New Sheet(s) dialog box
The New sheets dialog box allows you to create (a) new sheet(s) within an existing sheet set.
When starting from scratch, the dialog box includes 5 areas. By selecting the Import layouts from existing drawings option, the dialog box includes 4 areas.
- Number
- Title
- File name
- Folder path
- Template
- Add drawing(s)…
- Sheet titles
- Automatic numbering
- Leading zeroes
Create from scratch
Allows you to create a new sheet from scratch
- Number: defines the number of sheets.
- Title: defines the title of the new sheet(s).
- File name: defines the name of the file in which the new sheet(s) will be saved.
- Folder path: defines the location of the file.
- Template: choose the template of the new sheet(s).
Import layout
Allows you to create a new sheet with properties of an existing layout
- Add drawing(s)…: selects drawings to import a layout from trough the Select Drawing(s) dialog box.
- Sheet titles: specifies how the selected drawing
should be listed by selecting one of the options in the drop-down list.
- Drawing name: displays the drawing name of the selected drawings.
- Drawing name- Layout name: displays the drawing name and the layout name of the selected drawings.
- Layout name: displays the layout name of the selected drawings.
- Automatic numbering: numbers the layouts automatically.
- Leading zeroes: specifies how the Number value of new sheets is formatted by adding zeroes at the start of a sheet number.
