Drawing splines
A spline is an open or closed smooth curve defined by a set of points. You can use splines to draw curved lines, which cannot be drawn as a polyline.
The Spline tool is available on:
- The Draw menu.
 - The Draw toolbar.
 - The Draw ribbon panel.
 - The Draw tab of the No Selection Quad.
General procedure
Launch the SPLINE command.
Prompts you: First point of spline:
Specify a point.
Prompts you: Second point:
Specify a point.
Prompts you: Set next point or [Close/Fit tolerance/Undo]:
(option) Repeat step 3 to define more points.
Right click to stop adding more points.
Prompts you: Select starting tangent point:
A line that is tangent to the spline displays dynamically from the start point of the spline.
Click to define the starting curve of the spline.
Prompts you: Select ending tangent point:
A line that is tangent to the spline displays dynamically from the end point of the spline.
Click to create the spline.
