Sheet Properties dialog box
The Sheet Properties dialog box allows you to view and edit properties of a sheet.
- Number
- Name
- Description
- Destination File
- Publish
- Category
Number
Specifies the number of the selected sheet.
Name
Specifies the name of the selected sheet.
Specifies a short description of the selected sheet.
Destination File
Specifies the file in which the sheet will be saved.
Publish
Toggles the option to publish the currently selected sheet.
Category
Specifies the category of the selected sheet.
