BIMDISTRIBUTIONSYSTEM command
Creates or edits a BIM Distribution system group.
BricsCAD BIM
Method
Enter an existing distribution system name or a name for a new distribution system, then select the entities to add to or remove from the distribution system.
Note: Distribution systems created with BIMDISTRIBUTIONSYSTEM command are exported with IFCEXPORT command as IfcDistributionSystem entities.
Options within the command
List distribution systems
Lists in the command line panel all existing BIM Distribution System groups.
Create a distribution system
Creates a new group of BIM Distribution System.
Show properties
Allows you to edit the properties. The available properties are displayed in the command line panel.
Ifc properties
Allows you to edit the IFC Properties. The available IFC Properties are displayed in the command line panel.
Delete distribution system
Deletes the selected BIM Distribution System group.
Creates a new BIM Distribution System group.
