAY system variable
QUADWIDTH system variable
R
R12SAVEACCURACY system variable
R12SAVEDEVIATION システム変数
RASTERPREVIEW system variable
RE_INIT システム変数
REALTIMESPEEDUP system variable
REALWORLDSCALE システム変数
RECENTFILES システム変数
RECENTPATH system variable
REDHILITE_DUCSLOCKED_FACE_ALPHA system variable
REDHILITE_DUCSLOCKED_FACE_COLOR system variable
REDHILITE_HIDDENEDGE_ALPHA システム変数
REDHILITE_HIDDENEDGE_COLOR システム変数
REDHILITEFULL_EDGE_ALPHA システム変数
REDHILITEFULL_EDGE_COLOR system variable
REDHILITEFULL_EDGE_SHOWHIDDEN システム変数
REDHILITEFULL_EDGE_SMOOTHING システム変数
REDHILITEFULL_EDGE_THICKNESS システム変数
REDHILITEFULL_FACE_ALPHA system variable
REDHILITEFULL_FACE_COLOR システム変数
REDHILITEPARTIAL_SELECTEDEDGE_ALPHA system variable
REDHILITEPARTIAL_SELECTEDEDGE_COLOR システム変数
REDHILITEPARTIAL_SELECTEDEDGE_SHOWGLOW システム変数
REDHILITEPARTIAL_SELECTEDEDGE_SMOOTHING システム変数
REDHILITEPARTIAL_SELECTEDEDGE_THICKNESS システム変数
REDHILITEPARTIAL_SELECTEDEDGEGLOW_ALPHA システム変数
REDHILITEPARTIAL_SELECTEDEDGEGLOW_COLOR システム変数
REDHILITEPARTIAL_SELECTEDEDGEGLOW_SMOOTHING システム変数
REDHILITEPARTIAL_SELECTEDEDGEGLOW_THICKNESS system variable
REDHILITEPARTIAL_SELECTEDFACE_ALPHA system variable
REDHILITEPARTIAL_SELECTEDFACE_COLOR システム変数
REDHILITEPARTIAL_UNSELECTEDEDGE_SHOWHIDDEN システム変数
REDSDKLINESMOOTHING システム変数
REFEDITLOCKNOTINWORKSET system variable
REFEDITNAME system variable
REGENMODE システム変数
REGEXPAND system variable
REMEMBERFOLDERS system variable
RENDERCOMPOSITIONMATERIAL system variable
RENDERMATERIALDOWNLOAD system variable
RENDERMATERIALSPATH システム変数
RENDERUSINGHARDWARE system variable
REPORTPANELMODE system variable
REPOSITORYFOLDER system variable
RESTORELOSTFOCUS システム変数
RETINADISPLAY システム変数
REVCLOUDARCSTYLE システム変数
REVCLOUDCREATEMODE システム変数
REVCLOUDGRIPS system variable
REVCLOUDMAXARCLENGTH システム変数
REVCLOUDMINARCLENGTH システム変数
RHINOVERSION システム変数
RIBBONDOCKEDHEIGHT system variable
RIBBONPANELMARGIN system variable
RIBBONSTATE system variable
RIBBONTOOLSIZE system variable
ROAMABLEROOTFOLDER システム変数
ROAMABLEROOTPREFIX システム変数
ROLLOVEROPACITY システム変数
ROLLOVERSELECTIONSET system variable
ROLLOVERTIPS システム変数
RTDISPLAY system variable
RTROTATIONSPEEDFACTOR system variable
RUBBERBANDCOLOR system variable
RUBBERBANDSTYLE system variable
RUBBERSHEET (for OS X) system variable
RUBBERSHEETSENSIBILITY (FOR OS X) システム変数
RUNASLEVEL system variable
S
SAFEMODE system variable
SAVECHANGETOLAYOUT system variable
SAVEFIDELITY システム変数
SAVEFILE システム変数
SAVEFILEPATH system variable
SAVEFORMAT システム変数
SAVELAYERSNAPSHOT システム変数
SAVENAME システム変数
SAVEONDOCSWITCH system variable
SAVEROUNDTRIP system variable
SAVETIME システム変数
SCREENBOXES system variable
SCREENMODE システム変数
SCREENSIZE システム変数
