Add menu item dialog box
The Add button item dialog box allows you to add a menu item by selecting an available tool or by creating a new tool.
Assigns an existing command to the new button or button group. If this option is selected, the other options are grayed out, except for Available tools.
Assigns a new command/macro to the new button or button group. If this option is selected, Available tools is grayed out.
Specifies the toolbox to which to add the new command. You can choose a toolbox in the drop-down list.
Specifies the name of the new tool.
Specifies the help string displayed on the status bar.
Specifies the command(s) or macros.
Specifies the image to display for the new tool. The browse icon opens the Tool Image dialog box. There are five options to select an image.
Selects an existing tool.
