Add Property dialog box
The Add Property dialog box allows you to add properties to text contents for label styles.
- Use property from other objects
- Object type
- Object name
- Select property
Toggles the use of properties from other objects.
Object type
Lists all available objects types in a drop-down list.
Object name
Displays the object name.
Select property
Displays a list with all available properties of the object.
