Edit scale dialog box
The Edit Scale dialog box allows you to edit the name and the scale properties of a scale factor.
  1. Scale name
  2. Scale properties
Scale name
Edit the name by typing the new name.
Scale properties
Change the scale factor in paper (size when plotted) and/or drawing units.
Parent topic: BricsCAD
Parent topic: Okna dialogowe
Related commands
  • Polecenie EDLISTYSKAL.
  • -EDLISTYSKAL polecenie
  • SKALAOBIEKTU polecenie
  • Polecenie -SKALAOBIEKTU
  • PRINT command
  • PAGESETUP command
