Standard save file dialog box
The Standard Save File dialog box allows you to save or export a file.
This dialog box can be accessed using multiple commands.
- Dialog name
- Save in
- Quick access
- Use preview
- File name
- Files of type
Dialog name
Displays the dialog name depending on the command used.
Save in
Allows you to specify the location of your file. To change it to a different disk drive or folder, click the arrow and select another disk drive or folder from the drop-down list.
To scroll the list, press the F4 key.
Quick access
The Quick Access is available if USESTANDARDOPENFILEDIALOG = 1.
You can populate Quick access with folders that you want to be always available, not only for folders that have being used recently. The folders shown in Quick access can be configured in Windows Explorer.
Quick Access folders are available during both open and save operations.
Use preview
Tick the checkbox to see a part of the file before saving.
File name
Specifies the name of the file. You can accept the predefined name or you can specify a different name.
Files of type
Displays a list of valid file types. You can select a file type to filter the files list so that it only shows files matching that type.