SCRLHIST システム変数
SDI system variable
SECURELOAD system variable
SECTIONSETTINGSSEARCHPATH system variable
SELECTIONANNODISPLAY system variable
SELECTIONAREA システム変数
SELECTIONAREAOPACITY system variable
SELECTIONMODES system variable
SELECTIONPREVIEW system variable
SELECTSIMILARMODE システム変数
SETBYLAYERMODE system variable
SHADEDGE system variable
SHADEDIF system variable
SHEETNUMBERLEADINGZEROES system variable
SHEETSETAUTOBACKUP システム変数
SHEETSETTEMPLATEPATH システム変数
SHORTCUTMENU システム変数
SHORTCUTMENUDURATION system variable
SHOWDOCTABS system variable
SHOWFULLPATHINTITLE システム変数
SHOWLAYERUSAGE システム変数
SHOWSCROLLBUTTONS system variable
SHOWTABCLOSEBUTTON システム変数
SHOWTABCLOSEBUTTONACTIVE system variable
SHOWTABCLOSEBUTTONALL システム変数
SHOWWINDOWLISTBUTTON システム変数
SHPNAME system variable
SINGLETONMODE システム変数
SKETCHINC system variable
SKPOLY システム変数
SKYSTATUS system variable
SLABTHICKNESS system variable
SMASSEMBLYEXPORTMODE システム変数
SMASSEMBLYEXPORTREPORTPATHTYPE system variable
SMASSEMBLYEXPORTSOLIDTYPESINREPORTS system variable
SMATTRIBUTESLAYERCOLOR system variable
SMATTRIBUTESLAYERTEXTHEIGHT system variable
SMATTRIBUTESLAYERTEXTHEIGHTTYPE system variable
SMBENDANNOTATIONSLAYERCOLOR system variable
SMBENDANNOTATIONSLAYERTEXTHEIGHT system variable
SMBENDANNOTATIONSLAYERTEXTHEIGHTTYPE system variable
SMBENDLINESUPLAYERCOLOR system variable
SMBENDLINESUPLAYERLINETYPE system variable
SMBENDLINESUPLAYERLINEWEIGHT system variable
SMBENDLINESDOWNLAYERCOLOR system variable
SMBENDLINESDOWNLAYERLINETYPE system variable
SMBENDLINESDOWNLAYERLINEWEIGHT system variable
SMCOLORBEND system variable
SMCOLORBENDRELIEF system variable
SMCOLORBEVEL system variable
SMCOLORCORNERRELIEF system variable
SMCONTOURSLAYERLINETYPE system variable
SMCONTOURSLAYERLINEWEIGHT system variable
SMCONTOURSLAYERCOLOR system variable
SMCONVERTMAXIMALBEVELANGLE system variable
SMCONVERTMINIMALBEVELANGLE system variable
SMCONVERTPREFERFORMFEATURES system variable
SMCONVERTPREFERHEMFEATURES system variable
SMCONVERTPREFERZEROBENDFEATURES system variable
SMCONVERTRECOGNIZEHOLES system variable
SMCONVERTRECOGNIZERIBCONTROLCURVES system variable
SMCONVERTWRONGFEATURETHICKNESSDEVIATIONTYPE system variable
SMCONVERTWRONGFEATURETHICKNESSDEVIATIONVALUE system variable
SMDEFAULTKFACTOR system variable
SMDEFAULTHEMRELATIVEBENDDEDUCTION system variable
SMDEFAULTFORMFEATUREUNFOLDMODE system variable
SMDEFAULTBENDLINEEXTENTTYPE system variable
SMDEFAULTBENDLINEEXTENTVALUE system variable
SMDEFAULTBEVELFEATUREUNFOLDMODE system variable
SMEXPORTOSMAPPROXIMATIONACCURACY system variable
SMEXPORTOSMMINIMALEDGELENGTH system variable
SMFORMFEATURESUPCOLOR system variable
