Create Schedule dialog box
Create a new schedule in the project browser.
- Nazwa
- Data Extraction File
- CSV File
- Result Path
Nazwa
Specifies the name of the new schedule.
Selects the data extraction file that will be used. Opens the Select Data Extraction Definition file dialog box where you can select a file.
CSV File
Defines the CSV file that will be used. Opens the Select Delimiter-separated format file dialog box where you can select a file.
Result Path
Defines the path where the resulting drawing will be saved. Opens the Select Drawing file dialog box where you can select a drawing to save the result.
