Allowed deviations from center axis dialog box
The Allowed Deviation from Center Axis dialog box allows you to set the level of freedom used when generating an analytical model.
- Restricted parallel deviation
- Maximal deviation in profile directions
- Parallel deviation within bounds
- Unrestricted parallel deviation
- Any deviation
Axes remain parallel to center axis and within the specified distance from the center axis in both profile directions.
Set the maximal deviation in profile directions.
Axis remain parallel to center axis and do not exceed profile bounds.
Axes remain parallel to center axis, but can be placed outside the profile bounds if is useful to avoid node splits or rigid links.
Any deviation
The main axes remain parallel to the center axis, but tilted axis (with respect to vertical and main horizontal directions) can be allowed to deviate from parallel if useful to avoid node splits and rigid links. Other axes can move outside of profile bounds.
Click OK to open the Visual settings dialog box.
