Manage visibility
The Manage Visibility dialog box displays a list of visibility states in the drawing.
- Show invisible
- Rename
- Delete
- Add State
- Select visible entities for all states
- Select invisible entities
Show invisible
Shows all invisible entities grayed-out.
Rename
Displays the Rename dialog box. Type a name to replace the existing name.
Delete
Deletes the parameter and its visibility states.
Add State
Displays the Rename dialog box. Type a name for the new state to replace the default name.
First choose Show invisible, then select the entities to remove all visibility states from the selected parameter.
Visualizes all entities that are selected.
Hides all entities that are selected.