SMFORMFEATURESUPLAYERLINETYPE system variable
SMFORMFEATURESDOWNCOLOR system variable
SMFORMFEATURESUPLAYERLINEWEIGHT system variable
SMFORMFEATURESDOWNLAYERLINETYPE system variable
SMFORMFEATURESDOWNLAYERLINEWEIGHT system variable
SMJUNCTIONCREATEHEALCOINCIDENT system variable
SMOOTHMESHCONVERT システム変数
SMPARAMETRIZEHOLESPARAMETRIZATION system variable
SMREPAIRLOFTEDBENDMERGE system variable
SMSMARTFEATURES システム変数
SMSPLITAMBIGUOUSINPUT system variable
SMSPLITCONVERTBENDTOJUNCTION system variable
SMSPLITHEALCOINCIDENT system variable
SMSPLITORTHOGONALBENDSPLIT system variable
SMTARGETCAM system variable
SMOVERALLANNOTATIONSLAYERCOLOR system variable
SMOVERALLANNOTATIONSLAYERLINETYPE system variable
SMOVERALLANNOTATIONSLAYERLINEWEIGHT system variable
SMBEVELFEATURECOLOR system variable
SNAPANG system variable
SNAPBASE システム変数
SNAPCOLOR システム変数
SNAPISOPAIR system variable
SNAPMARKERCOLOR system variable
SNAPMARKERSIZE システム変数
SNAPMARKERTHICKNESS システム変数
SNAPMODE システム変数
SNAPSIZE システム変数
SNAPSTYL system variable
SNAPTHICKNESS システム変数
SNAPTYPE システム変数
SNAPUNIT system variable
SOLIDCHECK システム変数
SORTENTS システム変数
SPAADJUSTMODE システム変数
SPACHECKLEVEL システム変数
SPAGRIDASPECTRATIO システム変数
SPAGRIDMODE system variable
SPAMAXFACETEDGELENGTH system variable
SPAMAXNUMGRIDLINES system variable
SPAMINUGRIDLINES システム変数
SPAMINVGRIDLINES システム変数
SPANORMALTOL system variable
SPASURFACETOL system variable
SPATRIANGMODE system variable
SPAUSEFACETRES system variable
SPLFRAME system variable
SPLINESEGS system variable
SPLINETYPE system variable
SRCHPATH システム変数
SSFOUND システム変数
SSLOCATE システム変数
SSMAUTOOPEN system variable
SSMPOLLTIME システム変数
SSMSHEETSTATUS システム変数
SSMSTATE システム変数
STACKPANELTYPE システム変数
STAMPFONTSIZE system variable
STAMPFONTSTYLE system variable
STAMPFOOTER システム変数
STAMPFOOTEROFFSETX system variable
STAMPFOOTEROFFSETY システム変数
STAMPHEADER system variable
STAMPHEADEROFFSETX システム変数
STAMPHEADEROFFSETY system variable
STAMPUNITS システム変数
STARTUP システム変数
STARTUPTODAY システム変数
STATUSBAR システム変数
STEPSIZEシステム変数
STEPSPERSECシステム変数
STLPOSITIVEQUADRANT システム変数
STRUCTUREDISPLAYMODE システム変数
STRUCTURETREECONFIG system variable
SURFTAB1 system variable
SURFTAB2 システム変数
SURFTYPE システム変数
SURFU システム変数
SURFV system variable
SVGBLENDEDGRADIENTS システム変数
SVGDEFAULTIMAGEEXTENSION システム変数
SVGGENERICFONTFAMILY system variable
SVGIMAGEBASE system variable
SVGIMAGEURL system variable
SVGLINEWEIGHTSCALE system variable
SVGOUTPUTHEIGHT system variable
SVGOUTPUTWIDTH システム変数
SVGPRECISION system variable
SVGSCALEFACTOR system variable
SYSCODEPAGE システム変数
T
TABCONTROLHEIGHT system variable
TABMODE システム変数
TABSFIXEDWIDTH system variable
TARGET システム変数
TDCREATE system variable
TDINDWG システム変数
TDUCREATE system variable
TDUPDATE システム変数
TDUSRTIMER system variable
TDUUPDATE システム変数
TEMPLATEPATH システム変数
TEMPPREFIX system variable
TEXTANGLE システム変数
TEXTED システム変数
TEXTEDITMODE システム変数
TEXTEVAL system variable
TEXTFILL システム変数
TEXTQLTY システム変数
TEXTSIZE system variable
TEXTSTYLE system variable
TEXTUREMAPPATH システム変数
THICKNESS システム変数
THUMBSIZE system variable
TILEMODE system variable
TILEMODELIGHTSYNCH system variable
TIMEZONE system variable
TOOLBARMARGIN システム変数
TOOLBUTTONSIZE システム変数
TOOLICONPADDING システム変数
TOOLPALETTEPATH system variable
TOOLTIPDELAY システム変数
TOOLTIPS システム変数
TPSTATE システム変数
TRACEWID システム変数
TRACKPATH system variable
TRANSPARENCYDISPLAY system variable
TRAYICONS システム変数
TRAYNOTIFY システム変数
TRAYTIMEOUT システム変数
TREEDEPTH system variable
TREEMAX システム変数
TRIMMODE system variable
TRUSTEDPATHS system variable
TSPACEFAC system variable
TSPACETYPE システム変数
TSTACKALIGN システム変数
TSTACKSIZE システム変数
TTFASTEXT システム変数
U
UCSAXISANG system variable
UCSDETECT システム変数
UCSFOLLOW system variable
UCSICON system variable
UCSICONPOS システム変数
UCSNAME システム変数
UCSORG system variable
UCSORTHO システム変数
UCSVIEW システム変数
UCSVP system variable
UCSXDIR system variable
UCSYDIR システム変数
UNDOCTL system variable
UNDOMARKS システム変数
UNITMODE system variable
USECOMMUNICATOR システム変数
USERI1 システム変数
USERI2 システム変数
USERI3 システム変数
USERI4 system variable
USERI5 system variable
USERR1 system variable
USERR2 system variable
USERR3 システム変数
USERR4 システム変数
USERR5 システム変数
USERS1 system variable
USERS2 システム変数
USERS3 システム変数
USERS4 システム変数
USERS5 system variable
USESTANDARDOPENFILEDIALOG system variable
V
VBAMACROS system variable
VENDORNAME システム変数
VERSIONCONTROLPATH system variable
VERSIONCUSTOMIZABLEFILES システム変数
VIEWCTR システム変数
VIEWDIR システム変数
VIEWSIZE system variable
VIEWTWIST システム変数
VIEWUPDATEAUTO system variable
VISRETAIN システム変数
VOLUMEPREC システム変数
VOLUMEUNITS システム変数
VPMAXIMIZEDSTATE システム変数
VPROTATEASSOC system variable
VSMAX system variable
VSMIN system variable
VTDURATION システム変数
VTENABLE システム変数
VTFPS システム変数
W
WALLWIDTH system variable
WARNINGMESSAGES system variable
WHIPARC system variable
WHIPTHREAD system variable
WINDOWAREACOLOR システム変数
WIPEOUTFRAME システム変数
WMFBKGND システム変数
WMFFOREGND system variable
WNDLMAIN システム変数
WNDLSCRL system variable
WNDLTEXT システム変数
WNDPMAIN system variable
WNDPTEXT システム変数
WNDSMAIN システム変数
WNDSTEXT システム変数
WORLDUCS システム変数
WORLDVIEW システム変数
WRITESTAT システム変数
WSAUTOSAVE システム変数
WSCURRENT システム変数
X
XCLIPFRAME system variable
XDWGFADECTL システム変数
XEDIT system variable
XFADECTL システム変数
XLOADCTL システム変数
XLOADPATH system variable
XNOTIFYTIME システム変数
XREFCTL システム変数
XREFNOTIFY システム変数
XREFOVERRIDE system variable
Y
Z
ZOOMFACTOR システム変数
ZOOMWHEEL システム変数
Document tabs
Parent topic:
User interface
